a43d transmission options
Discussion in '1st Gen. Tacomas (1995-2004)' started by greentacomastertech, Jun 16, 2018.
  1. Jun 16, 2018 at 7:13 PM
    greentacomastertech
    greentacomastertech [OP] New Member
    1999 tacoma sr5 2wd 2.4 auto a43d transmission
    I have a 1999 Tacoma 2.4l 2wd with a a43d automatic transmission that only has 1st and a little of 2nd gear left. Looking for what all other transmissions will fit without major modifications. I can add wiring to accommodate a lockup convertor if needed. I have been told that an a340e will possibly fit but would like to hear it from someone that has done it. Model #'s and years and engine sizes of possible donors please. I think I can swap bell housings if needed. My transmission is with a slip yoke not a flange for driveshaft. Can a flange be unbolted and put a slip yoke in its place or can a flange be put on in place of slip yoke on my driveshaft?
    Thanks for any info.
  2. Jun 16, 2018 at 8:54 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Any reason why you don’t just get another A43D?
  3. Jun 16, 2018 at 9:59 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    convert to 5-sp? :)
    BassAckwards likes this.
  4. Jun 16, 2018 at 10:24 PM
    greentacomastertech
    Local availability is reason for looking for other options that would fit. Also had been told by one wrecking yard that a340e was a heavy duty option that they did have. the serial number on theirs showed 2004 (04br-17738)and my info at that time showed only good thru 2000 and only a43d. Did not appear to match after 183 mile trip to pickup. Mine is still in truck so harder to compare and I thought someone might know already.
  5. Jun 16, 2018 at 10:26 PM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
  6. Jun 16, 2018 at 10:26 PM
    greentacomastertech
    I need to stay automatic because wife won't drive a stick.
  7. Jun 17, 2018 at 10:57 AM
    BartMaster1234
    Tyler
    Flux Capacitor
  8. Jun 18, 2018 at 3:31 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    I should add the differences in 5-lug 2.4l transmissions are as follows:
    1995-2000: A43D, this was the column shift model
    2001-2003: A44D, this was the floor shift model
    I believe they’re exactly the same in exception of the shift linkage, but I could be wrong.
    The A340E very well may be able to fit. The earlier 5-lugs with the 5VZ-FE v6 was mated to the A340E, as it is in 6-Lug trucks.
    The 2RZ is basically identical to the 3RZ in exception of the top end design, so it may fit.
