Ac vent leaking water
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Travis804, Jul 17, 2019.
  1. Jul 17, 2019 at 2:50 PM
    Travis804
    Travis804 [OP] Active Member
    Travis
    2018 white TRD Sport Toyota Tacoma
    None
    Toyota Tacoma ac vent leaking water after I turn off the ac ? What can it be?
  2. Jul 17, 2019 at 3:02 PM
    ryan760
    ryan760 Well-Known Member
    Your AC vent is leaking water? That makes no sense dude. Do you mean water is leaking out of the bottom of your dash onto the floor, or the drain tube on the outside of the truck is dripping water?
    Chew, Travis804[OP] and dustin19d like this.
  3. Jul 17, 2019 at 3:07 PM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    If there is water on the ground outside, it is normal.
    If it is water on the passenger floorboard and it has been really humid and the ac was going a long time, it may also be sort of normal.
    If there is water on the floorboards and it isn't crazy humid and you haven't been running it all day, the drain may be plugged and the water is backing up into the cab.
    Or there is a leak from something else...
  4. Jul 17, 2019 at 3:18 PM
    Scott17818
    Scott17818 Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
    Drain tube leaks water it's the condenser working, and extracting moisture from the cabin air. if you are refering to water leaking in the cabin, then you most likely have a blocked drain tube, or cowl vent drain blockage.. use a coat hanger and poke up in through the drain under the passenger side if water and debris comes out, its clogged, and you probably need to drop the airbox, or get a small vacuum nozzle through the cabin filter port (behind the glovebox), and suck up as much debris as you can. otherwise this involves either removing the airbox, or at least the blower motor to clean out the airbox (havent dug into the tacoma that far yet,, so I am unsure about this one).. but first bet would be to clean out the cowl...
    ryan760 likes this.
  5. Jul 17, 2019 at 3:22 PM
    Travis804
    Travis
    None
    Water comes out the vent when I turn off the ac
  6. Jul 17, 2019 at 3:25 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    dre5491 likes this.
  7. Jul 17, 2019 at 3:29 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Exactly which vent?
    ryan760 likes this.
  8. Jul 17, 2019 at 3:32 PM
    ryan760
    The dash vents?? If so that's a new one on me... maybe stop driving underwater.
    dre5491 likes this.
  9. Jul 17, 2019 at 3:40 PM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    No, No. Air gun or a shop vac is all you need.
    https://www.youtube.com/watch?v=DfXyo7a2F9A
    https://www.youtube.com/watch?v=wZ6oupFWKoM
