ABS and traction control light after installing lift. Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by UmbrellaTaco, Mar 4, 2018.
  1. Mar 4, 2018 at 7:07 PM
    UmbrellaTaco
    UmbrellaTaco [OP] Active Member
    Jon
    14 AC 4WD Taco
    Hey all. Just installed a 1 inch puck lift on my taco. No issues except that the ABS and traction lights are on for some reason. I had installed new coil overs and shocks before and I didn’t have this problem. I looked at other threads and the most common explanation is a pulled wire or damaged sensor. The thing is that I didn’t have to mess with any wires. The only thing I “messed” that is steering related was the steering column spline bolts. All I did was loose them, and then retight.
  2. Mar 4, 2018 at 7:09 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    The abs line gets pulled/caught/snagged accidentally. To know for sure what your code is you'll need somebody with a diagnostic tool that can read ABS codes.
  3. Mar 4, 2018 at 7:38 PM
    UmbrellaTaco
    Jon
    14 AC 4WD Taco
    Would you happen to have a picture of said wire.
  4. Mar 4, 2018 at 7:55 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
  5. Mar 4, 2018 at 8:05 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    I had a dealer recalibrate my VSC system after 4” lift spindles, that fixed it. Never came on again until I REALLY hucked the truck in AZ.
  6. Mar 4, 2018 at 8:09 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I wish I had a vacation system. :rofl:
    VSC you mean?
  7. Mar 4, 2018 at 8:12 PM
    Sterling_vH111
    Sterling
    socal
    LOL YES.
    Dang auto correct.
    I think I just found my next mod too. Installing my custom Vacation system
    Key-Rei[QUOTED] likes this.
  8. Mar 5, 2018 at 5:16 AM
    UmbrellaTaco
    Jon
    14 AC 4WD Taco
  9. Mar 5, 2018 at 5:34 AM
    desertrunner24
    Jake
    Fresno , CA
    Some
    It will work for you.
  10. Mar 5, 2018 at 5:51 AM
    WebberLander
    WebberLander Well-Known Member
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    Hard to say without out scanning the ABS module for the error code its throwing. Hopefully as indicated above, a reset and calibration of the vsc takes care of it for you.
    IF the reset doesn't help, get it scanned and let us know the code its throwing. At that point its possible it is the wire harness that has an issue.
  11. Mar 5, 2018 at 8:21 AM
    UmbrellaTaco
    Jon
    14 AC 4WD Taco
    So I gave it the ole college try, and I still got the lights on. Everything that the instructions said would happen, did happen, but my lights remain on. I guess next step is to take to dealership. I don’t have a code reader.
  12. Mar 5, 2018 at 8:25 AM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    I've had the lights come on before too.
    Unhooked the battery for like 15 min. Give that a try. It worked for me.
    GOod luck.
    Az
  13. Mar 5, 2018 at 8:29 AM
    WebberLander
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    That's a bummer. If you have time and want to save a bit of money from a scan by the dealer (assuming they'll charge you to scan it), you can purchase an ODBII scanner, download and install techstream.
    Here is the scanner I purchased on Amazon: https://www.amazon.com/Fangfei-Mini...d=1520267193&sr=1-2&keywords=toyota+obdii+usb
    Here is a writeup on how to install techstream 12.00.127: http://blog.obdii365.com/2017/04/07/install-toyota-techstream-12-00-127-on-windows-7/ <<<< this part can be a little tedious but if you take your time and do it right, you'll have a scanning tool for your Tacoma just like the dealer has.
    Good luck and hope you figure it out.
  14. Mar 5, 2018 at 10:18 AM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    OP, a tire shop pulled the code for me when i went in for my alignment post lift.
    They told me the code description was something like "no continuity" and it even said driver side.
    I took apart the harness, soldered in wore where it pulled apart, hooked it back up in the correct orientation and it fixed it. Below is the thread i made for the same thing. A fellow member helped me out with the orientation of the wires and the sensor so that could be useful for you if you need to fix a harness.
    https://www.tacomaworld.com/threads/abs-wire-no-continuity.488429/
    UmbrellaTaco[OP] likes this.
  15. Mar 5, 2018 at 1:32 PM
    UmbrellaTaco
    Jon
    14 AC 4WD Taco
    Went to dealer, and it would cost 80 bucks just to diagnose the issue. Went to autozone and the guy plugged in the code reader and said my truck wasn’t giving out any fault codes at all (lights still on).
    Since the truck is driving fine, I will take a look at the harness (if I can find it lol) , also the OBD sensor will be coming in, sounds like a neat tool to have. Thanks everyone for the help
  16. Mar 5, 2018 at 1:55 PM
    Chase8059
    Chase
    ESVA
    The harness connects to the abs sensor down by the wheel. Then it will be connected up above the UCA i believe. It's literally just a black rubber coated line with two wires inside.
  17. Mar 5, 2018 at 2:07 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    ABS codes will likely not be able to be read by your standard code reader.
    You likely damaged one of the ABS wires when installing your lift, its rather common.
    Also why did you have to mess with the steering column spline bolts.... the only other thing that could cause codes to be thrown is messing with the steering wheel center and subsequently messing with its angle sensor.
  18. Mar 5, 2018 at 2:29 PM
    UmbrellaTaco
    Jon
    14 AC 4WD Taco
    To be honest the online reason I loosened the bolts on the steering spline is because the instructions said so. It was a toytec 1 inch body lift.
    I will look at harness
  19. Mar 5, 2018 at 2:48 PM
    Chase8059
    Chase
    ESVA
    This is one end of the harness in the engine bay below the driver side fuse box, near the front breather.
  20. Mar 5, 2018 at 3:12 PM
    nd4spdbh
    SoCal
    OH A BODY LIFT!
    You likely tore ABS wires when you lifted the body on the frame.... or airbag sensor wires.... get this checked ASAP!
