Add transmission fluid thru dipstick tube?
Discussion in '4 Cylinder' started by MGtaco2.7, Jan 20, 2015.
  1. Jan 20, 2015 at 3:10 PM
    MGtaco2.7
    MGtaco2.7 [OP] MEMBER
    NW Ohio
    18 DCSB 4X4 SR5 Silver Sky Metallic V6 AT
    Just curious if i can add the transmission fluid thru the dipstick tube on my taco? If so, will it take forever or is there another place? Thanks TW.
  2. Jan 20, 2015 at 3:12 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    If you have a 2012, you don't have a dipstick tube.
    Have to pump it in the side of the transmission.
  3. Jan 20, 2015 at 3:31 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Nobody (2nd gens) has a dipstick tube for the transmissions.
    OP - PLEASE PLEASE do not pour automatic transmission fluid down the regular oil dipstick tube.
  4. Jan 20, 2015 at 3:36 PM
    iitywygms
    iitywygms Well-Known Member
    Norcal
    4x4
    Not true.
    I have a dipstick for the automatic. 2011 4 banger auto.
    OP. I poured it through the tube. Just go slow it is not to bad.
    BillsSR5 likes this.
  5. Jan 20, 2015 at 3:39 PM
    MGtaco2.7
    NW Ohio
    Are you serious? What is the tube with the clasp looking thingy that sits on the right side of engine back close to firewall, if your standing at the front of truck?
  6. Jan 20, 2015 at 3:40 PM
    MGtaco2.7
    NW Ohio
    Shewwww glad someone else has one, it is a 2012 4cyl. I was hoping it was the trans tube. Thank you
  7. Jan 20, 2015 at 3:51 PM
    gearcruncher
    Canadain bumper technician
  8. Jan 20, 2015 at 3:52 PM
    MGtaco2.7
    NW Ohio
    Thank you so much. This is my 1st tacoma and this is all new to me. And yes if i remember right the tube handle is orangish red. Thank for your help
  9. Jan 20, 2015 at 4:13 PM
    MGtaco2.7
    NW Ohio
    Looks identical to mine. Thanks for checking so fast. Gonna drain and fill tomorrow
  10. Jan 21, 2015 at 1:51 PM
    Indy
    Indy Master of all I survey.
    No manual I've seen in any vehicle has a dipstick tube. They use a gear oil, not tranny fluid.
  11. Jan 21, 2015 at 2:42 PM
    Janster
    Jandy
    Lancaster, PA
    My 4.0L doesn't have one.
  12. Jan 21, 2015 at 2:47 PM
    MGtaco2.7
    NW Ohio
    Apparently the 4.0 auto do not have a dipstick and use the WS tranny fluid. The 4 cyl auto has a dipstick and uses the type lV tranny fluid.
  13. Jan 21, 2015 at 2:49 PM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    Always wondered why Toyota made the 6 cyl as a sealed tranny (no dipstick) but not the 4 cyl.
    Not sure if it is the 4 vs 6 cyl Camry, but my buddies tranny is sealed as well.
  14. Jan 21, 2015 at 2:51 PM
    gearcruncher
    You are correct .
    If you go back to post #9 , this will all be explained in detail .
  15. Jan 21, 2015 at 2:58 PM
    Clearwater Bill
    Billy
    Largo Florida
    you are correct. But the OP has a 2.7.
    Check out post 9.
  16. Feb 22, 2015 at 12:14 AM
    robran
    robran Member
    moulton al
    2012 regular cab 2.7 liter
    how many quarts does yours hold in the pan?
  17. Feb 22, 2015 at 5:24 AM
    MGtaco2.7
    NW Ohio
    I drained the fluid from the pan, guess most don't recommend "flushing" the trans, so I will be just draining and replacing every 30,000 or so, 4 qrts came out and 4 qrts went in. Now the level is just a hair below the upper full mark when warmed up.
  18. Mar 25, 2019 at 11:00 AM
    nyg052003
    nyg052003 Nyg052003
    Charleston, SC
    04 Tacoma TRD Offroad SR5 4x4
    hey did you add thru the tube? I have an 04 3.4 V6 auto and I need to drain and fill mine maybe today. I do not have a means right off top of my head to pour from side so filling through dipstick tube would be much better for me
  19. Mar 26, 2019 at 3:24 AM
    Dens71TA
    Dens71TA Well-Known Member
    2014 SR5 ACLB 4x4 2.7L A4
    You can purchase a plastic funnel specially made for filling through the transmission dipstick tube at most auto parts stores.
  20. Mar 26, 2019 at 6:39 AM
    nyg052003
    nyg052003 Nyg052003
    Charleston, SC
    I actually used a long tip funnel that I had. It's about a foot long, the actual stem and fit right in the tube. I was just skeptical as to how much I could pour steadily as to it maybe backing up but it seem to work fine even if you pour at a fast rate.
    How often do you change your fluid? Mine is an 04 auto 3.4 4X4 163 k miles. I bought it Jan 2015 with 113 k and this is the first time changing it.
