AC Condenser Hole from Tansmission Cooler
Discussion in '3rd Gen. Tacomas (2016-2023)' started by curraist, Aug 2, 2023.
  1. Aug 2, 2023 at 7:38 AM
    curraist
    curraist [OP] New Member
    Hello, fairly new to the forum so I would appreciate any help. I looked around and didn’t see anything about this specific issue (apologies if I missed a post about it).
    I noticed my AC was not blowing any cold air, upon inspection it appears that my transmission cooler has rubbed a hole in the condenser. My truck is a 2019 so I figure Toyota wont help me out but I would like to see if anyone else has dealt with this before. From what I understand replacing the condenser and the 1234yf refrigerant is not cheap.
    Attached photo has the cooler moved to show damage.
    OnHartung'sRoad likes this.
  2. Aug 2, 2023 at 7:43 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    If you do have to pay for this yourself, you do not need to buy a Condenser from Toyota. I had a hole in my condenser and purchased one from O’Reilly’s. It works just as well, and I’ve had it over two years now. It was less than half the cost of the OEM one. Also, most air conditioning shops can do this for you.
    People should definitely know this can happen, it is a very expensive repair!
  3. Aug 2, 2023 at 7:49 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Looks like you or a previous owner installed a winch and some kind of winch mount. It's possible the trans cooler was pushed back during that install -- it's not likely it came from the factory that way. Either way, it's probably not under warranty.
  4. Aug 2, 2023 at 8:00 AM
    OnHartung'sRoad
    I didn’t even notice the winch- just looked at the hole. Yeah, you are right, it won’t be covered due to this type of modification. Guess I should have written that people who install winches should check to be sure they don’t push anything against the condenser.
  5. Aug 2, 2023 at 8:37 AM
    curraist
    The photo does not really do it justice but the winch and front bumper sit in front of the cooler with no touching at all. That being said you are right and they would say the modification would make me liable. I really wanted to see if anyone else had ever noticed this issue and if not, to check before it is potentially too late.
    Thank you OnHartung for the condensor suggestion, hopefully the refrigerant isn’t too bad.
  6. Aug 2, 2023 at 8:58 AM
    OnHartung'sRoad
    Hey, I was just looking at the price for OEM condensers, and they’re not as bad as I thought anymore. Back when I was looking for one it was about $400 during Covid. You can buy them for about $300 now. I installed the Denzo one from O’Reillys and it was about $100.
    https://parts.longotoyota.com/oem-parts/toyota-condenser-8845004012
    I installed and did the whole job myself. The refrigerant will cost about $150 or so if you buy it over the counter, and you would also need PAG oil and a vacuum pump if doing it all yourself. Some places like O’Reilly’s loan out refrigerant manifolds, but I’m not sure they have the right one. I bought one of the refrigerant kits that had a pressure gauge built-in.
    Another less expensive way of doing this is to do just the condenser install labor yourself- it’s easy. Then have a AC service vacuum and recharge the system for you. If you go this route just be sure to add PAG oil in the condenser before bolting the lines on it - You’ll have to look up to see how much oil to add, I forget what amount it required.
  7. Aug 2, 2023 at 12:45 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Generally with a winch bumper that cooler gets relocation mounts to make room for the winch. So chances are good it either has relocation mounts or it was just bent back to fit the winch.
    Chew likes this.
  8. Aug 2, 2023 at 1:25 PM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    This! Usually bumper kits will include the brackets to scoot the cooler back. With the amount of scratch marks above and below the hole, I'm willing to bet the cooler is just unmounted and flopping around back there.
    5nahalf[QUOTED] likes this.
  9. Aug 2, 2023 at 1:57 PM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    That looks like the power steering cooler not the trans cooler. My stock trucks sits at least 2 inches from the condenser with 0 rub marks. This is almost certainly from the winch install.
    Clearwater Bill likes this.
