ADD W1 VER1 Oil Catch Can Group Buy "FEELER FAIL"-Please delete!!
Discussion in 'Group Buys' started by Rusty15Tacoma, Sep 29, 2015.
  1. Oct 26, 2015 at 7:17 PM
    #121
    Phoenix autoworks
    Phoenix autoworks Stock but fun!!!
    Josh
    North Phoenix
    95.5 Tacoma 4x4 3.4 manual
    Stock but I use it anyway!!!
    Can someone explain to me how a company in 2015 has a website and the auto correct, the guy typing the ad, or the website editor caught "pupple" as a color. Does cheap website=cheap product?
  2. Oct 27, 2015 at 12:14 AM
    #122
    Russtoy
    Russtoy Well-Known Member
    Russel
    Ohio
    2000 4Runner SR5
    Good question!! I'd lean toward yes. So what's your company about? What does @Phoenix autoworks sell?
    I can't believe no company would do a better deal then $5...that's sad!! Plenty of guys looked at the GB...most figured...why...not going to mess with it for $5. Too bad...there's a lot of guys out there that really should be running these. OP...thank you for all your time and efforts. No one can say it was due to lack of effort.
    - Russel
  3. Oct 27, 2015 at 3:51 AM
    #123
    XJfella95
    XJfella95 Product Developer
    Brandon
    Reading Pennsylvania
    '08 Taco DCSB
    A Few
    An important note on the install of the VMS can. With the internal hose that goes through the baffles, I trimmed it up another 1-1/2" to go through just the lowest baffle. I found that the tube was too low and when the oil starts to collect, the longer hose which sat near the bottom of the can, would froth up the oil.
    Edit: Also this should go without saying, Unless you are running the supercharger, the top filter does not get used.
    Tyson likes this.
  4. Oct 27, 2015 at 9:00 AM
    #124
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    Why no filer for non SC engine?
  5. Oct 27, 2015 at 10:51 AM
    #125
    XJfella95
    Brandon
    '08 Taco DCSB
    A Few
    Because the PCV system is a closed loop. if there is a leak between the crank case and the intake manifold the ECM will kick a Check engine light. Just buy new high pressure fuel line and run this oil catch can in-line and plug the top with the "filter plug". the engine on a naturally aspirated engine works to equalize the pressures in crank case by pulling from the intake.
    on a SC engine the intake is now pressurized and if you were to keep the system closed you would over pressurize the crank case and blow seals.
    SNIP: non supercharged=no filter
    supercharged=use filter
    I'm going to start a thread for this oil-catch can so that the information can be easily accessible.
    Edit: new thread link
    https://www.tacomaworld.com/threads/vms-oil-catch-can-install.397972/
    Russtoy likes this.
  6. Oct 27, 2015 at 2:15 PM
    #126
    Russtoy
    Russel
    Ohio
    2000 4Runner SR5
    @XJfella95 you did a very nice job explaining this. I too think there should be a write up on this, which I see you've already taken care of. I guess I'll have to make you my new hero...heck, I'll even throw in an attaboy or two...lol!! You da main man bro!!
    Seriously...great job!
    - Russel
    XJfella95[QUOTED] likes this.
  7. Oct 27, 2015 at 3:09 PM
    #127
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Well crap, just got an email from the seller, they are out of black lol, I settled for gun metal. I'll probably just sand up the can and paint it black though. I like the black engine compartment, and gun metal does not match at all :D
  8. Oct 27, 2015 at 3:53 PM
    #128
    Sje1124
    Sean
    Louisiana
    Just a few
    Bahahaha I'm still looking for one
  9. Oct 27, 2015 at 5:50 PM
    #129
    VolcomTacoma
    Jeff
    NorCal
    F it. Its just a color, point is I dont want all that oil hitting my intercooler. Ill take bright pink if thats all they have
  10. Oct 28, 2015 at 3:45 AM
    #130
    XJfella95
    Brandon
    '08 Taco DCSB
    A Few
  11. Oct 28, 2015 at 5:02 AM
    #131
    ThomasMore66
    Dallas/Fort Worth & Durango
    TRD Supercharger, TRD exhaust, Leather seats, running boards removed (why it came with them I cannot imagine), Salex organizers, BAMF behind-the-grill light bar, Rigid SR-20 and SR-Q - Spots mounted behind stock grill, color-matched grill, WeatherTech FloorLiner DigitalFit floor mats, Tech Deck, Avid bolt-on slider/step converted to weld on by TW member Achirdo, Diaz Fabrication Model T, Icon Stage 4 with OME Dakar rear leaf springs, OME Driveshaft spacer, Toytec 1" Front Diff Drop, FN BFD 18"x9" GMG Wheels, BFG KO2 285-65-18 tires, Ultragauge mounted above mirror, Tuffy Box lockable storage, MattGecko rear window security bar, Relentless Fab tailgate protector, CSJumper 700 lumen flood pattern back-up LED's, modified BeeRadd under-hood lighting with two KC Cyclones; KB Voodoo cargo management system and standard rails, AllPro hi-lift jack mount, 48" hi-lift, RCI Metalworks aluminum front skid, Flyzeye 3VP-RS in glovebox and console, AFE CAI, Coupe fuse box cover, battery hold-down bracket and CAI air-box cover, Wurton pod led's installed as bed lights on Lowbrow Customs motorcycle fork brake line aluminum brackets, Pop-n-Lock PL5400, Extang Solidfold 2.0, Rechelon Retro's, Moromoto LED fogs, URD Y-pipe, Walbro 255lph fuel pump, Speedhut AFR and Boost gauges, Cravenspeed gauge holder, CMC by Tandem Automotive, 70mm throttle body, CSF radiator, Doug Thorley shorties, Vibrant 7101 cats, SOS Offroad front and rear bumpers, Smoothflow 2.5” SC pulley, Steeda SC belt tensioner, roostfactor belt wrap kit, switch Pro 9100 in custom Tandem Automotive holder, WAT trans valvebody, FIC 650cc injectors, HP Tuner.
    There are at least two other threads on here that have lots of catch can info.
    https://www.tacomaworld.com/threads/oil-catch-can.312623/
    https://www.tacomaworld.com/threads/oil-catch-can-install-guide.231227/
    Russtoy[QUOTED] likes this.
  12. Oct 28, 2015 at 5:50 AM
    #132
    DougsGraphics
    DougsGraphics Duck Hunter!
    Doug
    Northern New Mexico
    2015 Pyrite Mica DCSB TRD OR
    3" Revtech Level, ARB Deluxe Bull Bar front bumper with WARN 9.5XP Winch and KC Pro-Sport LED Driving Lights, black Diamond Back HD tonneau cover, 4 cameras through Entunes display with capacity for two more, LED interior lights with map lights tied to dome, Bussman auxiliary fuse/relay box with 100 amp breaker/disconnect under hood.
    Thanks for the attempt, OP. When I get some time, I will get around to buying one of these and installing it. For now, my weekends are filled with duck hunting (and completing my long list of honney-do's)...:thumbsup:
  13. Jan 9, 2016 at 11:54 AM
    #133
    Jayjayb96
    Jayjayb96 Well-Known Member
    Jay
    SF Bay area, Ca
    02 4runner
    Sc'd. Arb rear locker, compressor, toytec coilovers w/eibach 600 lb springs, ome 890s, lc oem shocks, toytec panhard bar drop, ss extended brake lines, spidertrax 1.25" spacers, 275 70 bfg ko2 on scs sr8s, deckplate, isr, andymod 2.0
    I would definitely be interested so add me to the list if there even is one haha
    Im sure if we added this on t4r.org we'd have more interest unless this is a tw only gb
