ABS Issue?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TRDTaco009, Jan 26, 2020.
  1. Jan 26, 2020 at 5:04 PM
    TRDTaco009
    TRDTaco009 [OP] Active Member
    Jonathan
    Colorado Springs, Colorado
    2017 DCSB TRD Off Road
    30 Inch Light Bar, Hella Stickers, Aftermarket Dust
    My 2017 Tacoma has been on the fritz lately. I'm having some sort of electrical issue causing it.
    Issue: I'll be driving and my Check ABS warning comes across the screen. Then Check Vehicle Stability Control System. Then Brake and Gas depressed Simultaneously, in that order usually. Once the "both pedals pressed at the same time comes up" the truck cuts power from the accelerator and I have to lift my foot and press it down again to get power, then it will immediately cut power again saying the same message. This usually happens until I mash the gas and accelerate pretty hard and get up to like 40 mph and 4k RPM.
    Diagnosis: I took it to Toyota for Diag and they said they arent sure what's causing the issue but I should look into replacing my brake light switch.
    Has anybody else had this problem or know what might be causing the issue? I ordered a new brake light switch and it should be here sometime this week.
  2. Jan 26, 2020 at 6:29 PM
    GillyLink
    GillyLink Well-Known Member
    2018 Cement TRD Off-road DCSB AT
    Still stock completely capable!
    Obvs a completely different vehicle but my caliber srt4 had Similar issues and it was a ABS sensor. Quick fix and good to go.
    shakerhood likes this.
  3. Jan 26, 2020 at 8:44 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    All these systems use wheel speed sensors as inputs. I'd look there first.
    Big tall dave likes this.
  4. Jan 26, 2020 at 8:47 PM
    Kevin8se7en
    Kevin8se7en Well-Known Member
    2017 Inferno OR
    I see you're in Colorado... have you had a shit ton of snow lately? My WRX did the same thing when some sensors got caked with snow. A car wash with underspray dislodged it enough to get it back to normal.
    If not, bring it to the dealer.
    GillyLink and Big tall dave like this.
  5. Jan 26, 2020 at 10:00 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    If the brake light switch was faulty the vehicle wouldn’t start at some point. As stated above...wheel speed sensors are the more likely culprit.
  6. Jan 27, 2020 at 5:26 AM
    dan33410
    dan33410 Well-Known Member
    2020 Quicksand TRD Off Road
    My previous vehicle was a 2007 Touareg and I had ABS / Traction Control light on the dash on two occasions. In both cases, wheel speed sensors were the culprit. I guess once the seal deteriorates and water/dust get in there, corrosion happens and then the sensor won't read properly, triggering the light.
    As others have said, it could simply be a bad ABS sensor as well, hopefully thats the case as I am sure thats the cheaper fix!
  7. Jan 27, 2020 at 7:52 AM
    TRDTaco009
    Jonathan
    Dealer said Brake Light Switch but idk if i believe them, and all your above comments have reinforced that. Some of my more mechanically inclined buddies also suggested wheel speed sensor.
    There has been a lot of snow lately, and the issue only happens during the winter. It was first acting up last year, but once it stopped snowing I forgot about it because I didnt have an issue all summer or fall. Weird thing is that the issue started again AFTER I washed my truck and cleaned out the suspension and wheels.
  8. Jan 27, 2020 at 8:43 AM
    dan33410
    My issues always showed up if it was raining heavily, if I went ripping through a big puddle or if I washed it. If water is sprayed in and around the affected wheel it caused the speed sensor to not read properly and a dash light. In the beginning the light would come on and then a day or two of dry weather later it would turn off. Eventually it just stayed on all the time.
  9. Jan 27, 2020 at 8:48 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    If a wheel speed sensor is faulting enough to trip the ABS light, then it should throw a code....
    TRDTaco009[OP] and Skydvrr like this.
  10. Jan 27, 2020 at 8:50 AM
    Fearthisbeard
    Fearthisbeard Well-Known Member
    Josh
    Gilbert AZ
    Taco
    Check your battery, probably going bad.
  11. Jan 27, 2020 at 8:53 AM
    Lunabird
    Lunabird Well-Known Member
    rats?
    GillyLink likes this.
  12. Jan 27, 2020 at 1:05 PM
    TRDTaco009
    Jonathan
    Battery is good, I checked it right after fuses
  13. Jan 27, 2020 at 1:08 PM
    TRDTaco009
    Jonathan
    No sign of rats, but maybe. My air filters aren't eaten and none of the wires seem damaged or corroded
  14. Jan 27, 2020 at 1:17 PM
    TRDTaco009
    Jonathan
    It really does seem weather induced to me, because it's only happened shortly after snow and most recently when I washed it. It's been wet and snowy where I live all week though. Obviously theres a bigger issue, a little water shouldnt be lighting up every warning on my dash.
