Ac blower fan upgrade to blow harder and colder
Discussion in '1st Gen. Tacomas (1995-2004)' started by Vstar950, Jul 19, 2023.
  1. Jul 19, 2023 at 10:56 AM
    Vstar950
    Vstar950 [OP] Member
    Does anybody know of a reliable mod like this for an 03 tacoma? ever since I bought the truck new the AC was terrible in california. Now living in Arizona it is almost useless unless you are constantly moving on the highway. I would like to have an upgraded fan that blows harder so feet and face get alot of air.
    03 tacoma
    V6 extended cab 2dr
  2. Jul 19, 2023 at 10:58 AM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
  3. Jul 20, 2023 at 6:55 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    It sounds like your condenser needs a real good cleaning your unable to remove enough heat fast enough without being in motion.
    I never heard of a high output Blower motor then I never looked have you searched at all?
    Running on high the blower motor does not move enough air Has the duct work been cleaned or Checked for leaks??
    Increasing rpm by increasing Voltage to the motor might be an interesting idea to explore .
    Finding a squirrel cage to move more air would takes lots of work and $$$
  4. Jul 20, 2023 at 9:25 AM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    Yep I agree, no air across the cond. to remove the heat, usually that's a sign of blocked air movement or a partially plugged cond. Maybe putting in some pusher fans would help especially for idle or low speed conditions. but going down the highway it should operate fine.
    Bivouac[QUOTED] likes this.
  5. Jul 20, 2023 at 9:59 AM
    foothill96tacoma
    foothill96tacoma Well-Known Member
    I would think about repair/maintenance before a "mod" per se. My 1st Gen blows very fast, cold air with the stock set up.
    OnHartung'sRoad likes this.
  6. Jul 20, 2023 at 10:03 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    ^This^
    1st gen AC’s work very well in 110+ heat when working correctly. It does not need extra pusher fans for this, OP just needs to have it checked and repaired/serviced.
