AC compressor clutch wobble
Discussion in '1st Gen. Tacomas (1995-2004)' started by Shortman5, Jul 24, 2018.
  1. Jul 24, 2018 at 3:24 PM
    Shortman5
    Shortman5 [OP] Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Need some advice on a AC compressor. The pulley seems to run true at all times but when it kicks on the clutch wobbles around. I’m really hoping that the clutch can just be replaced and not the entire unit. Does anyone have experience with this?
  2. Jul 24, 2018 at 6:57 PM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    I’d replace the clutch sounds like it might be bent.
  3. Jul 24, 2018 at 7:08 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    The shaft is probably bent and becomes worse under load than when free wheeling.. you may have to replace the whole thing.
  4. Jul 24, 2018 at 7:17 PM
    Shortman5
    Supercharged TRD
    Under load it seems to run true. Even at a very light load by just slightly giving it some gas. Maybe I just can see it because it’s moving faster though.
    How would the shaft get bent?
  5. Jul 24, 2018 at 7:20 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    No idea. Just throwing spaghetti on the wall. Is it vibrating? Or maybe it just looks bent when turning?
    Here's what mine looked like on my old noisy compressor.
    https://youtu.be/gIh0XYtiaHk
    Maybe it's the bearing itself? Does it sound grindy and gritty when turning? That might be what's loose.
  6. Jul 24, 2018 at 7:48 PM
    Shortman5
    Supercharged TRD
    Nope no noise at all. It might be vibrating a bit at idle but not all that noticeable.
    Weird thing is the other day I thought it resolved itself as it seemed to run true. The next day back to wobble. Today After work wobble then no wobble now.
    Weird.
  7. Jul 24, 2018 at 8:34 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Do you check under the hood every time or are you just feeling it somehow while driving?
  8. Jul 24, 2018 at 9:57 PM
    Shortman5
    Supercharged TRD
    I don’t feel anything really. I just noticed it a few weeks ago and take a look at it just about every day to see if it gets worse. It seems to come and go though, with it wobbling most of the time. It’s weird.
    But if it doesn’t always do it it’s a little less concerning that it’s the compressor itself. I’ll just have to change the bearing and see if that does anything. But I may just do the whole clutch if you can get it separate.
  9. Jul 24, 2018 at 10:07 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Could just be your clutch making not-perfectly-centered contact with the pulley on some occasions.
  10. Nov 3, 2021 at 6:20 AM
    Kristi with a K
    Kristi with a K Well-Known Member
    Western MA
    01' Black (was Maroon, then red) Tacoma 4x4 SR5 ACab 3.4L AT
    G-Men sticker, driver's side "backseat" window - cracked driver's side headlight cover complete with hazy look - DIY 30 footer paint lift in Bedliner Black
    @ThunderOne - I've been procrastinating this mostly due to the compressor vs clutch dilemma. It's november & in Mass, defrost is a good idea to have. Anyway, I believe I saw this thread before, however maybe I didn't watch your vid. Pretty darned similar to what mine is like. Or was. I removed the belt a while ago. Question - was the prob the compressor or the clutch?
  11. Nov 3, 2021 at 7:47 AM
    Shortman5
    Supercharged TRD
    I just want to throw this out there. Ive had the same issue. After a new AC compressor and crank pulley I realized the the bolt hole that clamps the crank pulley onto the crank nose nose is slightly off center and crooked.
    This clamps the crank pulley on slightly harder on one side than the other. It creates an out of round orbital movement. All the other accessories have enough tolerance for the light wobble but when that Clutch kicks on it clamps on to the AC pulley that is moving slightly out of round (because it’s following the crank). This is what causes the excessive vibration/wobble.
    Ive confirmed my crank was never drilled out/repaired. It is just one of those factory defects that got out. Gadget also mentioned he had one of these wobbly crank pulley issues on his 3rd gen 4Runner. So far 170k+ miles no real issues other than annoying vibration and excessive noise from the accessories vibrating with the AC on.
    It just is what it is.
    Kristi with a K likes this.
  12. Nov 4, 2021 at 5:45 AM
    Kristi with a K
    Western MA
    Now that I have re-re-reread this thread, mine has the same symptoms as in the vid, however it matters not if the ac is on. It happens constantly as the pulley is always rotating. Louder & more wobble under load. My guess is that would be bearing.
    Wouldn’t this cause the symptoms to happen whether the ac was on or not? Or maybe it just becomes more evident since it is working harder?
  13. Nov 4, 2021 at 5:49 AM
    Shortman5
    Supercharged TRD
    Your issue is more than likely the pulley bearing on the AC compressor.
    But no. It’s hard to describe. You’d have to look at what’s going on with mine and understand how the AC compressor works and it will make more sense. To be fair all the accessories are taking up some of that orbital movement and the belts are taking up some as well. But when that clutch kicks on it grabs that pulley off center and adds a load.
