A/t oil temp light on!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by buzzard1992, May 11, 2012.
  1. May 11, 2012 at 11:33 AM
    buzzard1992
    buzzard1992 [OP] Yep
    Alex
    Summerville, SC
    01 4wd trd, 255/85/16 km2s
    5100's with eibachs. And 255/85/16 km2s
    I was drivin down the road and my at oil light came on then my truck shut off. What do I do? It won't start up
  2. May 11, 2012 at 11:46 AM
    buzzard1992
    Alex
    Summerville, SC
  3. May 11, 2012 at 11:50 AM
    Blasphemous
    Blasphemous Well-Known Member
    San Fernando Valley, CA
    2012 TRD Sport DC 4x4
    TRD SC, Stealth Pulley, DTLT Headers, URD MK3 Catback Exhaust, AFE II Intake
    This definitely won't solve the problem, but might help you get to a safer spot.
    Unplug your battery, wait a while, plug it back in.
  4. May 11, 2012 at 11:51 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Im no expert but oil light usually means oil pressure is gone. Do you have oil on the dipstick?
    Edit: I failed to read the title and thought you meant engine oil light sorry. Not a clue on trans temp light sorry
  5. May 11, 2012 at 11:58 AM
    buzzard1992
    Alex
    Summerville, SC
    Yes i oil on the stick. it shows its at a good level. i let it cool down for about 30 minutes and tried to start it up. it started and i went all the way home and no light came on. Any thoughts on why that may have happened?
  6. May 11, 2012 at 12:02 PM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    that's a little unnerving. Is your trans oil still nice and red? maybe time for a series of drain and fills. Or it could be an electrical thing. I'd consider going to the dealership for something like this. Something in the trans may be clogged, inhibiting the circulation, and hence the cooling, of the transmission oil.
  7. May 11, 2012 at 12:07 PM
    buzzard1992
    Alex
    Summerville, SC
    Someone also told me in the toyota manual it says that if that light ever comes on you should pull over and rev motor to 1500rpms every so often and then it should go off. I didnt try this because when i tried to start after 30 minutes the light did not come on and i drove 15 minutes home with no issues. When i was riding down the road i was makin a U turn and picked up speed pretty quick. the rpms went to 5k when i did that and when i let off the gas at the speed limit the light came on and shut off. Maybe me doin that had something to do with it?
  8. May 11, 2012 at 12:10 PM
    buzzard1992
    Alex
    Summerville, SC
    Yeah I checked it while it was off. It was nice and red. Its never happened before and I plan to take it to the dealership today or tomorrow
  9. May 11, 2012 at 12:59 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Auto trans is cooled by the radiator. If your coolant is hot and the trans is under heavy load (especially if it's slipping), it can overheat the fluid.
    That's why the manual says to pull over and rev the engine.
    Pulling over and putting it in neutral disengages the clutches and hydraulics so the heat source is removed. Revving the engine speeds the front pump and cycles the fluid through the radiator, and the engine fan draws air through.
    Might want to have the radiator checked/flushed (including the trans cooling lines) and change the trans fluid for good measure.
  10. May 11, 2012 at 1:04 PM
    buzzard1992
    Alex
    Summerville, SC
    Thank for your help! I also just popped the hood an noticed that my coolant in the resivior tank is above the full line. Could this also be why this could have happened?
  11. May 11, 2012 at 1:08 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Overfilled is not bad... but my concern would be "where did it come from"?
    The level in the reservoir rises and drops with the temperature of the engine. When hot, excess coolant will vent into the can, and when cool, the coolant contracts and draws from the can to maintain the radiator at the top of the cap.
    If your coolant level has suddenly started running higher, something has been "added" to the cooling system. If the trans cooler has failed, it can allow for an exchange of coolant/ATF, which will contaminate the coolant AND the trans.
    Same way a head gasket or cracked head/block can cause oil and coolant to cross-contaminate.
