AC won't stay on :(
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 5nahalf, May 2, 2020.
  1. May 2, 2020 at 6:31 PM
    5nahalf
    5nahalf [OP] I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Took the truck out for a drive today and noticed the ac was off, So I turned it on and it turned itself off again :( Every time I turn it on, it turns itself off again.
    Ive done a bunch of searching, and not much comes up except this video that shows my exact problem. He is saying that there is a plug behind the glovebox for the "mag clutch rotation sensor". This does make some sense because I was doing changes for my wiring to my mids in the dash.
    So, does anyone know where the "mag clutch rotation sensor" plug is? or what it looks like, or maybe some color codes on the wires? Id love to just fix this myself rather than let toyota fumble through it and then in the end blame me and charge me.
    This is not my video, but my truck does the same thing.
    GQ7227 likes this.
  2. May 2, 2020 at 8:06 PM
    5nahalf
    Erik
    Minnesota
    And now its working again....
    I took apart the passenger side of the dash, wiggled everything, still wouldnt turn on. Went and got gas and a car wash, wasnt working for about a mile after getting gas, then I turned it on and it stayed on. Guess its probably not something I did. Im going to keep an eye on it and if it starts acting up again I guess its dealer time.
    GQ7227 and Harperspop like this.
  3. May 2, 2020 at 8:11 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Mag clutch rotation sensor sounds like it would be on AC clutch on the compressor. Maybe unplug it and see if its corroded.
  4. May 2, 2020 at 8:25 PM
    5nahalf
    Erik
    Minnesota
    Yeah, I think there are 2 plugs for it, one under the dash where it connects to the control module and one where it plugs into the compressor. Guessing the one on the compressor side has the issue seeing as how it started working again after gas and car wash... perhaps water dripped into the plug and completed the connection. Guess ill find out in the morning when I can get under there with some daylight.
    GQ7227 and 0xDEADBEEF[QUOTED] like this.
  5. May 2, 2020 at 8:39 PM
    Dc2tacoma
    Dc2tacoma Well-Known Member
    That suck brontosaurus balls.
    Chew likes this.
  6. May 3, 2020 at 9:38 AM
    5nahalf
    Erik
    Minnesota
    Just checked the AC again this morning, off again :(
    GQ7227 likes this.
  7. May 3, 2020 at 10:13 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    I think what you're after is the "A/C lock sensor".
    From the mag clutch it goes to connector IH1 and then to connector A14 at the A/C amplifier.
    I tried finding that connector(IH1) for you in the wiring diagrams; no luck.
    @caribe makaira
    Skydvrr likes this.
  8. May 3, 2020 at 10:33 AM
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
    The mag clutch in some applications can come out of adjustment. If you're very careful you can tap the clutch when it's off and it will engage. If it does, it needs adjustment if it's adjustable. It's a mechanical movement so try it to isolate the problem. BE CAREFUL..TAP LIGHTLY. LOL
    Zim
  9. May 3, 2020 at 10:49 AM
    5nahalf
    Erik
    Minnesota
    Like tap on it when the engine is running or engine is off, tap, then turn on engine?
    What I find weird is that the time it stays on is not the same each time, it usually shuts off the second cold air starts to blow. I read there is a "ice" sensor for the system that shuts off the system.
    GQ7227 likes this.
  10. May 3, 2020 at 10:59 AM
    Tacman19
    Dave
    Mid Missouri
    19 Tacoma SOLD
    No while its running, turn on A/C on and if the compressor is not running, tap the clutch. Don't get close to the belt. Tap it lightly. It moves in and out to engage the compressor. A magnet "sucks" the clutch into the compressor to pump the R134 (freon).
    Zim
  11. May 3, 2020 at 11:01 AM
    Tacman19
    Dave
    Mid Missouri
    19 Tacoma SOLD
    Yeah could be a high/low pressure switch, or a relay going bad or any number of things. Is this a digital climate control system? Never mind on the digital, just saw the knobs..lol
    Zim
  12. May 3, 2020 at 11:40 AM
    GPatriot
    GPatriot Well-Known Member
    Cincinnati, Ohio
    2016 Black Tacoma Sport 4x4 V6 DCSB AT Loaded
    KDMaxPro 10.0, OME 2" Med Duty lift, RCI Sliders, RoofRack, Skid Plate, etc.
    Mine did the same thing a year or so ago but it was under warranty at the time. It was the AC clutch.
    5nahalf[OP] likes this.
  13. May 3, 2020 at 11:48 AM
    GPatriot
    Cincinnati, Ohio
    This is from my service history:
    CMPRSSR W/ MGNETC CLTCH ASSY COMB: MAGNETIC CLUTCH ASSY
    ~|~CUSTOMER STATES THAT THE A/C WILL GO OFF ON ITS OWN WHEN USING THE A/C , IT DOES NOT HAPPEN ALL THE TIME
    Here's what they replaced:
    COMPRESSOR ASSY - 8832004070 (1)
    CLUTCH ASSY, MAGNET - 8841004070 (1)
    SPACER, COMPRESSOR - 8831704010 (1)
    RING, COMPRESSOR SNA - 8836504020 (1)
    RING, COMPRESSOR SNA - 8836504010 (1)
    CLIP - 9008046327 (5)
    No problems since.
    Skydvrr, stealthmode and 5nahalf[OP] like this.
  14. May 3, 2020 at 11:57 AM
    5nahalf
    Erik
    Minnesota
    I got a appointment with the local shop tomorrow at noon, hoping its a quick fix because I have a a retaining wall to build this week and I need my truck.
    GQ7227 and shakerhood like this.
  15. May 3, 2020 at 12:03 PM
    5nahalf
    Erik
    Minnesota
    And now it’s working again... I’m car ac certified, but that’s on cars from 15 years ago.... this is over my head. I’m going back to my 1990 and older cars.
    This is the newest car I’ve worked on, prior to that the newest was 2008
    GQ7227 and Tacman19 like this.
  16. May 3, 2020 at 12:18 PM
    5nahalf
    Erik
    Minnesota
    I think I’ve narrowed it down to the ac compressor, I had sprayed it with the hose this morning, it didn’t work for a bit, but now is working. The only pattern I am seeing is getting the compressor wet makes it work after a little bit of sitting.
    GQ7227 likes this.
  17. May 3, 2020 at 12:44 PM
    mike2810
    mike2810 Well-Known Member
    Arizona - Rim Country
    had 06 Sport 4x4 , now 2016 Nissan Pro 4x
    Read your other posts. Hope that since you sy y
    Hope it is not working when you get to the local shop. If it is working, they will just say can't duplicate the problem.
  18. May 3, 2020 at 1:13 PM
    jetfishn
    jetfishn Well-Known Member
    Could be as simple as low on freon
  19. May 3, 2020 at 3:14 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Maybe you are low on freon.
  20. May 3, 2020 at 3:38 PM
    5nahalf
    Erik
    Minnesota
    Could be, but its odd that by getting the ac compressor wet it works.
    GQ7227 likes this.
