AC Compressor Clutch and Pulley replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TuckHolladay, Jun 22, 2021.
  1. Jun 22, 2021 at 9:09 AM
    TuckHolladay
    TuckHolladay [OP] Well-Known Member
    JT
    NJ
    2015 TRD Offroad, Blue, stock for now
    I am going to replace this weekend if I can get the right part. Has anyone else done this? Can anyone recommend where to get the part or should I make sure to get it from the dealer?
    it’s for a 2015 automatic six cylinder
  2. Jun 22, 2021 at 11:54 AM
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    I dont have the clutch part number! GL!!
  3. Jun 22, 2021 at 11:54 AM
    cardinalsfan
    cardinalsfan 2022 TRDOR DCLB
    What symptoms were you having and how did you diagnose this?
    From what my mechanic said, it's better to just replace the whole compressor assy, clutch/pulley and all.
    Just get any part from Rock Auto, dealer will be $$$
  4. Jun 22, 2021 at 12:01 PM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    I just bought mine@! Parts should be delivered tomorrow I hope. I am also replacing the lower idler pulley.
    These are the AC Compressor clutch, snap rings, and spacer kit part numbers.
    Canadian prices.
    Description:A/C Compressor Clutch
    Part Number: 8841004062
    Quantity:1
    Price:$431.21
    Description:
    Part Number:
    8831704010
    Quantity:1
    Price:$7.85
    Description:
    Part Number:
    8836504010
    Quantity:1
    Price:$8.13
    Description:
    Part Number:
    8836504020
    Quantity:1
    Price:$7.95
    2 weeks ago, we went wheeling for the 1st time this summer. We turned on the AC on the highway going out to the trail, and it took and extended amount of time to get cold. I turned the truck off to air down.
    When I turned it back on, and fired up the AC. It made a loud noise from the AC compressor area, for about 30 - 45 seconds now the AC light flashes and no cold comes out. Upon inspection it showed the AC compressor clutch was gone, and the lower idler pulley is making a bit of noise.
  5. Jun 22, 2021 at 12:26 PM
    TuckHolladay
    JT
    NJ
    I can do the clutch myself. If it’s the whole compressor I’m just going to let the shop do it. I don’t want to deal with the freon.
    so $50 gamble and it works and I save a bunch or I have to just bite the bullet
    symptoms are AC does not blow any cold air. Squeals at intervals when it is on. I removed the fuse and relay related to the AC clutch and the squealing goes away.
    cardinalsfan[QUOTED] likes this.
  6. Jun 22, 2021 at 12:50 PM
    llamasmurf
    Wes
    Northern Ontario
    The clutch is not $50
    Oh sorry it maybe after market, I bought OEM.
  7. Jun 23, 2021 at 8:20 PM
    llamasmurf
    Wes
    Northern Ontario
    Bingo bango
    AC all fixed.
    Did not require the 2 snap rings, just the spacer kit.
    Cleaned up and reused the existing snap rings.
    Here is the issue.
    AC compressor clutch melted I believe because the bearing it sits in got dirty and seized, from being so low and always subjected to every splash of anything.
    Replaced this and the bearing it sits in. Got is spaced just as required, needed the new spacer kit and existing spacers to get it perfect.
    Wannabe4x and cmoore like this.
  8. Jul 13, 2021 at 4:36 PM
    I'mNotWillieNelson
    I'mNotWillieNelson Member
    '08 4x4 manual access cab 4-cylinder
    Baseball on the shifter.
    I'm having the same exact thing!
    We're you just able to do the clutch without the rest of the compressor? If so, where did you get the part? Not funding it on rock auto. Thanks!
  9. Jul 13, 2021 at 8:29 PM
    Wannabe4x
    Wannabe4x Well-Known Member
    Conner
    EastCounty, SanDiego
    2nd gen TRD PreRunner
    Spindle lift, 285/70/17s, Methods
    https://www.tacomaworld.com/threads/ac-clutch-install-success.726846/
    Here’s an easily understandable write up I did with mine a few weeks ago. Solved my problems and AC rocks with no issues
    llamasmurf likes this.
