Ac compressor locked up
Discussion in '1st Gen. Tacomas (1995-2004)' started by lshouse35, Apr 9, 2015.
  1. Apr 9, 2015 at 5:55 PM
    lshouse35
    lshouse35 [OP] Active Member
    Lawrence
    Havelock nc
    04 tacoma 2.7
    my ac compressor gave me trouble when I first bought my truck a year ago (it made a really loud screaming sound when I would engage it)I replaced the idler pulley and the belt no more noise an the AC would freeze you out .. Today I got home from work and could smell something like your brakes got hot ... Check brakes popped the hook checked all electric wires nothing went out a couple hours later to go fishing cranked the truck up started smoking and screaming loud I shut it down looked my compressor locked up and the crank was burning the belt up I took the belt off ... And ran it with no problems will it be alright to drive with out that belt for a while and has anyone replaced the compressor and have some advice for me to do it on a budget
  2. Apr 9, 2015 at 5:58 PM
    lshouse35
    Lawrence
    Havelock nc
    04 tacoma 2.7
    It's 2.7l 03 btw
  3. Apr 9, 2015 at 6:54 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    No info on the compressor questions but yes you can run it without the belt! Nothing to worrie about!
  4. Apr 10, 2015 at 12:40 AM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    You can replace the compressor yourself. I'm not sure of anyway to save money here other than find the cheapest one. You'd want to replace the receiver/dryer at the same time. Then take it to a shop and have them vacuum the system and fill it with freon. Before doing any work yourself, explain to the shop what you are doing and ask if you should add any oil to the compressor and if so how much and what type. Later, when you take it in let them know how much oil you put in (if any) so they know if they need to add oil or not.
  5. Apr 10, 2015 at 7:32 AM
    MrRiverMan
    MrRiverMan Compulsive tinkerer
    WNC
    2002 Taco 2.7 4x4 auto, 96 Taco 2.7 4x4 manual, previously 2003 Taco 4x4 auto, 2000 Taco 2.7 4x4 manual, 1994 22RE 4x4 manual, and 1996 T100 4x4 auto
    The compressor definitely takes a bit of oil on the 2.7s. You have to pour it in before you hook it up. I found the amount needed in the service manual. I replaced my compressor with one from a junkyard. It does sound like the clutch in your compressor is shot, so you will need to replace the whole unit.
    It's fine to run it without the AC belt on there until you can get it fixed.
  6. Apr 11, 2015 at 12:36 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    The bearing in my AC clutch went out and melted the clutch. I ended up replacing just the clutch with the compressor in the vehicle. This allowed me to do the job for about $70 (cost of the clutch) and not have to drain the refrigerant. It was not an easy task and required many different snap ring pliers and a mirror to see what I was doing.
  7. Apr 11, 2015 at 2:27 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    This.
    Might be a good time to flush the system of all the old oil and replace with new.
    The AC is one of those " do it right the first time" type things or you will spend a shit-ton of money getting it right.
  8. Apr 17, 2015 at 2:04 PM
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
  9. May 11, 2021 at 7:57 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    1st gens have 3 belts
    Alternator
    Power steering pump
    AC
