AC Freezing HELP
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FXHO, May 17, 2016.
  1. May 17, 2016 at 8:46 AM
    FXHO
    FXHO [OP] Well-Known Member
    Luis
    Miami,FL
    2013 Toyota Tacoma DCSB TRD Sport
    So abt 2-3 months ago, I noticed that after abt 30-45 mins of running the Ac, whether on low or high, it looses power and doesn't blow as hard and as cold but still blows cold air. So I poped the hood and noticed the Ac line frozen with a good thick layer of ice. After shutting down the Ac for about 30 mins and turning it back on, AC runs normal and blows extremely cold. I'm attaching a video so you guys can see what I'm talking about.
    Why is it doing this? Why is it freezing over with ice? And how can I fix it?
    My AC compressor was changed alout at abt 20k ish mileage and my truck currently has 59k so it's not that old. It was replaced BC they thought that was the raddleling noise coming from under the glove box but it wasn't.
    I've tried searching and found that it might be low in freeon or what not but I wanted to ask you guys what you all think it might be.
    here is a video to show how bad its freezing up
    https://drive.google.com/file/d/0B6w_FmG7wxsSUklremtJSi1kR2M/view?usp=sharing
    Thanks in advance
  2. May 17, 2016 at 8:57 AM
    randd
    randd Well-Known Member
    Eric
    Sunbury Ohio
    2015 4x4 DCSB Black
    2 things I can think of off hand are either:
    1. Your charge is low, probably since they replaced your compressor
    2. Your cabin air filter could be plugged up. Check you cabin air filter to make sure it is clean.
  3. May 17, 2016 at 9:48 AM
    FXHO
    Luis
    Miami,FL
    what do you mean charge is low?
  4. May 17, 2016 at 9:57 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Low on refrigerant. R134-A is the refrigerant used in 2nd Gen Tacoma's and many other vehicles.
  5. May 17, 2016 at 9:59 AM
    FXHO
    Luis
    Miami,FL
    I'll try this. So i just buy a bottle and empty it in or is there suppose to be a certain amount of pressure on the gauge?
    so my truck is considered low on refrigerant even tho it cools very good for the first hour or two?
  6. May 17, 2016 at 10:00 AM
    Lester Lugnut
    Compressor?...that's weird. It's under the hood closer to front of engine.Don't understand how an experienced a/c tech thought that? Sure it wasn't the evaporator which is below the glove box?
  7. May 17, 2016 at 10:00 AM
    randd
    Eric
    Sunbury Ohio
    2015 4x4 DCSB Black
    The refrigerant should be charged to a certain pressure that should be done by a professional.
    Lester Lugnut likes this.
  8. May 17, 2016 at 10:03 AM
    FXHO
    Luis
    Miami,FL
    i have no clue what it is. from when my truck had about 9k miles it had this ticking noise under the glove box. at first the thought it was something stuck in the fan or filter, like a leaf, which was causing it but when they checked everything was clean and clear. so after multiple visit, they decided to change the fan under the glove box thinking that was the cause (at around 25k miles) but till this day my truck is at 60k and is still doing it.
  9. May 17, 2016 at 10:04 AM
    FXHO
    Luis
    Miami,FL
    so this is not something i can do on my own? like go to the auto parts store and buy a refrigerant can and load it up myself?
    does anyone know what the pressure setting needs to be at?
    my truck hasn't seen a stealership since it had 25,000 miles. I have been doing all the maintenance myself and really don't want to take it back to those guys. they do everything half ass.
    took my truck in for an oil change once, under the first 25,000 maintenance warranty, and wrote on my oil filter with a silver sharpie to make sure it was being changed, got called to pick up my truck because it was ready, popped the hood and my oil filter was still the same.
    when i ask if they changed it, everyone said yes it was changed until i showed them my initials was written on the oil filter
  10. May 17, 2016 at 10:06 AM
    Lester Lugnut
    If it were me doing this, I'd put R134-A gauges on the system(2 lines - low & high pressure) and check pressure. I would never rely on the gauges installed on the suicide kits sold at the McParts places. Compare readings to what's in the FSM(factory service manual). If low - charge.
    If a low refrigerant charge is not the issue you might also suspect a faulty evaporator thermostat. I'm still suspicious your evaporator was changed and not your compressor.
    If you have the receipt from the work done, post the part numbers.
  11. May 17, 2016 at 10:10 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    For Reference on a/c freon capacity
  12. May 17, 2016 at 10:12 AM
    FXHO
    Luis
    Miami,FL
    thanks soo much for your help brotha. as soon as i get home, I'll look for the invoice of the work they did on my truck
  13. May 17, 2016 at 10:12 AM
    FXHO
    Luis
    Miami,FL
    ah ha. savage! thank you.
  14. May 17, 2016 at 10:14 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    The stickers have a tendency to fall off, so I finally found one and documented! Now like everyone else is saying don't just get the recharge cans with the hoses with them. Get a manifold set if you want to DIY and learn how to use them
  15. May 17, 2016 at 10:17 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    You can get a gauge with a can of the 134 at most auto parts stores...they are pretty simple to use, it may or may not need to be topped off. Just follow the instructions on the can. Mine was really low and I serviced it myself and it works great now.
  16. May 17, 2016 at 10:24 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    That only works for some cases, and the gauge only reads the Low pressure side. To do it correctly you need the manifold set which reads High and Low pressure sides.
    IPNPULZ and Lester Lugnut like this.
  17. May 19, 2016 at 5:23 AM
    Turbo-Taco
    Turbo-Taco Well-Known Member
    Randy
    Portland, Oregon
    2024 Toyota Tacoma SR5
    You might have a similar issue I was having with mine. Dealer found the reciever dryer slightly over saturated with moisture due to a prior leak allowing it to freeze at the expansion valve. They replaced condensor and dryer and all is well now. Evidentally they didnt evac the system good enough after the leak and the system got moisture in it causing my problem.
  18. May 19, 2016 at 5:35 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Just did mine. Autozone rents it for free.
  19. May 19, 2016 at 5:36 AM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    You may have some kind of restriction as well....
  20. May 19, 2016 at 6:29 AM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Your low pressure switch is not working, allowing the compressor to run continuously.
