AC Oil charge, how many ounces?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jibski, Jun 30, 2016.
  1. Jun 30, 2016 at 12:42 PM
    jibski
    jibski [OP] Well-Known Member
    Josh
    Arvada, CO
    2009 Silver 2.7 AC 4X4
    I am rebuilding my '09 AC system. Compressor didn't come with any instructions on volumes and I don't see a sticker under my hood or anywhere on the condenser area that has these volumes either. I have read conflicting information in my search. Some places say there is a total of 8 ounces in the system, and other sources say very specifically that it is 5.61 ounces. Some compressors seem to ship with 5.6 ounces already in them.
    Toyota Corporate and my local dealers have both been useless in answering this (which I don't understand, because when they rebuild someone's AC they must know how much oil to put back in the system).
    Does anyone have a definitive answer to this question?
    Thanks,
    Josh
  2. Jun 30, 2016 at 3:37 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
  3. Jun 30, 2016 at 4:14 PM
    jibski
    Josh
    Arvada, CO
    Wow thanks Lester, you the man. I haven't seen this link before, what a great resource. After looking through that, it's pretty clear that if installing all new components, one should add 5.61oz oil to compressor and 1.4oz each to both condenser and evaporator.
    Thanks again.
    Rambo MARINE Recon likes this.
  4. Jun 30, 2016 at 4:22 PM
    Drivesector
    Drivesector Well-Known Member
    TRD sport
    Beat me to it, good luck OP
  5. Jun 30, 2016 at 5:17 PM
    joedirt
    joedirt Hallow
    Ploeśti
    2005 Tacoma
    Are you buying a new compressor? Some usually come with the oil; you have to drain it and measure it, then add the remainder to the condenser and evap coil.
  6. Jun 30, 2016 at 5:46 PM
    jibski
    Josh
    Arvada, CO
    Yeah I bought one already. Haven't gotten around to removing the old compressor or breaking open the new one yet. That's the first project after the holiday weekend. Thanks guys.
  7. Jul 1, 2016 at 3:49 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    Joedirt is right, drain the oil from the compressor see how much is there and adjust.
  8. Jul 1, 2016 at 4:44 AM
    jibski
    Josh
    Arvada, CO
    Ok after straining my eyes to read drivesector's image (thanks btw), I am once again confused. That chart says TOTAL system capacity is 5.61oz oil. The other link said 1.4oz in each for condenser and evaporator. So that's 2.8oz which is half of 5.61. So would I only put 2.8oz in the compressor (as opposed to 5.61 in compressor) and then 1.4 each in evap and condenser? I still don't see this mysterious refrigerant tag in my engine bay. Can anyone tell me where that is? I'm just trying to figure out if my total oil charge should be 5.6 or closer to 8ish.
    Thanks
  9. Jul 1, 2016 at 5:33 AM
    joedirt
    joedirt Hallow
    Ploeśti
    2005 Tacoma
    5.6. 8 would be way too much.
    Drain the new compressor and measure the oil. I would do 1 and 1 in the condenser and evap coil and the rest in the compressor.
  10. Jul 1, 2016 at 7:30 AM
    jibski
    Josh
    Arvada, CO
    Ok thanks Mr. dirt, I'll go with 5.6 total. But I will drain and measure the new compressor oil as well to compare. I appreciate the help.
  11. Jul 1, 2016 at 9:56 AM
    joedirt
    joedirt Hallow
    Ploeśti
    2005 Tacoma
    Spin the compressor by hand a couple of times after everything is installed but before you start the system.
