ac discharge hose heating up???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Conej0, Aug 20, 2017.
  1. Aug 20, 2017 at 6:36 PM
    Conej0
    Conej0 [OP] New Member
    08 Tacoma 4WD four door
    Magnaflow exhaust, 2.5 inch lift,
    So my A/C discharge hose on my 2008 tacoma gets very hot when i turn on my Ac is that normal? it is only when my ac is on, and it cools down when it is off, i checked my friends truck its a 2011 and it does the same. so I'm confused since a mechanic said it usually doesn't do that but wanted to see if anyone knows about that, thanks
  2. Aug 20, 2017 at 6:38 PM
    Frankenstuff
    Frankenstuff Busy iracing
    Frankie
    16TRDORDCsb 4x4 & 2020 BMW M2 competition
    16 trd ORdcsb4x4 c4 swingout rear, cbi t3 front , arb lift,16"grabber x3 rtt, hilift,jerry cans,and sliders . 81 hilux trail donkey
    I work in collision and charge a/c frequently on many different vehicles. It's normal.
  3. Aug 20, 2017 at 6:41 PM
    Conej0
    what about the pressure what should it be at normally? mechanic said it was 400+ and it should be at 200 or something like that
  4. Aug 20, 2017 at 6:49 PM
    Frankenstuff
    Frankie
    It says the lbs or kilograms it needs to be charged at on a sticker under the hood . We just evacuate ,pressure test and charge the weight of the refrigerant required buy the vehicle . It's mostly the new stuff for us on average now the y-1234.
  5. Aug 20, 2017 at 7:05 PM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    What the high side pressure should be depends on the ambient air temperature--here's a "rule of thumb" chart for low and high side pressures:
    400 psi is high, here is a guide to interpreting the observed pressures:
    The high side hose is normally hot, however blockage at the expansion valve or orifice tube could cause it to be very hot.
    But--you need to check the low side pressure also; if it too is high then the system may be overcharged...
    Tex-Tac and TRDSport10 like this.
  6. Aug 21, 2017 at 4:15 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Yes, it's normal. That's how the system is supposed to work. The compressor compresses the refrigerant which increases the temperature, PV=NRT. That makes the refrigerant hotter than ambient temperature. Then, it goes through your condenser which is that second radiator looking thing in front of your radiator. It cools from air flow through the condenser then is circulated to your evaporator coil in your cab, under the dash. When the pressure drops, the temperature drops and gives you a cooler than ambient temperature in the evaporator coil. Your fan blows air through that coil and gives you nice cool, refreshing air in the cab of your truck.
    Yes, it's normal.
    cliffyk likes this.
  7. Aug 21, 2017 at 4:37 PM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    Sub'd
  8. Aug 21, 2017 at 9:01 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    400 is high. Make sure you fan is working and your system is properly charged.
    landphil likes this.
