About to do a 200,000km (125,000miles) service at Toyota. What costs should I expect?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by comradeshrek, Mar 3, 2022.
  1. Mar 3, 2022 at 4:46 PM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    'The previous owner had the entire bottom of the vehicle sprayed with a thick black rubber-like coating to protect it from rust'.
    This is from the OP.
    My first thought - your fucked.
    Is this not the biggest RED flag, other than purchase from a used car lot.
    Previous owner prob knew it had frame rot, undercoated, got it dirty and traded it in. Used car lot picked it up from auction house.
    Can't wait to hear what condition the frame is really in. Much good luck to you and I hope I'm wrong.
    Ohh and find a good local mom n pop garage for repairs/maintenance. They will appreciate you.
  2. Mar 3, 2022 at 6:08 PM
    Chris2009
    Chris2009 Well-Known Member
    Massachusetts
    2013 Reg Cab 4x4
    What are the chances you can remove the majority of the undercoating? I’m guessing the used car dealership saw extensive rust, had no idea about the extended warranty and caked it on themselves. Here’s hoping this works out for you one way or another.
  3. Mar 3, 2022 at 6:45 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    You should be able to fairly easily complete the following - throttle body cleaning, coolant flush, power steering flush, rear diff flush, oil change.
    Slightly more difficult - replace spark plugs, flush brake fluid, replace accessory drive belt
    Most difficult would be the transmission, drop the pan, replace the filter, reinstall the plan, refill the trans, drain and fill two or three more times to get all the old fluid out.
    You should be able to do most of that with the help of a semi mechanically skilled friend over a weekend.
    Honestly its not worth paying a indie shop or dealer for something as simple as a rear diff flush.
  4. Mar 4, 2022 at 6:40 AM
    comradeshrek
    comradeshrek [OP] Well-Known Member
    Artie
    2011 White Tacoma TRD Sport
    Very helpful, thank you!!!
  5. Mar 4, 2022 at 6:42 AM
    comradeshrek
    Artie
    Sooo this hits home. The used car lot DID actually pick it up from an auction house. After purchase, I took it to my buddie's small shop and he did do a rough frame inspection (hit it in a bunch of places to check for holes/rot) and didn't see any issues. Maybe the dealership can do a better inspection
  6. Mar 4, 2022 at 6:47 AM
    comradeshrek
    Artie
    This is some nightmare shit. Hope you gave them some hell after!
  7. Mar 4, 2022 at 7:44 AM
    Leomania
    Leomania Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    Check out your springs and shocks, if they are old/original, consider replacing them before getting that alignment. On my 2011, they were original and very much needed to be replaced. Even the fairly new TSB leaf packs are not very good; one of mine (drivers side) is slightly inverted with nothing in the bed.
    Check the vent hoses on the transfer case and front differential 4WD actuators. Make sure they are not cracked where they connect. Check for excessive play in the center bearing on the driveshaft. Check all of the spinny bits that the serpentine belt goes around, idler and tensioner pulleys in particular.
    Do a search here on TW and look for threads regarding rust. There are common places that tend to be the first/worst and you want to pay close attention to those.
    Good luck, let us know how it goes. And enjoy your new Taco!
  8. Mar 4, 2022 at 7:52 AM
    comradeshrek
    Artie
    Thanks very much for these tips, super helpful! Will look into this.
  9. Mar 4, 2022 at 9:01 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    $320 bucks for oil, plugs and filters and all that other shit? That is a great deal.
  10. Mar 4, 2022 at 10:11 AM
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
    Why in the world would you go to a dealership for maintenance? Maybe you live in a wilderness area but I’d look for an independent shop with factory trained mechanics. A shop that’s been around and has a good reputation. Dealerships are nothing more than a training ground for mechanics and the good ones leave soon as possible so you are left with rookies and those who cannot function by themselves. If they will not even quote you a price that’s a warning you might be getting ready to take a severe fucking.
    look for a good independent
    eherlihy likes this.
  11. Mar 4, 2022 at 10:14 AM
    Gen2 Man
    Midwest
    07 Sport DCLB
    Sounds more like they bent him over
  12. Mar 4, 2022 at 11:42 AM
    comradeshrek
    Artie
    Going to the dealership because I need an alignment done, and the machines Toyota has are better than the one my buddy has (he's an independent mechanic and advised me to go to Toyota for this). They're just trying to tack on all this servicing and I want to squeeze it out of them what exactly they want to do, so I'm asking what to expect.
  13. Mar 4, 2022 at 11:56 AM
    TacomaMike37
    13' DCLB MGM
    If you don't think that is a solid price then you should lay off the acid.
  14. Mar 4, 2022 at 12:36 PM
    No Shoes Nation
    Listen, at least your buddy is honest and telling you he can't do the alignment. BUT don't go to a dealer. FIND, as local as you can, a mom n pop garage. They will be honest with you and can probably do the alignment.
    FURTHERMORE, don't do anything until you have confirmed from a trusted source that the frame is OK.
    Good luck, you will need it.
  15. Mar 5, 2022 at 8:58 AM
    #35
    Gen2 Man
    Midwest
    07 Sport DCLB
    Sounds like voice of experience there chief were you tripping when you were violated?
  16. Mar 5, 2022 at 10:54 AM
    #36
    Jp5385
    Jp5385 Well-Known Member
    2014 TRD Sport V6 4x4
    Hey OP what you need to do to get that rubberized undercoat off is spray the whole undercarriage with Fluid Film or Krown. Inside the frames and outside. The FF or Krown will seap underneath the coat and it’ll eventually soften the rubberized undercoat and get to the rust and it’ll also make the undercoat come off eventually. You should do this at least once a year. Not sure where you live but this will kill two birds with one stone. It’ll protect you from rust and it’ll eventually soften the undercoat so you can take it off easier. Read up on this I did a lot of research about that rubberized undercoat crap. Watch a video on YouTube South Main Auto Krown and he talks about it also how their product weakens the rubber crap.
    Also all these repairs people are telling you to do I would honestly just change the rest of your fluids and just change your lower ball joints and fix stuff that breaks after that. It’ll cost you a lot to do all those repairs at once.
  17. Mar 5, 2022 at 12:14 PM
    #37
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    FWIW I never quote maintenance stuff over the phone. There may be other things that need to be done that aren't on the list, some of things on the list might be fine. Any shop that quotes a bunch of maintenance over the phone without seeing the car is going to replace everything no matter what, even if the plugs are fine, filters are clean, etc
    I charge 1 hr to inspect the vehicle, I'm taking into account what the manufacturer recommends and I've got my own list in my head of items to check
    Any estimate given over the phone beforehand is a worthless estimate. There's no value in price shopping if nobody has looked under the hood yet
