Access cab weather seal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by glwood6, Jan 2, 2019.
  1. Jan 2, 2019 at 9:43 AM
    glwood6
    glwood6 [OP] Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    Has anyone ever replaced the door weather seal (rubber seal all the way around both doors) on a 2nd Gen Tacoma access cab? I would like to hear about that if you did, as in, where you got the seal, and what the process involved.
    Thanks.
    MuddyJackson likes this.
  2. Jan 2, 2019 at 11:21 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Have you used anything to clean/soften them up?
  3. Jan 2, 2019 at 11:27 AM
    Maggot61
    Maggot61 Well-Known Member
    Jose
    Sky Valley, CA
    2005 Tacoma Prerunner 4.0L
    "If I'm gonna die, I'm gonna die historic on the fury road!"
    I did mine, both Driver and Passenger doors about 4-5 months ago. I just ordered the door seals from a Toyota dealer online (i think it was out in the Midwest somewhere) since the price for these here in California were way higher. Replacement is straight forward, you just pull the old ones off along with the clips and install the new ones which comes with clips.
    Jimmyh and PzTank like this.
  4. Jan 2, 2019 at 11:50 AM
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    So it did help.
  5. Jan 2, 2019 at 12:32 PM
    CaTaco101
    CaTaco101 Well-Known Member
    California
    '13 TRD Off-Road PreRunner
    Did the cold weather squeak go away? How much should we expect to pay if ordered online?
  6. Jan 2, 2019 at 12:41 PM
    Thebubble
    Thebubble Well-Known Member
    Southern California
    2006 GX470
    2009 Pre-Runner, V6: Totaled 2014 Tacoma 4x4, 5 speed, 4 Cylinder: Totaled 2000 Tacoma 5 Lug: Sold 2006 Lexus GX470: Wheeling!!!!!!!!!!!!!!!!!!!!!!!
    If you got squeaks - try heavy duty silicone ( not the caulking. ) My squeaks like crazy and i'm at a point where Vaseline is my next option... all you need is grease that won't eat up your seals... just don't sloop it on to where it gets on your pants / clothes.....
  7. Jan 3, 2019 at 8:54 PM
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    I've tried a couple of products. Still, my driver side door seals 'chatter' (like tacky or something) at certain temperatures, drives me nuts. Doesn't always do it, but when it does, it's right in my ear. I thought new seals might help.
  8. Jan 3, 2019 at 8:57 PM
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Access cab? Seals on both doors on each side?
    Maggot61[QUOTED] likes this.
  9. Jan 4, 2019 at 6:21 AM
    mikalcarbine
    mikalcarbine Well-Known Member
    Phoenix, AZ
    2015 AC TRD OR
    My AC squeaks every once in a while. When I detail my interior I use aerospace 303 on all of the door seals and I clean and wax the painted part of the door jams, keeps it quiet for a pretty good amount of time until it gets dirty again, worth a try! I'll probably replace my front door seals eventually to fix the kazoo sound on windy days
    BlkDakDave likes this.
  10. Jan 4, 2019 at 9:27 AM
    Maggot61
    Jose
    Sky Valley, CA
    Yup and yup, the only one i forgot to replace was this one circled in blue. My trucks an 05' though and live in the desert, i've never done anything to them like adding silicone. The only time they squeak is when hitting dirt my reason for replacing was wind noise, it got really bad.
    Edit: on the front doors you will need to unbolt the door check because the seal is all one piece.
  11. Jan 4, 2019 at 9:47 AM
    CaTaco101
    California
    What was the cost of the seals?
  12. Jan 4, 2019 at 10:00 AM
    Maggot61
    Jose
    Sky Valley, CA
    honestly i don't remember, this was 4-5 months ago. I'll see if i can find my receipt...
    CaTaco101[QUOTED] likes this.
  13. Jan 4, 2019 at 10:02 AM
    Thebubble
    Southern California
    2006 GX470
    Honestly, if you Google the part number- you'll get a price..... unless your a body shop where you can a discount... but honestly, the online price is close to body shop pricing....
  14. Jan 4, 2019 at 10:50 AM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Use this on your seals - https://www.napaonline.com/en/p/BK_7651351
    Works great, no wind noise, no squeaks.
    Only drawback - on my white truck, it left a yellowish stain where the seals hit the truck. You can only see it when the doors are open. I think I will try to clay bar it off - but it is not a high priority item.
  15. Jan 4, 2019 at 12:47 PM
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    I don't think staining will be an issue on magnetic gray metallic, but I could be wrong...did you apply liberally, wipe off, apply sparingly, or what?
    For $7, I don't think I can lose by trying this before ordering new seals...thanks!
  16. Jan 4, 2019 at 12:50 PM
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    I don't have my truck with me today...unbolt from the door or the body?
  17. Jan 4, 2019 at 1:53 PM
    Scott B.
    Scott
    Georgia
    True - on MGM I don't think the slight yellowish stain will be seen.
  18. Jan 4, 2019 at 1:59 PM
    Maggot61
    Jose
    Sky Valley, CA
    unbolt from the body, it's just 2 bolts.
  19. Jan 4, 2019 at 7:24 PM
    CaTaco101
    California
    Honestly don’t have the part number to google...
  20. Jan 8, 2019 at 9:31 AM
    Maggot61
    Jose
    Sky Valley, CA
