Add-A-Fuse question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kingston73, Mar 17, 2017.
  1. Mar 17, 2017 at 7:31 AM
    kingston73
    kingston73 [OP] Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    I recently installed an underseat sub and used an add-a-circuit in the fuse box to plug into power and switched power. I bought these before looking:
    https://www.amazon.com/gp/product/B015GYN38A/ref=oh_aui_detailpage_o05_s02?ie=UTF8&psc=1
    and when installing realized the fuses are more like this:
    https://www.amazon.com/gp/product/B00K17A2E6/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=A3TOPXSF99I2AT
    Everything seems to be working well but I'm wondering if I should replace the first set with the second ones? If they plug in and work is everything fine or could there be any potential problems later on?
  2. Mar 17, 2017 at 7:34 AM
    sjwhitaker
    sjwhitaker Today Was A Good Day.
    Jake
    Berea, KY
    2010 DCSB TRD Offroad 6MT - Icon Stage 2 - 285/75/16 Falken AT3W
    You can never have to many fuses. Fuses are way better than burnt down trucks.
  3. Mar 17, 2017 at 7:36 AM
    sjwhitaker
    Jake
    Berea, KY
    Actually upon looking at both of those they look like pretty much the same thing. As long as you have the appropriate fuse and everything is working fine I wouldn't worry.
  4. Mar 17, 2017 at 10:49 AM
    twhalm
    twhalm Well-Known Member
    Denver, CO
    2015 TRD/OR Manual, OME , Dual battery
    Fuses are fuses. As long as you have good contact they will do their job. The only difference between mini fuses and the low profile mini fuses is that the low profile ones are just that.
    The low-profile ones, however, will not fit in a standard mini fuse slot.
  5. Mar 17, 2017 at 11:26 AM
    Ross09
    Ross09 Well-Known Member
    Greeneville,TN
    2009 DCLB base 4x4
    I did the same thing when I was doing an add a circuit for my light bar. Realized it takes the mini fuses. As long as you don't jam a wire underneath an already existing fuse to tap power from it.
  6. Mar 17, 2017 at 1:15 PM
    orezona
    orezona title unspecified
    satan's skillet
    2006 TRD OR DCSB OMGWTFBBQ TL;DR
    WARRANTY VOIDED
    I have a question that's on-topic for this thread I suppose...
    I just got a couple add-a-fuses and I was wondering about the amp rating for dual USB set up? What is the consensus on the max fuse rating for one of these?
    I'm mainly going to use mine (for now) to power/charge accessories like my dash cam, phone and external TPMS.
    Thanks in advance.
  7. Mar 17, 2017 at 1:22 PM
    twhalm
    Denver, CO
    Depending on the type of USB port max amperage rating varies. The newest type-C supports up to 3 amps, but I doubt you are putting those in. USB 2.0 and 3.0 are rated for .5 and .9 amps respectively.
    So mostly likely the most current you will draw is <2 amps. The smallest size most mini fuses come in is 5 amps so I'd just put one of those in.
    Also, make sure you aren't connecting USB ports directly to the cars 12V source. It should have some sort of little box that converts it to the 5V that USB runs on.
    Does that answer your question?
    orezona[QUOTED] likes this.
  8. Mar 17, 2017 at 2:25 PM
    orezona
    satan's skillet
    WARRANTY VOIDED
    YES! Thank you very much... :D
    I'm pretty much putting one of these in.
    Going to hide it instead of getting something to take the place of one of the switch blanks.
    My work has about 50 of them unused and my boss said he didn't care if I "borrowed" one.
    Much obliged.
