Abs relay
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Robert3079, Mar 22, 2020.
  1. Mar 22, 2020 at 5:21 AM
    Robert3079
    Robert3079 [OP] Member
    2007 tacoma
    Location of abs tray on 07 tacoma.
  2. Mar 22, 2020 at 5:24 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
  3. Mar 22, 2020 at 6:44 AM
    Robert3079
    2007 tacoma
    This is the abs fuse I need to know location of the relay
  4. Mar 22, 2020 at 7:20 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    There is no "ABS Relay". You are looking for something that doesn't exist, like Aliens.... or the tooth fairy.
    What is the issue and we will see if we can help.
  5. Mar 22, 2020 at 7:47 PM
    Robert3079
    2007 tacoma
    My 07 tacoma has the abs light on and a engine code of C0278 which is a open or shorted and relay.
  6. Mar 22, 2020 at 7:53 PM
    Bishop84
    Bishop84 Well-Known Member
    The relay is internal, this code is the entire ABS module 99% of the time.
    I would test for power to the ABS fuse that was shown and inspect the connector to the ABS module.
    It's insane expensive. 1000-2000$ often. Good luck.
    Jimmyh likes this.
  7. Mar 22, 2020 at 8:13 PM
    Robert3079
    2007 tacoma
    I maybe in trouble then because my fuses are good and I have 12 volts at the abs module connector. Thanks
  8. Mar 23, 2020 at 12:34 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    The relay as stated that is referenced for that code C0278 is an internal relay inside the Skid Control ECU on the ABS Unit. Not a user item, ABS Skid Control is replaced as an assembly. As stated by Bishop84 above.
    The below is the print.
    Even if you can't afford to get the unit replaced at least it is still functional with regular ( no ABS ) brakes. Unless you are in a state that requires an inspection... :rolleyes:
  9. Mar 23, 2020 at 3:16 AM
    Robert3079
    2007 tacoma
    THANKS This diagram helps alot!!!
  10. Mar 23, 2020 at 9:16 AM
    caribe makaira
    Caribbean, Puerto Rico
    Reading material
    Jimmyh likes this.
  11. Mar 23, 2020 at 10:06 AM
    Robert3079
    2007 tacoma
    Thank You This helps alot
