AC/Heater fan only works on high
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stevencand0, Jul 9, 2018.
  1. Jul 9, 2018 at 10:18 PM
    stevencand0
    stevencand0 [OP] Member
    hanco likes this.
  2. Jul 10, 2018 at 2:23 AM
    5678ta
    5678ta Well-Known Member
    Hogan
    Henderson, NV
    '18 ECLB Colorado ZR2
    Sounds like a switch problem if you already replaced the resistor.
    Nimble9 likes this.
  3. Jul 10, 2018 at 3:02 AM
    i/o
    i/o Active Member
    Richard
    San Antonio Texas
    2013 Limited Double Cab PreRunner Pyrite Mica
  4. Jul 10, 2018 at 9:00 PM
    stevencand0
  5. Jul 10, 2018 at 9:02 PM
    stevencand0
    Can you elaborate please? Maybe link me to a switch I can buy online. :cheers:
  6. Jul 10, 2018 at 9:16 PM
    5678ta
    Hogan
    Henderson, NV
    Think electronic throttle body and pedal assembly. You changed the throttle body but it still only moves when you mash the pedal. Bad pedal. Your situation, bad HVAC fan control switch.
    https://www.ebay.com/itm/9849E-TACO...ash=item2aa6868885:g:ZlEAAOSwSKtaY1aJ&vxp=mtr
    This is speculation though... It is up to you to do your tests before dropping $150 on a new climate control switch.
    DG92071 likes this.
  7. Jul 10, 2018 at 9:19 PM
    Little Bruiser
    Little Bruiser Well-Known Member
    Jon
    Salt Lake City
    2014 tacoma TRD
    Mine did this as well. Luckily still under warranty and toyota replace the throttle control panel
  8. Jul 20, 2018 at 4:04 PM
    Caithegreat83
    Caithegreat83 New Member
    '06 Tacoma
    I've had the same issue with my 2006 tacoma. Already replaced the blower motor resister and the connector, but at different times. Each time it fixed it for a little while and would only work on high again. I'm going to replace both at the same time and see if it works
  9. Jul 20, 2018 at 5:07 PM
    Taco'09
    Taco'09 Well-Known Member
    OP, there is the old Dorman and the new Dorman. Once upon a time Dorman had a decent reputation for aftermarket parts, but in recent years I have had bad luck with the new stuff and would never consider using their electrical parts, YMMV. I have been recommending the ACDelco kit for the reason that the entire HVAC in our trucks is a GM special and they came up with the kit as a fix. Probably ToyMoCo's parts in the TSB is a repackaged version of this and that would make sense because of the earlier GM/Toyota joint venture.
    Here is a TSB for the problem that appeared in the fall of 2011 and you may find something useful therein.
    T-SB-0149-11.pdf
    hanco and charliecham15 like this.
  10. Jul 23, 2018 at 11:49 AM
    Tacoman1992
    Tacoman1992 Active Member
    Thank you for this!!!
  11. Jul 23, 2018 at 11:49 AM
    Tacoman1992
    I bought one on Amazon for $22 I believe worked perfect
  12. Dec 30, 2019 at 1:28 PM
    Efbarf13
    Efbarf13 New Member
    I recently went to my local dealer to get a new resistor and connection. It needed a new connection because the new recommended resistor was an upgrade and wouldn’t fit the old connection.
  13. May 21, 2020 at 10:24 AM
    coldbeer1000
    coldbeer1000 New Member
    2006 Tacoma 2013 Tacoma
    I had the same problem and replaced the resistor it worked for about 20 minutes and quit again. The resistor got very hot. I removed the motor and the cap is rusty. Should the fan motor spin freely because mine takes a little effort?
  14. May 21, 2020 at 10:37 AM
    Big_Red_Taco
    Big_Red_Taco Well-Known Member
    SoCal
    Rad Red '08 DCSB TRD Off Road
    Mostly stock: AP rear plate bumper, CR D-Lights, 4600s
    I replaced mine with the new Toyota design that quietly came out in...2018 or so? The connector was changed with a presumably better, square shaped design. The parts counter gave me a kit that included the new design resistor, new square pigtail, and butt connectors.
    I've had it on for over 8 months and have had zero issues, after replacing just the resistor before and having everything fail again and again.
    hanco likes this.
  15. May 21, 2020 at 12:18 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    It should spin freely. Sounds like you need a new motor, though some folks take them apart, clean and relube them.
  16. May 21, 2020 at 12:34 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    you need a motor and another new resistor. Check the connector pins for melting too
  17. May 21, 2020 at 1:22 PM
    coldbeer1000
    Thanks to all the replies. The connector pins look fine.
  18. May 21, 2020 at 2:32 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    There are two connectors that can fail, or have a bad connection: the 4-pin that goes into the resistor, and the two-pin that goes into the blower.
    My first issue was that the #3 blower speed setting did not work. That was due to one of the pins in the resistor connector. Using fine file set, I removed the haze and used a pick to bend the tab back into shape. Then, the fan would only work on high. That was due to a bad connection at the blower. It had got so hot it melted the connector. I had to use .187 female pins to wire directly to the blower. I posted pictures on another thread years ago. In my case there was nothing wrong with the resistor or the blower; it was shitty connectors.
  19. May 21, 2020 at 7:15 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The motor should spin freely with little to no resistance. It sounds like the motor is binding causing increasing current draw. If the blower is not spinning there is no air flow across the resistor and it will get hot and burnout. That is why it is inserted into the air flow duct to cool it off.
    CurtB and b_r_o like this.
  20. Aug 27, 2020 at 8:29 PM
    bkrdave36
    bkrdave36 Well-Known Member
    Dave
    Wittmann,AZ
    06 Prerunner Double Cab Black
    Front OME Springs, Upper Control Arms, Icon Stage 3 Rear Leaf Springs, Durobump bump stops,Bilstein 5125 shocks, BFG All Terrain KO2 Tires, Avid Light bar and step rails, Victory 4x4 bed rack with Tepui Ayer Rooftop Tent, Anytime Fog light mod, Outside Air Temp Gauge mod, ImMrYo Rearview Mirror mod, Chinese Knockoff LED lights, Body Armor 4x4 Offroad Swingout rear tire carrier and bumper, Victory 4x4 Bed Stiffeners, Rattle can Custom Camo paint stripe, Truxedo Lo Pro tonneau cover, various Blue Ridge Overland Gear storage solutions in cab, thats it so far .... to be continued!
    Anyone have any problems with the new type resistor going bad like the old style ones? Mine seems to be taking a dump this past two days (when its conveniently about 110 outside).
    Will the new "new" style work (The one that was posted above that came out in 2018 with new connectors ?) in my 2006 Prerunner?
