AC Outlet in the bed....115v??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jmettx, Jan 20, 2013.
  1. Jan 20, 2013 at 2:40 PM
    jmettx
    jmettx [OP] Active Member
    2005 TRD V6
    Hey guys,
    I was doing some maintenance on my 05 TRD V6 today. I rarely use the 115v AC outlet that is in the bed, so I thought I would put my multi-meter on it to make sure it still works. It works, but only registers 105 volts. Engine is running, interior AC switch lights are on (both of them...400w), but still only getting 105 volts. Is that normal for this truck? Any thoughts? Thanks.
  2. Jan 20, 2013 at 2:47 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Hey, if it's only 105v you get an extra 0.4a out of it. :notsure:
  3. Jan 20, 2013 at 3:39 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    im no electrician, but i would think that to be fine to run stuff designed to run on houshold electricity. which varies anyways, and frustrates me at work, hey bro you have a 110v houshold adapter? no mines 120v and the box says 115v. . . . . . JUST PICK ONE!!!! SO MANY VOLTAGES!!! 110=115=120, 230=240, 270?, 460=480
    sorry i would think it to be ok, plug something in and see if it smokes. . . .thats how i roll lol
  4. Jan 20, 2013 at 5:52 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Yeah but where can I get an adapter to run my 110v fan in my 220v outlet? Actually heard at a Home Depot after the customer got done describing the outlet and the HD monkey telling the customer it's a 220v outlet. Care to describe phases?
  5. Jan 20, 2013 at 5:59 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Hmmmm, never tested mine. Now I'm curious. I've never had an issue, if that's all mine puts out also. I have used it for my dremel, no issues, I also have a plug installed in my cab and use it to charge my phone all the time, and my son charges his DS with it, and also never had an issue. When I installed the plug, I used my dremel to test it, LOL, cause it was there, instead of digging out my tester. I'll have to check mine out now to see.
  6. Jan 20, 2013 at 6:01 PM
    jmettx
    2005 TRD V6
    Thanks. Let me know what your meter reads after you check it out. Appreciated.
  7. Jan 20, 2013 at 6:04 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    I'll try to get out there tomorrow, see what it reads, and get back to you.
  8. Jan 20, 2013 at 6:20 PM
    JKD
    JKD Well-Known Member
    Maybe it isn't pure sine-wave output. That could affect the measured voltage.
  9. Jan 20, 2013 at 6:50 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    It isn't a pure sine wave. Even then you have by standard 10% plus or minus...
  10. Jan 20, 2013 at 7:15 PM
    Failure2Comply
    Failure2Comply Old HVACR Tech
    Virginia, USA
    05 Access Off Road TRD/SR5
    Power companies try to regulate the voltage as close as possible to spec, they have to constantly alter the volts up and down to get an average for the day. This is why when you look at a piece of equipments voltage rating it gives you a range that it will operate at. Sometimes with you meter you might see 110v, 112v, 115v, 120v, 124v, etc. All still within the electrical communities allowable voltages for a certain class of equipment. And 270v is matched with the 460-480 range.
    In case anyone is interested, you can tell the power coming into a building by looking at the transformer configuration on the pole outside the building.
    1) Transformer on the pole = 208/230v 1 phase
    2) Transformers on the pole = 240v 3 phase
    3) transformers on the pole = 208 or 480v 3 phase depending on how they are tapped.
    And yes, you can run a 110v fan on 220v, it won't run long, but it will be fast. :D
  11. Jan 21, 2013 at 10:55 AM
    Failure2Comply
    Virginia, USA
    I checked my truck today with my Fluke 902 meter and with the truck idling I get 118.1 vac . It would fluctuate between 118.1 and 118.2 vac.
  12. Jan 21, 2013 at 7:01 PM
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    I ran a 208/230v fan on 460v once. Wasn't faster... :eek:
  13. Jan 22, 2013 at 6:05 PM
    maykevin5
    maykevin5 Well-Known Member
    Kevin
    Carbondale Illinois
    2012 Tacoma SR5
    3 inch lift, stainless steps, JL/Focal audio sound system
    Power inverter voltage drops when there is no load. In order to turn on or "activate" the inverter, you must have some load on it. Try plugging a 75watt light into it and pull out the plug a little and test the voltage with the light attached.
  14. Jan 22, 2013 at 11:43 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Correct ^^ AC motor speed is determined by frequency ( 60 Hz ) and motor windings.
  15. Jan 23, 2013 at 4:33 AM
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    It's fine.
  16. Jan 23, 2013 at 4:55 AM
    gearcruncher
    Canadain bumper technician
    Not to get off subject here but I have a power monitor in my home . You can see the voltage fluctuating . Sometimes it drops far below 100 volts and some times it goes as high as 140 . Not worried about the undervoltage ,but an overvoltage can do some nasty damage to exspensive electronics and is why I have such a critter placed on my incoming hydro line .
    Hydro always tells you they send clean voltage to your home . Do not beleive them .
  17. Jan 23, 2013 at 8:47 AM
    Failure2Comply
    Virginia, USA
    I was only joking. :)
