A tip for all the DIY's that grease their own zerks.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Markcal, Oct 11, 2018.
  1. Oct 11, 2018 at 3:40 AM
    Markcal
    Markcal [OP] Well-Known Member
    Most of the DIY's on TW know this, when I first started doing my own lube this tip would have saved me much headache. After greasing a zerk I would try to pull the nozzle straight off and at times needed to use pliers to get it off. I just did my zerks yesterday and it was so much easier when you tilt the grease pump nozzle 45 degrees to remove it. I used to dread doing mine but using that technique, as well as using this LocknLube greasing fitting when doing the hidden 4x4 zerks. Here: https://locknlube.com/
  2. Oct 11, 2018 at 3:51 AM
    freeriderchad108
    freeriderchad108 Well-Known Member
    Boston
    2016 Tacoma TRD Sport Silver
    A few minor things...
    Have these at work on my dewalt 20v grease guns. They work pretty well.
    dreadedyota likes this.
  3. Oct 11, 2018 at 3:58 AM
    Markcal
    I agree the two zerks up front on the 4x4 leave very little room and that LocknLube adapter is what the zerk-lube doctor ordered... so much more pleasant to do.
  4. Oct 11, 2018 at 4:19 AM
    Catcrazed
    Catcrazed Love is Dogs and Toyotas
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    91 Flatbed, 4.88's, ARBs, SAS, 3.4 Swap, 35s, M8000, lots lights, Aux tank, Protech
    Dewd, you just blew my mind.
  5. Oct 11, 2018 at 5:03 AM
    freeriderchad108
    Boston
    I've put probably 200-300 tubes of grease through each gun (4 guns in rotation) this past year. They're not leaking unless the zerk is scratched or broken!
    8/10 would recommend.
    10/10 would be coming up with a way to not need grease...
    Biscuits likes this.
  6. Oct 11, 2018 at 7:44 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    And purchased.
    Those front zerks are even harder to access once you add all the skid plates :cookiemonster:
    This has pissed me off since day 1 of owning the truck and realizing I can grease dat shaft. So hard to get the gun to seat correctly and put the grease in.
  7. Oct 11, 2018 at 7:46 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    yep...them zerks can be a PIA.....
  8. Oct 11, 2018 at 8:00 AM
    Markcal
    That was my thoughts before using the LocknLube, included with it is a kit to rebuild the adapter if needed. I was always in fear of snapping off a zerk too.
    llamasmurf[QUOTED] likes this.
  9. Oct 11, 2018 at 8:02 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I got the kind of fitting that you twist lock onto the zerk. Then twist the other way to release. It works well enough, if I didn't own it already, I'd get the recommended one in this thread. looks much better actually.
  10. Oct 11, 2018 at 8:03 AM
    Markcal
    What part caused your mind to blow?
  11. Oct 11, 2018 at 8:28 PM
    Catcrazed
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    Lol consider myself a pretty savvy dude. And I've never seen these before.
    Gotta get me one, looks awesome.
    Biscuits and Norton like this.
  12. Oct 11, 2018 at 8:45 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    +1.
  13. Oct 12, 2018 at 1:26 AM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    What the hell is a zerk
  14. Oct 12, 2018 at 1:39 AM
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    TRDSport10, Crom, Norton and 2 others like this.
  15. Oct 12, 2018 at 1:42 AM
    lvs2rock
    lvs2rock Well-Known Member
    N. Cali
    96 Taco 2RZ-FE auto
    grease fitting- (sometimes called a nipple) but usually referred to as a 'zerk'.
    edit: evidently the term 'zerk' may come from the inventors' name; I had written that 'zerk' was short for something
  16. Oct 12, 2018 at 2:39 AM
    Crow Horse
    Crow Horse Well-Known Member
    Central NY
    2012 DCSB TRDOR
    The lock n lube works great! On our 2012 it worked for all the zerks. Our 2015 proved to be a little more difficult. I used their needle adapter on the front seems and it was easy peasy.....
    Norton and Biscuits like this.
  17. Oct 12, 2018 at 7:09 AM
    xaircav
    xaircav Well-Known Member
    Bill
    Wheat Ridge, CO
    '10 TRD Access Cab 6 speed manual
    TRD intake, skid plate, cat back exhaust and short throw shifter. Bilstein 5100 leveling front and 5100 shocks rear. 32” Falken WP AT4W tires on Gen 3 wheels.
    The zerk grease fitting was invented by Oscar Zerk of the Alemite Corporation in 1929.
  18. Oct 12, 2018 at 8:35 AM
    Norton
  19. Oct 12, 2018 at 12:08 PM
    Rollingstoned
    Rollingstoned Well-Known Member
    How often do you grease the zerks? I have a 2013 with 30.000 miles. Is it mandatory? Ive never heard of anyone doing this faithfully lol
  20. Oct 12, 2018 at 12:47 PM
    Norton
    I do mine when I change the oil, which ends up being about once-a-year.
    FWIW, I consider it as "mandatory" as changing the oil.
    JGO, Biscuits and Markcal[OP] like this.
