Abs and traction control light coming on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by double09, Jun 16, 2013.
  1. Jun 16, 2013 at 7:53 PM
    double09
    double09 [OP] Member
    Jacksonville IL
    2009 Double Cab LB TRD Package
    Side windows tinted, 8 in windshield strip, remote start, head lights
    Recently I have been expeirencing a problem that the traction control and the ABS light will randomly be on in my truck and will seem to just randomly shut off. Also my truck will not want to shift out of park this will happen with the light on or off. I did a quick search about the light and most guys had this problem after lifting their tacos' but mine is bone stock and mostly sees interstate time. Any advice on these problems would be greatly appreciated!
  2. Jun 16, 2013 at 9:15 PM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Been in the mud, water, beach recently?
  3. Jun 17, 2013 at 12:33 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Ignition ( IGN1 ) fuse. Check it.
  4. Jun 17, 2013 at 4:31 PM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    Brake light switch will cause all of those problems
  5. Jun 17, 2013 at 8:34 PM
    double09
    Jacksonville IL
    No sir to any mud or off road situations. I made a warranty appointment at the stealership for tomorrow I paid for it I might as well use it. They believe it is a "stop light switch (or sensor don't remember)" also I may be getting a new drive shaft to fix the famous wheel shake!! I will keep you updates in how it goes thanks for the input!
  6. Jun 17, 2013 at 9:52 PM
    Conex
    Conex Well-Known Member
    Not sure about Tacomas, but my LX470 (Land Cruiser) had similar issues and it was a wheel speed sensor. Pucker factor is strong at 75mph and the traction control takes over the vehicle and tries to lock up the right front wheel.
  7. Jun 17, 2013 at 10:05 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    ABS error won't cause the engine to shut down.
    A problem with the IGN-1 circuit will though.
    Brake light switch will cause ABS and traction control lights, but it won't kill the engine.
    What it will do though, is if throttle is above 25% and the switch makes contact, the engine will drop to idle.
  8. Jun 18, 2013 at 2:56 AM
    Conex
    I read the OP as the light randomly shuts off, not the engine.
  9. Jun 18, 2013 at 10:43 AM
    double09
    Jacksonville IL
    Yea just the light shuts off not the engine. Sorry for the confusion
  10. Jun 18, 2013 at 7:36 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Ahh... Could be the brake light switch then.
    Do you have cruise, and if so, does the brake cancel it, and can you verify that your brake lights work?
    Not sure about the Tacoma, but one of the ABS codes on my '95 Suburban was for brake light on without deceleration, and another code was for deceleration faster than "x" mph per second without a brake light.
  11. Jun 25, 2014 at 7:38 PM
    kai38`
    kai38` Well-Known Member
    I had this problem today also, called a friends Toyota repair shop and he said check to see if I had break lights, correct no brake lights, I went to his shop and he replaced 2 mini fuses, 10 amp one under the hood in the fuse box and other inside behind fold out storage box.
    Not sure what blew the fuses but its working again and no ABS or traction control light on dash.
  12. Jan 10, 2015 at 3:41 PM
    brycew
    brycew New Member
    Any idea which mini fuses were replaced?
  13. Jan 10, 2015 at 4:17 PM
    kai38`
    Sorry, don't remember if it was in the cab fuse or under the hood, look for tail light fuse.
  14. Jan 10, 2015 at 4:21 PM
    CamoNBlaze
    CamoNBlaze Well-Known Member
    Zach
    '09 V6, 6 speed
    I had same issue twice when I bought my 09. It turned out to be the "light actuator" both times.
  15. Apr 18, 2017 at 2:12 PM
    Rickaren
    Rickaren Member
    Rick
    Clarksville TN
    09 Tacoma PreRunner SR5
    CamoNBlaze, the ABS and the RSCA lights have come on and gone out sparaticly on my truck without me doing anything to them. When they do come on I can not shift out of park. Did you experience the same? You mention light actuator, part number? Exactly what is a light actuator and where is it on the truck? Is it the light switch on the steering column/turn signal arm? Rickaren@charter.net.
  16. Jun 14, 2017 at 9:46 AM
    furi
    furi Active Member
    Puerto Rico
    2010 TRD Sport PreRunner
    Greetings. Resurrecting the issue I have the same problem in my tacoma 2010, it turns out that sometimes it turns on the light of brake, traction control, abs and then turns them off and does not leave me a code in the computer I would like to know how I can solve that problem, because in this Topic talks about possible solutions but they do not say the right solution. Thank you
  17. Jun 20, 2017 at 6:16 PM
    furi
    furi Active Member
    Puerto Rico
    No one knows what may be happening that causes this problem
  18. Jun 23, 2017 at 10:02 AM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    speed sensor is the focus.
    furi likes this.
  19. Jun 23, 2017 at 10:17 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    If you have Techstream or other ABS scanner, you can check to see if all the sensors are working properly.
    furi likes this.
  20. Jun 24, 2017 at 7:46 AM
    furi
    furi Active Member
    Puerto Rico
    Check the speed sensors and found one that had grease, it was the passenger side of the front, it seems that when I broke the bearing of the control arm there is a dirty sensor, I hope now when cleaning it stop turning on the lights. I did that since in youtube I found a video that talks about the same problem I have and the person solved it by cleaning the sensor that was full of fat and this caused that it could not read the sensor well. Then I'll let you know if the problem was solved and thank you very much Leggo for your suggestion, since for your opinion I found the video.
