AC compressor Manifold...? Stripped bolt Help pls
Discussion in '1st Gen. Tacomas (1995-2004)' started by HaloATL, Jun 30, 2024.
  1. Jun 30, 2024 at 5:58 PM
    HaloATL
    HaloATL [OP] New Member
    Greetings All,
    I have a 98 2.4 standard which has had a siezed ac compressor for some time. I have a friend who agreed to replace the compressor but unfortunately a bolt snapped when he was taking the old one out. Not sure what the name of the part is other than AC manifold but Ive included some pictures to show what I am talking about. He probably should have taken it out differently but now I just need to find a new one so the new AC comp can go in. Thanks for any help finding the part.
  2. Jun 30, 2024 at 6:42 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Bc that bolt is in the bad compressor
    You don’t need to extract snapped bolt
    take the bolt that came out correctly (Next to the green line in your pix)to dealer or old school hardware store
  3. Jul 1, 2024 at 7:05 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Compressors typically come with a blank cover in place of the manifold as different models use different manifolds on the same compressor. They also have a slight pressure to prevent moisture intrusion and help with seal health.
  4. Jul 1, 2024 at 11:35 AM
    HaloATL
    That’s the manifold still attached to the old compressor. How do I replace that since it has a broken bolt snapped into it?
  5. Jul 1, 2024 at 2:10 PM
    ControlCar
    Steven
    Sugar Land TX
    ohhhh sorry i didnt know not included
    anyway
    you need a reverse bolt extractor
  6. Jul 1, 2024 at 2:15 PM
    ControlCar
    Steven
    Sugar Land TX
    i had to do the same on a snapped valve cover bolt on a Subaru
    BARELY ANY ACCESS.....EVEN WITH ENGINE RESTING ON FRONT SUBFRAME
    i had to modify a R-angle drill(cut the drill housing) and dremelled away small portion of subframe lip just for access
    IT WORKED......1ST TIME!!!!
    (if it didnt i would have to pull entire engine for access)
    yours will be 1000% easier to accomplish bc you can do on a bench
    -drill small hole 1st
    -use reverse bit 2nd
    GL
    let everyone know how turns out
  7. Jul 27, 2024 at 2:23 PM
    Ouranos
    Ouranos Member
    Sasaki
    2011 Toyota Tacoma
    K&N Drop-in Filter, Nitro Gear Upper Control Arms, Teck Deck. Pioneer Head Unit, Bullbar, Magnaflow Exhaust. Body Mount Chop, Alpha Rex LUXX-Series Projector Headlights.
    What's the bolt size for this? I snapped one too while changing out a compressor for my father's 95 Tacoma with the 2.4L 2RZ-FE.
