AC only works on High...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ac41233, Apr 1, 2011.
  1. Apr 1, 2011 at 6:06 PM
    ac41233
    ac41233 [OP] Member
    Al
    Fullerton, CA
    2005 4dr PreRunner TRD Sport V6 4.0L 6cyl
    My AC has been acting up lately. It works normal sometimes. But most of the time, it only blows cold air on High... If I try to switch the control to Medium High, Medium Low or Low, it doesn't work at all. It blows a little bit of air, but nothing cold or with any force.
    It's starting to get hot here in SoCal, and my lady doesn't like it when I'm blasting that AC on High all the time... Hey, I'm not gonna suffer, just because she's getting too cold. LOL
    Is there a HVAC filter that may be clogged up? Or is this something more related to a malfunctioning switch? Someone at my work said it might be something called a climate control unit that is going bad...
    I drive a 2005 PreRunner Double Cab 4.0Lit V6.
  2. Apr 1, 2011 at 6:08 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
  3. Apr 1, 2011 at 6:11 PM
    ac41233
    ac41233 [OP] Member
    Al
    Fullerton, CA
    Thanks Whippersnapper02. That was quick... Is that Blower Motor Resistor easy to change out. And if so, where is it?
  4. Apr 1, 2011 at 6:12 PM
    NelsonTacoma
    Tucson, AZ
    If you read the thread in the link I posted it gives you step by step instructions on how to replace it.:)
    ChemDawg likes this.
  5. Apr 1, 2011 at 6:15 PM
    ac41233
    ac41233 [OP] Member
    Al
    Fullerton, CA
    Thanks for the welcome, NelsonTacoma... I checked out that sticky/link, and it sound exactly what's going on with my truck. And, it sound easy to replace this resistor.
    Man, this forum is great... a couple responses and quick answers to my problem.
  6. Apr 1, 2011 at 6:28 PM
    ac41233
    ac41233 [OP] Member
    Al
    Fullerton, CA
    NelsonTacoma, is that a picture of your truck? Nice Truck! I have the exact same truck, same color, same wheels, same everything...
    I'm wondering if it's better to get that resistor from the Toyota dealer, or from an AutoZone? I know any auto parts store will be way cheaper, but I've always tried to use genuine Toyota parts. And, for anything electrical, that might be the wise choice.
  7. Jun 4, 2017 at 4:02 PM
    atexas70schic
    atexas70schic New Member
    2007 Toyota Tacoma
    I am having the same problem with my Tacoma..the a/c will only blow on high. We have replaced the resistor the wire harness and connector several times and this last time we changed it out nothing happened. It still only blows on high. Could there be something else causing this? Please help!!
  8. Jul 29, 2018 at 11:49 AM
    Frogman1
    Frogman1 New Member
    Stephen
    1999 Tacoma 4X4
    None to speak of, except I installed slightly heavier rear leaf springs than come stock.
    Hi: The AC on my 1999 Tacoma was only working on low. After my mechanic said the control head (where the switch is) would need to be replaced for about $350, I balked at the cost. I researched the problem and found this forum which suggested the problem might be related to the resistor, which is real easy to access. I removed mine and discovered that it was dirty with a clump of dust, hair and such on the metal parts between the mounting bracket and the ceramic block. It also had a bit of corrosion, but was not broken and didn't appear to be heat damaged. I cleaned it up, reinstalled it and now my AC works on all blower settings. Thanks for the NO COST fix.
  9. Jul 29, 2018 at 12:33 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Find someone nearby to try a swap of AC control panel. If that fixes it then thank them and get yourself a replacement either used or new. Takes a minute or two to pop it out and unplug/replug.
  10. Jul 29, 2018 at 1:10 PM
    Frogman1
    Frogman1 New Member
    Stephen
    1999 Tacoma 4X4
    I count myself lucky that a dirty resistor appears to have been the problem. Another alternative is the switch in your control panel, which will require disassembly of the dash where it it located to get at it. There are U tube videos on how to do that. When I was researching the problem, I found Ebay sellers with the blower switch <$20. Steve
