Add a Leaf + Lift block or more leaves?
Discussion in 'Suspension' started by steveo27, Nov 11, 2014.
  1. Nov 11, 2014 at 9:09 PM
    steveo27
    steveo27 [OP] Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Long story short....
    I installed larger tires on my truck finally.
    The truck currently has 5100s up front set at 1.75 with TRD Off Road Springs (1.75" lift). The rear has a Wheelers Progressive 3 leaf add a leaf on a 3 leaf non TSB springs (about 2" of lift).
    The truck has the perfect amount of rake with the suspensions set at its current setting.
    I plan on adding Eibach springs, 1/4" top plate spacers, and Light Racing upper control arms to the 5100s up front to bring them up to a full 3" of lift.
    I would like to bring the rear up about more 1"/1.5" when I do the fronts.
    What would be my best option for the rear? Adding a 1" lift block? Adding more leaves to the spring pack?
    Thanks
    :beer:
  2. Oct 13, 2015 at 5:58 PM
    steveo27
    Pittsburgh
    Finally finished the front lift, now the rear end is all saggy looking bump
  3. Oct 13, 2015 at 6:00 PM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    The cheaper/better than a lift block way would be to put that 3-leaf AAL on a set of TSB springs and leave the overload in with it.
  4. Oct 13, 2015 at 6:01 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    TBD
    I hate lift blocks, so there. I said it.
    I'd go with a new leaf pack.
  5. Oct 13, 2015 at 6:02 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Since no shackle then it looks like a whole new pack.
  6. Oct 13, 2015 at 6:03 PM
    steveo27
    Pittsburgh
    I despise the idea of lift blocks as well. Just weighing my options
    Thats what I was thinking. Unfortunately Im beyond the limit of having the TSB done to my truck and havent had any luck finding anyone sellin TSB springs locally.
  7. Oct 13, 2015 at 6:10 PM
    deeezy
    Dana
    Hawaii
    I don't think you can lift a stock second gen taco with shackles.
  8. Oct 13, 2015 at 6:13 PM
    TACO TX
    Kelly
    Denison ,Texas
    Yea I was just looking and don't see any for a 2nd gen.
  9. Oct 13, 2015 at 6:14 PM
    keahi808
    keahi808 Well-Known Member
    Shane
    Roseville, Ca
    08 DCLB 4x4 Magnuson S/C
    Suspension 5" rcd lift 4" alcan leaf pack LR Ucas Toytec coils #620 Tires 33" cooper stt Rims 18x10 moto metals mo962 Others Oil catch can mod Homertaco satoshi grille Angeleyes headlight 6500k hid w/demon eye mod Prinsu Studio Roof rack w/ 40" Heretic •Performance Magnuson Supercharger AFE Stage 2si ucon ems urd 2.8 stealth pulley urd cam gears urd performance thermostat urd 76mm adapter 5.7L throttle body
    Leaf pack. Do it right the first time
  10. Oct 13, 2015 at 6:16 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    I've been running a one inch block on stock, non-TSB, leafs for a few months now and have not had any issues with it whatsoever. Considering you've invested in some quality parts, it all depends on your budget. A block would be cheap, easy to install, and better yet easy to replace if needed. I'd say run the stock leaf packs/AAL's into the ground and buy an entire new setup. This way you wouldn't be wasting a whole bunch of money if you plan on upgrading in the future. Block's really aren't that bad unless you exceed 2+ inches in my opinion. Id say block or another AAL if I were you.
  11. Oct 13, 2015 at 6:18 PM
    ZachPrerunner
    Southeast TN
    Nothing is wrong with cheaper alternatives if you know the limits to the product. :rolleyes:
    Kssooner likes this.
  12. Oct 13, 2015 at 6:29 PM
    Jakers83
    Jakers83 Well-Known Member
    Jake
    Denver
    2.7 base.
    OME lift. Tires and wanting more
    What's TSB?
  13. Oct 13, 2015 at 6:31 PM
    ZachPrerunner
    Southeast TN
    Technical service bulletin. It's like a recall, but on a smaller scale.
  14. Oct 13, 2015 at 6:33 PM
    Jakers83
    Jake
    Denver
    2.7 base.
    Lol oh ok. Would a Dakar leaf spring help the op? Sorry don't know jack about rear ends
