ACC Wire in Kick Panel
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Frogsauce, Dec 9, 2016.
  1. Dec 9, 2016 at 12:15 PM
    Frogsauce
    Frogsauce [OP] Well-Known Member
    Chesapeake Bay
    16 TRD Offroad
    I'd like to find a wire under the kick panel that is only hot when the truck is on accessory (for a relay). I've been hunting around with a test light for an hour. So far no luck, all those wires seem to be always hot. Even the trailer brake pig tail is always hot.
    Anyone found a good acc source under the kick panel?
  2. Dec 9, 2016 at 4:28 PM
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    Kick-panel, no, but I haven't really looked there, either. I did find an ignition-switched fuse in the main fuse box, though. (It was a 10amp, top-left corner if looking at the fuse box from the driver's side fender.) Easy enough to run a wire from there through the firewall's existing grommet (did just that).
  3. Dec 9, 2016 at 4:31 PM
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
    I might have to do that unless anyone else can find one. In my 2009 I used the cig lighter. But that wire is now always hot under the kick panel. I would have to pull the dash apart and run a wire from there.
  4. Dec 14, 2016 at 5:28 PM
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
    I'm thinking about running a wire around from the shift lights in the center console (PRNDS lights). Those are ignition switched. But that's a long way around. I would have thought that empty fuse slot under the dash would be ignition swithed, but no, always powered.
  5. Apr 27, 2017 at 6:49 AM
    waydago
    waydago Well-Known Member
    Jack
    Jensen Beach, FL
    '16 Taco, TRD-OR, DCSB, SSM
    TRD Pro Exhaust, aFe Filter, Hard Tonneau, Predator steps, Pro Grille, Pro Fogs, Pro Badges, Pro Skid, Decal Inserts, H9 headlight swap, tailgate light bar, !7 in 4-Runner Pro wheels, 265/65-17 Falken Wildpeaks, AVS Bug shield and window shades, WeatherTechs, Sill protectors, pistol holster, Home Link mirror, Power tailgate lock, Redline Tuning hood struts, Caliper covers, Rigid Radiance light bar.
    This thread has not been active for a while and it's probably too late for any meaningful input but a good ignition switched source I found is also under the main fuse-relay panel. I used it for my Rigid Radiance light bar. Taking the fused light bar wire that would have gone directly to the battery + terminal I ran it through a 1/8 inch hole I drilled at the rear of the fuse panel (top right corner if standing over the driver's side fender) and T-tapped it to the blue wire shown. It provides a good ignition switched source under the hood for future mods as long as they are fused correctly. I also ran a spare 4 wire cable into the cab when I ran my light bar cabling so it can also be used inside the cab as well.
    MountainManGuy, urbncby and muddydog1 like this.
  6. Jul 15, 2018 at 1:16 PM
    muddydog1
    muddydog1 Member
    17 Tacoma OR
    Thanks for the tip! Just ran a gang switch system on my ‘17 and used your method. Super easy and everything works great!
  7. Apr 5, 2021 at 10:29 AM
    MountainManGuy
    MountainManGuy Well-Known Member
    Colorado
    2019 Toyota Tacoma TRD Off-Road DCSB
    Bringing this back from the dead, but, if anyone is looking to install a switch pros setup, that blue wire works great as the accessory 12v wire. Thanks waydago!
  8. Jun 26, 2021 at 10:16 AM
    432Cherries
    432Cherries Member
    Carrie
    2017 Black Toyota Tacoma SR5
    So that blue wire is a not always hot wire because I'm trying to run or install these damn lights on my headlights pictures will be at the bottom of this and also the instructions cuz I'm completely confused and I'm hoping I'm doing this right
    https://www.silverholder.com/product/led-flow-type-car-signal-light
    This is what I'm trying to install and then this would be the instructions that came along with it but I'm still confusedreceived_4087924451275971.jpg
  9. Jun 26, 2021 at 2:45 PM
    caribe makaira
    Caribbean, Puerto Rico
    If your Tacoma has the DRL activated, then those added LED's would be ON when you tap into the turn signal wire at the lights. Is that the function you seek?
  10. Jun 26, 2021 at 9:02 PM
    432Cherries
    432Cherries Member
    Carrie
    I don't want them on all the time I only want them on when turn on my turn signals. Whatever I did earlier somehow worked because they're on but they're on all the time I did attach the red wire to the blue wire that somebody had posted about on this post at a later date but the LEDs are on all the time unless I turn them off with the remote
  11. Jun 26, 2021 at 9:52 PM
    caribe makaira
    So you'll need to turn OFF the DRL feature of the TURN signals so they only function as TURN signals only, since you're going to tap the turn signal wire.
