AC condenser clean out
Discussion in '1st Gen. Tacomas (1995-2004)' started by Caslon, Apr 9, 2021.
  1. Apr 9, 2021 at 8:00 PM
    Caslon
    Caslon [OP] Well-Known Member
    2003 Base Cab. 2 whl drive. 5 speed
    Been trying to clean out the accumulation of smoke and mildew smell. What bothers me is that I use cans of Kool-It foaming cleaner and empty 8oz. of the stuff, but only about 4 oz. drains out from the drain tube. What liquid drains out is brown, but I wonder if the other 4 oz. is just collecting smelly liquid near the drain out tube area. Drain tube is not clogged. I end up driving a few feet forward and stopping fast just hoping it sloshes out, which it does, but just a little. Took the blower motor off and no debris that I could see or feel by reaching my hand up inside to a limited degree. Wondering if I have to use 5 cans of the stuff before the liquid drains out clear. I feel as if the condenser area just isn’t getting cleaned enough at $12 a pop for this stuff. 4 weeks later the bad smoke smell comes roaring back.Tried using two 8 oz. cans at once. It ends up draining out almost immediately. Not sure it’s foaming up like Kool-It says it does. Anyone used a different brand foaming AC condenser cleaner? That brand might be overrated. P.S. I fed the hose thru the console vents too.
  2. Apr 9, 2021 at 8:19 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Bad smoke smell? You might be smelling a valve cover gasket leak. Oil drips on the exhaust and makes a stinky burning smell
  3. Apr 9, 2021 at 8:47 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
  4. Apr 9, 2021 at 8:58 PM
    Caslon
    Jeesh! If I want to get to the problem once and for all, that link pulls no punches. Not sure if a ‘97 AC housing is similar to a 2003 Tacoma. There’s probably a build up of smoke residue that totally coats that area. I was a bit disappointed with Kool-It foaming cleanser and how little drained out. Damn, it was nasty brown, just not enough of it. As if I could repeat it five times and still not eventually get clear liquid. Like 10 cans of the stuff at $12 a pop. BTW, there’s only a measly 8 oz. of that “foaming” cleanser per $12 can. That’s not a whole lot. Anyone recommending another brand would also be appreciated. And yes, I always try and not use the recirculating air setting.
  5. Apr 9, 2021 at 9:06 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    As far as I know all the 1st gens use the same HVAC housing, it's not terribly difficult to get to the evaporator just takes a little time.
  6. Apr 9, 2021 at 9:36 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    If it’s that bad and you can pull it that would be your best bet. Then you can steam it, pressure wash it, whatever and clean out the box too.
  7. Apr 10, 2021 at 5:08 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    The only real way to clean an Evap Coil is to pull things apart so you can see it .
    Worse case disconnect and remove the complete coil
    not doing the first just makes things worse
  8. Apr 10, 2021 at 5:24 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    I pulled the inside of mine apart last year and washed it with coil cleaner, it didn’t help the stink on A/C startup. Not sure what is going on with it.
  9. Apr 10, 2021 at 8:34 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    The vent tubes are still dirty as is the cabin intake.
    six5crèéd[QUOTED] likes this.
