ABS & Brake Warning Lights on after stuck in snow.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nichostiles, Jan 23, 2016.
  1. Jan 23, 2016 at 12:24 PM
    Nichostiles
    Nichostiles [OP] Well-Known Member
    Nick
    USA
    08 Taco Access Cab 4x4
    Hi All -
    Hopefully someone who knows more than me can help me out here.
    I was stuck in the snow for about 45 minutes in 4wd. and the ABS light and Brake Warning Lights came on and stayed on. I turned the truck off and on and they were still illuminated.
    I'm unstuck now but the lights were still on when I came inside.
    Any ideas?
  2. Jan 23, 2016 at 1:33 PM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Any digging take place in, around, or behind the wheels that might have damaged an ABS sensor?
  3. Jan 23, 2016 at 1:39 PM
    Nichostiles
    Nick
    USA
    I guess it's a possibility but not really. Are they super sensitive?
  4. Jan 23, 2016 at 1:47 PM
    08TRDOFFROAD
    Dan
    They are just pretty exposed, along with the wiring. I would check them to make sure there is no obvious damage and that the harnesses are plugged in tight.
  5. Jan 23, 2016 at 1:51 PM
    Nichostiles
    Nick
    USA
    Thanks for the info. Is there a diagram somewhere on where they're located?
  6. Jan 23, 2016 at 1:58 PM
    08TRDOFFROAD
    Dan
    https://youtu.be/YTS4ke7nViE
    At 14:10 he talks about the abs sensor and then removed it. Ours are in the same spot. Should give you somewhere to start.
  7. Jan 23, 2016 at 1:58 PM
    abarber11
    abarber11 Well-Known Member
    ATX
    2011 DCSB
    Yea wiggle the connectors a little bit and make sure they're plugged in well. It happens to me every now and then. It's the only wire/connector on the inside of each wheel
  8. Jan 23, 2016 at 2:00 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Do you have snow packed in & around the inside of the wheels?
  9. Jan 23, 2016 at 2:58 PM
    Nichostiles
    Nick
    USA
    Yeah... Your thoughts?
  10. Jan 23, 2016 at 3:00 PM
    Nichostiles
    Nick
    USA
    thank you everyone for the replies.
  11. Jan 24, 2016 at 8:16 AM
    Janster
    Jandy
    Lancaster, PA
    Remove all the snow that's packed in the wheels & around the brakes. Be careful of the brake lines/wires. etc.
  12. Jan 24, 2016 at 11:24 AM
    08TRDOFFROAD
    Dan
    Get it figured out?
  13. Jan 24, 2016 at 11:56 AM
    Nichostiles
    Nick
    USA
    Yeah just got back from the wash, cleaned everything off and got all the snow, mud out of everything and the lights went off while driving. So all good.
    I should stick to driving to the mall. Haha.
    Thanks again.
    DouginNC likes this.
  14. Jan 24, 2016 at 12:08 PM
    Clearwater Bill
    Billy
    Largo Florida
  15. Jan 24, 2016 at 12:14 PM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    those sensors/connectors are finicky. If you do a lot of wheeling in mud/sloppy terrain that is 1/4-1/2 way up the wheel, dirt and grime get in that connector and will trip it. after a deep puddle (or a rinse) it'll get that stuff outa there and turn the light off. its not something to be worried about, unless of course you actually know the wire got pulled from doing maintenance or something like that.
    if you truck sat in snow/ice and were driving in it, brine from the road plus the ice and snow easily trip that sensor. glad you found it out, but most things like that aren't anything to be concerned about...unless you know you did something physical to it). :thumbsup:
    Nichostiles[OP] likes this.
  16. Jan 24, 2016 at 12:17 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Are you TRD Off Road? If you had the diff lock engaged = ABS disabled and light on.
    Swampcollie likes this.
  17. Jan 24, 2016 at 3:33 PM
    Nichostiles
    Nick
    USA
    Thanks for the info, yeah glad it wasn't anything serious.
  18. Jan 24, 2016 at 3:34 PM
    Nichostiles
    Nick
    USA
    Oh wow I didn't know that, I didn't engage it though. Thanks for the tip.
