Active shutter grill?
Discussion in '4th Gen. Tacomas (2024+)' started by 5nahalf, Apr 11, 2023.
  1. Apr 11, 2023 at 6:05 PM
    5nahalf
    5nahalf [OP] I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    What are the chances the 4th gen gets the active shutter grill like the rest of the hybrid cars?
    A manual control of the active grill would be amazing here in MN to get my 3rd gen warmed up faster.
  2. Apr 12, 2023 at 5:25 AM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    Probably pretty good - the tundra has it
    Junkhead and 5nahalf[OP] like this.
  3. Apr 12, 2023 at 6:08 AM
    5nahalf
    Erik
    Minnesota
    If It does, Im totally going to try to adapt it to our trucks. Just think of how nice that will be to push a button, and get faster heat on those 10 degree days, or the slight bump in mpg while cruising on the highway.
  4. Apr 12, 2023 at 6:14 AM
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    sign me up
    5nahalf[QUOTED][OP] likes this.
  5. Apr 12, 2023 at 8:47 AM
    Lunar Squirrel
    Lunar Squirrel Well-Known Member
    24 TRDOR Hybrid SPF100-Octane
    I believe the NX 350h does not have active shutters so coin toss on whether the upcoming Tacundra will
  6. Apr 12, 2023 at 9:38 AM
    Servingko
    Servingko Well-Known Member
    2022 DCSB OR MT
    As long as it doesn't cover the inter-cooler.
  7. Apr 12, 2023 at 9:52 AM
    5nahalf
    Erik
    Minnesota
    If its going to be like similar cars with it, then it should cover the top 75%, but it will only be closed at start up and on the highway to improve mpg and warm up times.
  8. Apr 12, 2023 at 11:43 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The grille shutter would be cool. The active chin strap on the Tundra is goofy and looks pretty bad.
  9. Apr 12, 2023 at 1:26 PM
    5nahalf
    Erik
    Minnesota
    Just watched a video of it, not going to lie, I kinda like the idea, but that thing would get smashed here in MN.... Also, I like how it has a QR code on the part that sends a person to a video of how to put it in service mode.
  10. Apr 12, 2023 at 1:57 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Like you said, I think it is a bad spot on a truck to put something active. Begging for high repair costs.
    We've had too many cars with subframes that were low and forward enough to contact parking blocks. Brings up familiar feelings.
  11. Apr 12, 2023 at 3:00 PM
    GBourne
    GBourne Just a regular guy
    Grant
    Surprise, AZ.
    23 Ram 1500 Classic
    Dumped the Tacoma, that's all it needed.
    The truck should do this automatically… that’s a huge part of why they were engineered…
  12. Apr 12, 2023 at 3:49 PM
    5nahalf
    Erik
    Minnesota
    Im talking about getting the active shutters and retrofitting them to my 3rd gen. Since I dont have the needed control computers I would just put a switch in to open and close them.
    doublethebass likes this.
  13. Apr 12, 2023 at 3:51 PM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    If it’s going to have a turbo, it’s almost a given it’s going to have active shutters.
  14. Apr 16, 2023 at 2:39 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Likely as mentioned in the turbo, plus they are going to have to find efficiency anywhere they can. I’d think closing them when cooling not needed, would reduce drag?
    Leedehua likes this.
  15. May 19, 2023 at 6:24 AM
    gmtech
    gmtech Well-Known Member
    quad cities illinois
    2016 trd or. 2024 trd OR iforcemaxx!!
    Stock AF
    everyone likes the active grill shutter untill you tag a bird with one on the highway and the check engine light comes on cruise turns off and you have to take it to the shop.. pull the whole front clip off because its behind everything and then its 1k$ job to fix a plastic miny blind on your truck...
    Malvolio likes this.
  16. May 19, 2023 at 7:09 AM
    5nahalf
    Erik
    Minnesota
    How often are you hitting birds that its really a concern?
    Herniator and doublethebass like this.
  17. May 19, 2023 at 7:41 AM
    gmtech
    Stock AF
    its just an instance. chevy has been using grille shutters for a while now and they break more often than you think.. its just one more reason for the check engine light to come on. i know its a toyota so it will probably be more robust. but just somthing to think about.. 3rd gen has all the room in the world to mount stuff behind the grill. maybe not so much any more.
  18. May 19, 2023 at 8:21 AM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Still probably cheaper than replacing the AC condenser from a bird smacking it.