  12. May 11, 2012 at 1:12 PM
    buzzard1992
    Alex
    Summerville, SC
    Well I noticed that it was at that level when I bought the truck 3 months ago. And its ran fine since. Once my trucked started it ran perfectly fine like it had before the light came on
  13. May 11, 2012 at 1:54 PM
    buzzard1992
    Alex
    Summerville, SC
    Just talked to Toyota. I told them exactly what happened and they said that when I went around that U turn I shifted my transmission fluid enough to where the sensor showed I had low fluid and then shuts off the truck
  14. May 11, 2012 at 3:33 PM
    x2468
    that's weird. Very misleading to have the "A/T TEMP" light come on when it thinks the fluid is low. A fluid being low and a fluid being too hot is a big difference.
    Anyhow, I'm guessing your trans oil must be on the edge of being low? I whip around u-turns and have never had that happen.
  15. May 11, 2012 at 3:45 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    +1
    You should not uncover a "low fluid" sensor unless you're on your side.
    Your suspension and tires are not capable of running the skidpad at 1g, and it takes 1g to push the fluids over at 45 degrees.
    Fully warm the trans (nice, 10 mile drive), stop on a level surface, shift through all positions, pausing for a few seconds each time, place in park, and check the fluid level with the engine still running.
  16. May 11, 2012 at 5:48 PM
    buzzard1992
    Alex
    Summerville, SC
    Well he said that it's a safety thing and that's why the light came on. My truck had been on maybe 5 minutes when that light came on. So I don't know. But I also took a 30 minute drive an drove normal and it didn come on and nothing sounded different
  17. May 11, 2012 at 6:30 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I'd still check your fluid levels.
    It should not have been uncovered and come on from a hard corner.
    I'm not even sure the 1st gen has a low ATF sensor.
  18. Mar 20, 2016 at 10:27 AM
    tacomaniac81
    tacomaniac81 Active Member
    salvadorean
    Houston tx
    05 PreRunner silver
    Plasti dip headlights eyelids,plasti dip front bumper,to be continued.....
    Ok i know this is a old thread but i have a 2012 tacoma i purchaased a week ago cash private seller,and the exact same thing happened to me..pulled a u turn and minutes later truck died showing a/t oil temp light and check engine i belive,did you ever figure out the problem??
  19. May 7, 2016 at 2:34 PM
    2010tundra
    2010tundra Member
    Raul
    2010tundra
    N/a
    The same thing happened to my wife a few day's ago. The a/t oil temp came on the rpms just dropped she turned off the truck hopping that it would reset itself but didn't it would crank but wouldn't start. Long story short I had it towed multiple times to my home to mechanics . Mechanic couldn't figure it out neither could his electrician . So I called my brother in law that use to work for lojack and other gps company he did random test we pulled off the fuel hose and I cranked it he said it wasn't passing any fuel so he figured it wasmy ffuel pump. He asked if the truck had gas the gauge read 1/4 tank so we dropped the gas tank and it was bone dry that was the problem the whole time. We tested fuel pump it worked we put the tank back on added gas cranked it until started. Hopefully this helps . ..
  20. May 7, 2016 at 3:08 PM
    2010tundra
    2010tundra Member
    Raul
    2010tundra
    N/a
    Hi there the same thing happened to my wife just a few day's ago I'll tell you what the problem was first then the symptoms. OK so the problem was she ran out of gas so the a/t oil temp and engine light came on the fuel gauge read 1/4 so that along with the lights through everyone off myself ,mechanics ,electricians the code readers couldn't even pick up a code even though the engine light was on. So I called my brother in law he is a awesome electrician after a few test with in 15 minutes he found the problem.so after several test he said let's see if the fuel pump is working , so we disconnected the fuel hose he asked me to crank it so I did and no fuel was came out, so he said it was my fuel pump we drove to auto parts store it was almost $500. He said that was to much let's see if we can wake yours back up by tapping it and cleaning it so he tapped on the gas tank then we cranked it nothing , so then he suggested let's drop the tank so we did it took about 10 minutes when we pulled the fuel pump out that's when we discovered that it was bone dry even though the gauge read 1/4. Regardless we tested the fuel pump it worked so we put everything back added fuel and cranked it until she started right up. Saved me $400. Gave my brother in law $100. Not that I'm cheap that's all he wanted .. so hopefully this helps out guys. Just a few day's ago I was on you tube Internet trying to find the solution. Since I didn't find it I joined this website to share my experience .. hope to learn from others as well ...
    take care ladies and gentlemen ..
    greghansen123 likes this.
