AC is cold on the driver's side, hot on the passenger side
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cmassey17, May 4, 2020.
  1. May 4, 2020 at 8:58 AM
    cmassey17
    cmassey17 [OP] Member
    Cole
    2016 quicksand tacoma
    I have a 2016 3.5 with almost 67,000 miles. I’ve had for about 3 years. This year I noticed that the ac is not working like it should.
    The air that it is blowing out is decently cold on the driver side but hot on the other. I have the settings on all the way low, ac button on, and the recycle button on and it will not get anywhere near as cold as it used to be.
    I have put in a new cabin filter and I don’t really know how to approach this problem.
    I need help!
  2. May 4, 2020 at 9:09 AM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    If it was me I would take it to the dealer and at least let them tell me the problem and maybe have them fix it or fix it myself GL .
  3. May 4, 2020 at 9:11 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    This sounds like a low r134 symptom. Many cars will focus AC to the driver when its low.
    ryan760 likes this.
  4. May 4, 2020 at 10:09 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Sounds like a blend door issue to me if one side of the truck is colder than the other.
    Cvarnz46, Canufixit, BSFord and 4 others like this.
  5. May 4, 2020 at 10:55 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    You have dual zone? If so I would assume an issue with blend doors or however the truck splits them.
    BSFord and Modesto Tacoma like this.
  6. May 4, 2020 at 11:08 AM
    ryan760
    ryan760 Well-Known Member
    High probability it's low on refrigerant. Also these trucks take the new r1234YF, not r-134a.
  7. May 4, 2020 at 2:43 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    If some of the vents are cold, there's most likely a blend door or controller issue; time for the dealer. Just cause I'm assuming it's easy (I've never actually done it on this particular truck) check the cabin filter.
    Canufixit and BSFord like this.
  8. May 4, 2020 at 2:54 PM
    Doobfucious
    Doobfucious I get it. It ain't makin' me laugh but I get it.
    Doobie
    WNC -> Midwest
    2020 TRDOR DCSB 6MT
    Stock AF. My 68 Bronco and 2000 2.5RS get the mods.
    Good call on the cabin filter, make sure it's clean before bringing it to the dealer.
    shakerhood likes this.
  9. Jun 26, 2020 at 8:54 PM
    cmassey17
    Cole
    Forgot to update. Took it to my local shop and it was halfway low on freon. Had them put some back in it and works good as new.
    Kolter45, Canufixit, BGXtobe and 2 others like this.
  10. Jun 26, 2020 at 9:09 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Glad to hear they got you all fixed up, wonder why the refrigerant was low in the first place?
    MannyS and Chew like this.
  11. Jun 26, 2020 at 9:26 PM
    Jcran2
    Jcran2 Well-Known Member
    Middle Georgia
    2016 MGM Tacoma TRD Sport
    Bed Mat, Soft Bed Cover, Weathertech Mats, LEDs throughout interior, 1" Bora Wheel Spacers, OEM Bed Light Kit, OEM Mudguards, Window Tint, Center Console Organizer, Glove Box Organizer
    Sounds like blend door. Low freon sounds suspicious.
  12. Jun 26, 2020 at 9:32 PM
    5nahalf
    Erik
    Minnesota
    Many car will do this. If there is not enough refrigerant in the system to cool the whole cabin it will close off other parts (like the passenger) to make sure the driver gets the AC.
    The hvac system in a car is like a person going into hypothermic shock, it tries to preserve the vital parts (The driver)
  13. Jun 26, 2020 at 9:37 PM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    Has Katy Perry been riding in your truck?
    ....lucky
  14. Jun 26, 2020 at 9:44 PM
    cmassey17
    Cole
    I definitely thought it was odd that it was low. I have rebuilt quite a few of these trucks in my shop but I don’t have the machine to mess with the r1234 Freon yet. This truck was hit in the rear with no damage to the front. That definitely doesn’t rule out the fact that something wasn’t jerked around too hard. I’ve had this truck for a while and was about ready to part with it, but I guess it’s going to stick around for a while longer to make sure nothing else will happen. It has been nearly 2 months since it was fixed and nothing has happened yet with the ac being used almost every day.
  15. Jun 26, 2020 at 9:58 PM
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
    I get it......but I'm very much ashamed that I get it
    BSFord likes this.
  16. Jun 26, 2020 at 10:03 PM
    jmauvais
    NorCal
    ...stuff
    I feel dirty all over for saying it.
    One could say I was yes then I was no about it
    slowlane[QUOTED] likes this.
  17. Jun 27, 2020 at 12:58 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Wow - would not of thought it was Just Low charge..... Good to know! Thanks for the follow up/results post OP !!
  18. Jun 27, 2020 at 1:06 PM
    Cvarnz46
    Cvarnz46 Well-Known Member
    Tennessee
    2020 magnetic grey trd off-road A/T V6 4X4
    No most cars won’t even let the ac run if it’s to low on Freon hence why they have a pressure cut off switch on 99% of cars now. The blend doors don’t automatically adjust to only blow the drivers side I can guarantee you that, possibly due to insufficient cooling so by the time it circulates to the passenger side it’s not as cool would be the only possibility.
    Chew likes this.
  19. Mar 29, 2024 at 3:16 PM
    Sct60
    Sct60 Member
    Scott
    2018 White Tacoma TRD
    None yet
    My 2018 Tacoma A/C wasn’t blow cold but somewhat cool but in the heat of the day not cold enough and passenger side not blowing air at all. So went to local Auto Zone and bought a can of r1234yf, system was low once added sufficient amount now it’s blowing cold again. Will know once vehicle runs a while whether passenger side is blowing now. Also gonna check the cabin air filter too. MTF
  20. Mar 29, 2024 at 3:54 PM
    Mike_O
    Mike_O Active Member
    2019 DCSB Manual/2021 DCSB MGM Sport Manual
    Had the same issue on my wife's 2019. Driver's side cold, passenger side warm. Turned out to be low on refrigerant because of a small leak.
    Eventually the compressor went and we went without cooling for a couple of months while waiting for parts. Luckily everything was covered under warranty.
