ADD front diff?
Discussion in 'Technical Chat' started by adamw, Jan 9, 2012.
  1. Jan 9, 2012 at 11:35 PM
    adamw
    adamw [OP] Well-Known Member
    sunnyvale, CA
    06 prerunner-> FJC 4x4 swap
    on the 2nd gens, what does it stand for and how exactly does it work? I know its like the opposite of manual locking hubs but I could be wrong? I'm just trying to figure out how that system works, if anyone know anything i would appreciate it, thanks
  2. Jan 10, 2012 at 8:18 AM
    Hard
    Hard Well-Known Member
    H
    4X4X4
    Automatic Differential Disconnect. It is a motor on the second gen, and vacume actuated on the first gen tacomas. It disconnects the passenger side axle so that the differential and driveshaft are not under laod. It leaves the drivers side axle connected to the differential so the spider gears will continue to spin on that side but there is no load on the drivetrain.
    If you need more info on what the spider gears are there is a thread that explains how a differential works up above.
  3. Jan 10, 2012 at 9:10 AM
    adamw
    sunnyvale, CA
    okay I didnt realize that much stuff was going on. I thought 4wd was only controlled by the transfer case? how can you get around this system if you want to use an fj t case? do you add another switch that would turn on the add?
  4. Jan 10, 2012 at 10:28 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    The ADD (automatic disconnecting differential) allows one to shift on-the-fly into and out of 4WD (High). It was on the First Gen Tacos as well... It replaced automatic locking hubs which required driving in reverse to fully unlock.
  5. Jan 10, 2012 at 10:30 AM
    Hard
    H
    4X4X4
    You can create a circuit to control the ADD motor by a switch. If you search into the FJ case swap there are some wiring diagrams to follow. OR.......... you could SAS and have manual hubs.
  6. Jan 10, 2012 at 10:32 AM
    98tacoma27
    Ben
    Not Beech Creek
    You don't even have a transfer case or front diff according to your profile.
  7. Jan 10, 2012 at 10:40 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Or fit an FJ cruiser manual case and put in an ADD switch.
  8. Jan 10, 2012 at 11:20 PM
    adamw
    sunnyvale, CA
    yeah that's right, that's why I'm looking into this to see if it is even remotely possible to do a 4x4 swap in a second gen prerunner and how hard it would be, which seems like slim and very.
  9. Jan 11, 2012 at 5:19 AM
    98tacoma27
    Ben
    Not Beech Creek
    With time and $, anything is possible.
  10. Jan 11, 2012 at 10:47 AM
    adamw
    sunnyvale, CA
    yeah but if I SASd my truck it would be the biggest waste of a SAS here on TW just saying
  11. Jan 11, 2012 at 11:11 AM
    adamw
    sunnyvale, CA
  12. Jan 11, 2012 at 11:24 AM
    98tacoma27
    Ben
    Not Beech Creek
    I'd bet the other way around.
  13. Jan 11, 2012 at 11:28 AM
    98tacoma27
    Ben
    Not Beech Creek
    You said stock parts......not new parts.
    No (or very little) fab work. You could pretty much bolt one in.
  14. Jan 11, 2012 at 11:30 AM
    98tacoma27
    Ben
    Not Beech Creek
    You could probably change the housing in the truck, but I never looked into it.
  15. Jan 11, 2012 at 11:37 AM
    98tacoma27
    Ben
    Not Beech Creek
    Very true.
  16. Jan 11, 2012 at 12:05 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    ...or unbolt extension :thumbsup:
  17. Jan 11, 2012 at 12:11 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    The easiest way to convert your PreRunner into a 4x4 is trade it in for one. You're going to be spending way more trying to convert it than just trading in your PreRunner for a 4x4 and just paying the difference.
  18. Jan 12, 2012 at 12:09 AM
    adamw
    sunnyvale, CA
    I would rather not trade in bc of the good deal i got otherwise I would have bought 4x from the start and trading in would be more expensive then doing the swap the other reason for doing the conversion over trade in is having the manual t case from and fj. I have had 3 different occasions where the tacoma t case decided to take a crap at the worst time. SAS would be ideal, but i would never use it to its full potential IFS would get the job done no problem.
  19. Jan 15, 2012 at 10:45 AM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    I'm one of those. 3-4 60 lb bags of tube sand takes care in snow for me for the last 23 years with 2wd trucks in WI, IA and CO.
    But I don't ski regularly and don't head to the mountains when snow is in the forecast or I'd find myself needing 4wd soon enough.
  20. Jan 19, 2012 at 12:56 AM
    adamw
    sunnyvale, CA
    If I was going to hook up a switch to use the ADD separately what switch would I use. then would it matter putting into 4wd first then switch or the other way around?
