A340e built transmission questions!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by farmer_kyle, Nov 20, 2018.
  1. Nov 20, 2018 at 11:53 PM
    farmer_kyle
    farmer_kyle [OP] Well-Known Member
    2004 Tacoma sr5
    3.5" (adjusted to 4.5") fabtech suspension lift. 15x8 procomp 252 crawlers. 32x11.5 BFG Ko2's.
    Hey guys, so I’ll soon be making an order of the parts required to make 700+ hp on my 5vz motor. I’m not even going to think about testing my stock (with the exception of a shift kit) transmission at that kind of power. She held up alright at 420hp and then my oil pump failed and i spun a rod bearing. Moral of the story: i would like to keep the a340e (or a variation of it) in my tacoma and just fully build it. Yes, I’m aware that a th400 trans would be cheaper. Does anyone know where to locate performance parts for these transmissions? Apparently a variation of the A340e came in the mk4 Supra’s. Any help would be appreciated
    Brice likes this.
  2. Nov 21, 2018 at 1:28 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
  3. Nov 22, 2018 at 3:24 PM
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    Where are you located? I have two A340e's from Toyota Aristos that came with GTEs I bought. This has me thinking...
    https://en.wikipedia.org/wiki/Toyota_A_transmission#A340E_(30-40LE)
    Hmmm, wonder if the 5vzfe bell-housing bolts to this version of A340, in which case I'll be keeping one of these trans for myself! Also wonder if the electrical connectors are the same, and the wiring/pinnout is the same.
  4. Nov 22, 2018 at 10:12 PM
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    May be worth talking to these guys. https://www.inductionperformance.com/products/atf-stage-iii-built-toyota-a340e-transmission
  5. Nov 30, 2018 at 4:12 PM
    BlackSportD
    Los Angeles
    IMG_20181130_155536.jpg Sitting on two Aristo GTE autos and their torque converter if anyone wants to give a swap a try (in SoCal). I'd give it away darn near next to free, the only other application are GS3/400 guys that want to beef up.
  6. Nov 30, 2018 at 4:30 PM
    tony2018
    tony2018 Well-Known Member
    hm, looks a bit diff but from what i cam tell I would suggest swapping pans, bell housing and compare valve bodies.
  7. Nov 30, 2018 at 5:03 PM
    94jdmeg6civic
    94jdmeg6civic Well-Known Member
    David
    Orlando,Florida
    2001 Tacoma dbl cab long travel
  8. Nov 30, 2018 at 5:13 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Please make a build thread. I’m really interested to hear about your current setup and the new motor and transmission build.
