Add a fuse under dash? Remote on/off amp
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TACOZAC, Oct 17, 2020.
  1. Oct 17, 2020 at 5:13 PM
    TACOZAC
    TACOZAC [OP] Well-Known Member
    2018 OR 4x4
    Hey, which of the fuses under the dash (see picture below) can I “add a fuse” for the remote switch to turn on and off my amplifier?
    what I’ve tried:
    1. “Panel” 5A - but that didn’t work( or it stays on I forget )
    2. AM1 - it’s empty and it stays ON constantly
    I’m trying to find a fuse here that triggers the Amp on for my Sub, only when the car is on or has accessories/audio on.
    Which do you recommend? It’s hard enough to pull these smaller fuses out so I don’t want to keep doing that for trial and error.
    i need to get a multimeter. That’s probably the correct way to go about this
  2. Oct 17, 2020 at 5:56 PM
    Interbeing
    Interbeing A Canadian living in Texas
    Austin, TX
    2020 Tacoma TRD Off-Road 4x4 DCSB AT
    TRD Pro suspension with Headstrong 3 Leaf AAL, DV8 OR front slimline bumper & Engine Skid Plate, RCI OR high clearance bumper, CaliRaised Trail Edition Sliders, Spidertrax 1.25" Wheel Spacers, 265/75 16 GY Duratracs, wrapped the OEM wheels, OR Roof Rack, Extang Exceed Hard top Tri fold tonneau.
    I agree
    TACOZAC[OP] likes this.
  3. Oct 17, 2020 at 6:12 PM
    TACOZAC
    2018 OR 4x4
    I really don’t want to pull the radio out. Any options for this fuse setup?
  4. Oct 17, 2020 at 7:08 PM
    TACOZAC
    2018 OR 4x4
    @Boghog1 I’ll probably just have to pull the radio. I’ve done tranny swaps on my own so I think I got that technical aspect covered. Thought it’s been easier to add a fuse. I’m using the LOC for frequency into RCA cables into my amp. Cheers man
  5. Oct 17, 2020 at 7:20 PM
    TACOZAC
    2018 OR 4x4
    PAC SNI-35 LOC cheap one on Amazon. I use the front right speaker wire in the kick panel to supply frequency to the amp. It works. You were probably curious to why I didn’t already pull the head unit for that. Trying to do less pulling of items.
  6. Oct 17, 2020 at 7:34 PM
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
    Pulling the head unit will take no more than 10 minutes.
    Yank the radio trim and remove four bolts.
  7. Oct 17, 2020 at 8:00 PM
    TACOZAC
    2018 OR 4x4
    Yah lol. It’s not “slow”? Wink wink. #fasttimes
  8. Oct 23, 2020 at 8:08 AM
    TACOZAC
    2018 OR 4x4
    @Boghog1 @slowlane I tapped into the radio White wire (constant 12v) but now my amp stays always on. Is this ok?
    the other option was using the smaller Gray switched ign wire. I’ve hear if you use this eventually the amp could cause the radio to remain on?
    I may switch to the gray wire for now or I was thinking I could run a in line on/off switch on the remote wire when it passes under the driver side kick panel but then I’d have to always remember to not leave it on.
  9. Oct 23, 2020 at 8:41 AM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    P.outlet 15A 3down from the top left of you don’t want to pull the radio. Otherwise like other members said, grey wire for IGN
    Waynebarkr and TACOZAC[OP] like this.
  10. Oct 23, 2020 at 9:08 AM
    TACOZAC
    2018 OR 4x4
    @Boghog1 I may just go gray!! @MESO thanks. Yah I have an add a fuse so I’ll test out the p outlet as I was hoping to use that. Thanks so much.
  11. Oct 23, 2020 at 10:11 AM
    caribe makaira
    Caribbean, Puerto Rico
    On with vehicle on, so amp will be ON also.
  12. Oct 23, 2020 at 11:03 AM
    TACOZAC
    2018 OR 4x4
    @caribe makaira hey thanks. are you suggesting to use either of those 7.5fuses?
  13. Oct 23, 2020 at 11:06 AM
    caribe makaira
    Just the same one that provides juice @ ACC - Gray wire - 7.5A ECU-ACC...so you don't remove the radio or cut the wire while tapping it...
    TACOZAC[QUOTED][OP] likes this.
  14. Oct 23, 2020 at 11:49 AM
    TACOZAC
    2018 OR 4x4
    ... sweet. Saves me from cutting another wire. Cheers guys. Really appreciate everyone’s input
