ABS active on sharp turns?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by IDTaco, Aug 27, 2019.
  1. Aug 27, 2019 at 10:56 AM
    IDTaco
    IDTaco [OP] Member
    Jeff
    2014 PreRunner DCSB
    Took a trip up in the mountains this last weekend and the beginning of the trip is winding asphalt road with speed that varies from 35mph to 60mph curves. There was one sharp 35mph turn that I may have taken a little to quick on the way up that made it feel like the ABS may have activated and started to apply breaking to what felt like the driver front tire on a left hand turn. Once I exited the turn it went away. I didn't notice any dash lights since my eyes were on the road. Same thing happen later in the day on the way down but this time it was a right hand turn, not the same spot in the road. Not sure if it matters but it's a 2014 PreRunner with 5100's / 885 coils / SPC UCA in the front and HD Dakar in the back.
    Just curious if anyone else has experienced this.
  2. Aug 27, 2019 at 10:57 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Probably just your traction control kicking in. Feels similar to ABS.
    It's all the same system I believe.
    whatstcp likes this.
  3. Aug 27, 2019 at 10:58 AM
    ronixtaco
    ronixtaco Instagram @la_swampyota
    Brandon
    Central Louisiana
    2021 AG TRD OFFROAD
    possibly your ABS line being pinched??? my 15 had done the same thing and it was the abs line being pinched and eventually broke the line.
  4. Aug 27, 2019 at 10:59 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    If you lifted the weight off one wheel, and it lost friction with the road surface, yes ABS would modulate your brakes as it sensed that wheel stop rotating or about to.
  5. Aug 27, 2019 at 11:11 AM
    IDTaco
    IDTaco [OP] Member
    Jeff
    2014 PreRunner DCSB
    That's kind of what I was thinking but I've never experienced it before. Truck is lifted, going into a corner a little too hot, inside front tire lifting but not loosing contact. ABS trying to do it's job.
  6. Aug 27, 2019 at 11:12 AM
    IDTaco
    IDTaco [OP] Member
    Jeff
    2014 PreRunner DCSB
    I'll have to take a look at that tonight. Was going to jack up the front and and move the front wheels to feel if the wheel bearings are going bad.
    ronixtaco[QUOTED] likes this.
  7. Aug 27, 2019 at 1:07 PM
    Westside
    Westside Southbound
    JT
    Nor Cal, East Bay
    TRD Sport 4X4
    VSC is activating. It's common on lifted trucks with larger than stock size tires. You can search the 2nd Gen forum for exhaustive reading and a few options for making it not happen.
    Is the lift a new addition? That's when it's first noticed and usually happens on freeway on or off ramps - where turning/g-force and higher speeds, with larger diameter tires than stock can trigger a VSC reaction.
    Best of luck
    SC4333, alexplb, whatstcp and 2 others like this.
  8. Aug 27, 2019 at 1:17 PM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    Time to recalibrate the Traction Control Computer. There is a thread on recalibrating VCS - all thats needed is a level ground in all directions and a bare-wire to jump across the pins in the OBDII port.
  9. Aug 27, 2019 at 3:17 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    This happens nearly everyday at a curved off-ramp that I always take too fast. Feel the brake pedal pulsing... I now consider it a daily test of the system. No problems with the truck.
  10. Aug 27, 2019 at 4:31 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  11. Aug 27, 2019 at 5:03 PM
    blenderdriver
    blenderdriver Inflamed Member
    Todd
    texAss
    Magnetic Grey 2010 4 Door, 4X4, Long bed.
    Powered by one tailgate mounted CFM56–7 engine. The engine is a dual–rotor, axial–flow turbofan engine capable of producing 27,000lbs of thrust. Why yes, my tailgate is slightly bowed in.
    My truck was doing this when my front left wheel bearing started going bad. Once the bearing was replaced it stopped.... Can only assume they were related....
    Edit, only did it in a right turn.
  12. Aug 27, 2019 at 5:47 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I had this same thing happen a couple of weeks ago in a similar circumstance. I think it's a normal reaction of the VSC system. I'm pretty sure my inner rear tire lost traction.
    I considered it normal.
  13. Aug 27, 2019 at 5:49 PM
    Thuguon2.7
    Thuguon2.7 Cheeehuuu
    J
    SoCal.
    ‘15 1GRFESR5AC
    It’s normal . It’s happens to me in the rain and in the snow . Just safety
  14. Aug 27, 2019 at 6:33 PM
    Tacomafella
    Tacomafella Member
    Nik
    Lake Elsinore California
    2013 Tacoma TRD sport
    Bilstein 5100's Method grid 309 Bfgoodrich k02 CBI aluminum skid plate Aero turbine muffler
    My truck was doing the same thing coming down big bear that was a few months ago and hasn’t done it since.
  15. Aug 28, 2019 at 8:44 AM
    IDTaco
    IDTaco [OP] Member
    Jeff
    2014 PreRunner DCSB
    Thanks for the replies. Makes me feel better knowing that it's happened to others under the same circumstances.
    Checked the ABS lines and the front wheels don't have any play so I don't think the wheel bearings are going.
    Thanks again for the piece of mind.
    blenderdriver likes this.
  16. Aug 28, 2019 at 9:20 AM
    Westside
    Westside Southbound
    JT
    Nor Cal, East Bay
    TRD Sport 4X4
    Losing traction in wet/icy conditions or on dry pavement (less common) is where the VSC is intended to take over.
    Using feedback from the Yaw-rate Sensor, the VSC computer controlling ABS pump applies braking to individual wheel(s) help correct a slide or fishtail of the vehicle. There are plenty of YouTube vids that demo how this works.
    What the OP is experiencing is not what the system should do and is a result of the mods. Anyone with this issue should re-calibrate their VSC computer
    SC4333 likes this.
  17. Aug 28, 2019 at 10:18 AM
    IDTaco
    IDTaco [OP] Member
    Jeff
    2014 PreRunner DCSB
    Thanks for the info. Just read thru a lot of this post and will be doing this tonight.
    https://www.tacomaworld.com/threads...ibrate-your-vsc-computer-the-easy-way.467485/
    Combination of the lift and the caster being pushed forward with the SPC UCA may be the cause. Funny thing is when I was reading threads regarding suspension and lifts I never ran across anyone mentioning a re-calibration of the VSC computer or I would have done this earlier.
    Thanks again.. Love TacomaWorld
    Westside[QUOTED] likes this.
  18. Sep 13, 2019 at 5:58 PM
    alexplb
    alexplb Well-Known Member
    been there done that... try to replicate the same thing maybe going around a circle see if it kicks in... my guess is traction control, mine has been doing that in similar situations you've described after a lift/tires. Pretty damn annoying and yes I've completed the VSC reset even at the alignment rack.
  19. Sep 13, 2019 at 6:00 PM
    alexplb
    wonder if crossing the wires like some of the posts suggest does the same thing as re-calibration at the alignment shop. Shop advised they've done it but my issue still comes up on higher speed or sharper turns. Not a pleasant experience lol
  20. Sep 15, 2019 at 7:17 PM
    IDTaco
    IDTaco [OP] Member
    Jeff
    2014 PreRunner DCSB
    I recalibrated the VSC computer but I'm not normally in the situation so only time will tell if it worked for me.
