Abs fuse
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Beerline123, Jan 21, 2016.
  1. Jan 21, 2016 at 6:19 PM
    Beerline123
    Beerline123 [OP] Well-Known Member
    07 Tacoma access 4x4
    Hey. Guys our first snow is heading my way (phila) can some one tell me which fuse or fuses need to be pulled to disable abs. I've had terrible experiences with snow or ice with these brakes. Tia (a picture would be even better) 07 4.0 access 4x4
  2. Jan 21, 2016 at 8:15 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    In the fuse panel under the hood there are two Large ABS fuses ABS No 1, 50 ampere and ABS No 2, 30 ampere. Pull them both.
    Just take note that the ABS System will be disabled if these are pulled and all associated VSC, DAC, TRAC, HAC, or Auto LSD will not function.
  3. Jan 22, 2016 at 2:57 PM
    Skunkman
    Skunkman Well-Known Member
    Syracuse - Tug Hill
    2007 Tacoma Access Cab ,
    I have an 07 A/C also, and drive in the snow almost daily. The ABS on my truck is about as dangerous as anything I have ever seen. I can't even begin to apply light pressure on the pedal without it actuating and taking control of the braking. I have put a couple hundred K miles on it like this, and am prepared for how it acts, but still hate it. I keep telling myself to do that green wire ABS mod....maybe this summer. My 2010 DCLB Pre-Runner does not have the same issue, and I suspect it may have something to do with the 07 being a 5 speed.
  4. Nov 11, 2017 at 3:16 PM
    ecliff5
    ecliff5 Well-Known Member
    Brooklyn, NY
    06 Tacoma Access cab
    King Coilovers with Total Chaos stock length upper & lower control arms, Bilstein and Archive Garage shackle flip in the rear Bruteforce Fab Front & rear SOS Offroad Concepts sliders RCI skids 285/75/16 Falken Wildpeak AT3W on Pro Comps Hard Shell RTT and ARB awning on a Pinsu rack Home made storage drawer unit in the bed.
    bringing back an old thread. I have an 06 4x4 access cab 6 speed with a rear e-locker
    my ABS was going crazy on my truck, randomly kick in under light braking, then the other day I hit some bumps in the road and the abs locked on. Came to a stop and then every time I would go above 5mph the abs would kick on without even touching the brakes and stay on until I came to a complete stop.
    Pulled the ABS No.2 Fuse ONLY, not No.1 and disabled the ABS. I have the yellow ABS light and red BRAKE light on and have been driving around for a few days now and everything seems to be working great.
  5. Nov 11, 2017 at 3:22 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Does your Speedo work consistently?
    The ABS sensor is tied into the speed sensor. If something there isn't working right that could be causing ABS to kick in.
  6. Nov 11, 2017 at 3:24 PM
    ecliff5
    Brooklyn, NY
    Speedo works, it's not accurate due to tire size but it works. Just about 5mph off
  7. Oct 20, 2019 at 9:29 PM
    darcycook
    darcycook Well-Known Member
    2005 4x4 Toyota Tacoma
    I just did the fuse ecliff5 is right only No. 2 fuse 3amp not No.1 50amp ( do not know what happens if you pull No. 1 50amp ) but not needed
