ABS Wheel speed sensor harness repair questions.
Discussion in 'Technical Chat' started by eildydar, Sep 13, 2023.
  1. Sep 13, 2023 at 9:27 AM
    eildydar
    eildydar [OP] Member
    So I didn't want to necro the old thread but I have the exact problem as in this thread. https://www.tacomaworld.com/threads/rear-abs-connector-wires-broken-help-needed.461315/ I had fixed it once using butt connectors and this was fine for a while but eventually the lights came back on. The speedometer was still working however.
    So I bought a connector with pigtails, connected it up to the harness with butt connectors again. Plug it in and now all the lights are on and my speedometer is no longer working. Does anyone have thoughts on what I can / should try next I would love to hear it. My next step is going to be to cut out the connections I made in case I got insulation in or something while making the connections.
    Also a note, I did NOT try to jump the odb like recommended in the thread because the speedometer is also not working. However if you guys think thats my missing step i'll give it a shot also.
    Thanks!
  2. Sep 13, 2023 at 9:34 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I've broken and repaired my abs wires a few times. Do you have a multimeter and know how to test for continuity? Test continuity on the new and old harness and see if you have any breaks in the wires as they can be fairly fragile.
  3. Sep 13, 2023 at 9:36 AM
    eildydar
    I have one but am a bit meh on using it. I'll find a youtube video i'm sure and start there lol.
    EatSleepTacos likes this.
  4. Sep 13, 2023 at 9:41 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It's how I learned too, it's pretty easy, you just have to figure out which settings to use on it. Continuity is testing a wire to see if there are any breaks in it or not. So if you hold a multimeter lead to either side of a wire and it beeps at you, there is continuity.
    In all the times that I had abs wire issues, it was because there was a break in the wire somewhere and I have had a 100% success rate with figuring that out and fixing it with continuity on a multimeter.
  5. Sep 13, 2023 at 10:06 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Are you sure you didn't get the wires crossed?
  6. Sep 13, 2023 at 12:09 PM
    eildydar
    LOL I'm not positive but pretty sure. I followed the diagram from the other thread and when I pulled the wire from the old connector it _looked_ correct. (note the insulation was mostly gone from the old wiring). I'm going to go through with multimeter tonight and see where I'm losing continuity
  7. Sep 13, 2023 at 6:18 PM
    eildydar
    ok so of the two sets of wires one has power and the other does not. I'm super tempted to just take it in and let them deal with it however I'm pretty sure they quoted me $750 to fix at our local dealer. I Tried to open up the wire loom as far as I could and didn't see any issues but I was running out of lihgt. Guess I'll give it a go tomorrow again one last shot before sucking it up and spending the money :) such a pain in the ass to take apart the loom under the truck with no lift but saving the money is worth it I suppose.
  8. Sep 13, 2023 at 8:19 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    What year is your truck and do you have the vacuum or hydraulic booster, I can grab a wiring diagram for your truck.
    I still bet you have wires crossed.
  9. Sep 13, 2023 at 8:37 PM
    eildydar
    2013, you can see the diagram in the other post I linked. I can't have wires crossed, they aren't connected right now and one set (white + black) has no power reading. I get voltage from Tan + Yellow however.
  10. Sep 13, 2023 at 9:45 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    It seems they labeled the pins incorrectly on that drawing.
    the White wire is Pin 1 Rear Left - and Yellow is Pin 2 Rear Left +
    Beige is Pin 3 Rear Right - and Black is Pin 4 Rear Right +
  11. Sep 14, 2023 at 10:37 AM
    eildydar
    Well you are absolutely correct. wired up like above and my abs lights are all off. My TCS light was on but driving down the block it went off on its own. Sorry for doubting you and thanks for the diagram, really appreciate it. Saved me a bunch of money :)
    6 gearT444E, HondaGM and Dm93 like this.
  12. Sep 14, 2023 at 10:43 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    No worries, glad you got it fixed.:thumbsup:
  13. Mar 17, 2025 at 3:04 PM
    PyriteTacoma11
    PyriteTacoma11 Member
    I’m having a similar problem. 2011 Tacoma TRD Sport DBL Cab 5’ bed. ABS, BRAKE, and Traction Control lights lit up on the dash. Replaced all 4 wheel speed sensors, and reset the OBD2. A day later they all came back on. Reset again, same problem. Changed all 4 sensors, AGAIN, and reset again. Still no change. Checked voltage in all 4 connections, and they’re good - 11.XX. Any ideas on next steps?
  14. Mar 17, 2025 at 3:38 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Have you even checked what code(s) it's setting? There's other things besides wheel speed sensors that can turn the lights on.
  15. Mar 17, 2025 at 5:03 PM
    PyriteTacoma11
    Yes, scanned it myself and at 2 shops. No codes showing up. Leaving me puzzled.
  16. Mar 17, 2025 at 5:14 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    If the lights are on there should be codes present in the ABS module.
    A generic OBDII code reader is only gona pull engine codes, most won't read ABS codes. You need a scan tool that can read codes from all systems or at least is capable of reading ABS codes.
    https://www.tacomaworld.com/threads/scan-tool-discussion-recommendations.834898/
  17. Mar 17, 2025 at 5:31 PM
    PyriteTacoma11
    Okay, good to know! Thank you.
  18. Mar 17, 2025 at 6:04 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Wouldn't hurt to check the brake fluid level as low brake fluid can trigger the lights as well.
  19. Mar 18, 2025 at 3:42 PM
    PyriteTacoma11
    Brake fluid is good. Received the following codes:
    B1650
    B1660
    B1826
    C0200
    C0205
    C0210
    C0215
    C1236
    C1239
  20. Mar 18, 2025 at 7:48 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    That's interesting to have signal malfunction codes for all 4 sensors and signal noise codes for the 2 left sensors and very rare, you said you replaced all of them but what did you replace them with?
    Do you still have the originals?
    The B codes are SRS (Airbag) codes.
