Abs light on after brake change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dt4x4, Oct 5, 2021.
  1. Oct 5, 2021 at 3:06 PM
    Dt4x4
    Dt4x4 [OP] New Member
    David
    2007 Tacoma SR5 4x4
    I got my brakes replaced by a local shop and the abs light came on ever since. I hooked up a obd scanner but it read no trouble codes. Anyone know what’s going on?
  2. Oct 5, 2021 at 3:20 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If the ABS light is on, there should be a code. A lot of scanners won’t read ABS codes. Do you know if yours does for sure?
  3. Oct 5, 2021 at 3:27 PM
    Dt4x4
    David
    2007 Tacoma SR5 4x4
    I don’t have my own reader so I took it to jiffy lube to get it read. According to the guy it would read the code but nothing showed up.
  4. Oct 5, 2021 at 6:01 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Since you say it happened after brakes were done I'd look closely at the wires going to the wheel speed sensors, it's possible one got torn or streched. If nothing turns up there your gona have to get the codes to know where to go.
