A.R.E. Overland Truck Cap - Reviews/Pics?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mapnfor4x4, Sep 20, 2013.
  1. Sep 20, 2013 at 12:03 PM
    mapnfor4x4
    mapnfor4x4 [OP] Member
    Does anyone have one of these on their rig yet? If so, let's see some pics and a brief review/thoughts. Even if you don't have one, how do you think this will look on a 2013 White SB with graphite gunmetal Konig Six Shooter wheels?
  2. Oct 9, 2014 at 10:01 AM
    Mike90
    Mike90 Well-Known Member
    Black Hills, SD
    '07 DCSB, '79 FJ40, '18 Subaru Crosstrek, ‘23 DCSB
    BUMP! I am curious too!
  3. Oct 9, 2014 at 10:13 AM
    Pigpen
    Northwest Montana
    So, this is an "offroad" style topper? Doesn't seem to offer any features, unless you count the spray on bedliner...
  4. Oct 9, 2014 at 11:13 AM
    ryusan
    ryusan Active Member
  5. Oct 9, 2014 at 11:28 AM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    I was debating between this model and the CX. I found the bed lined stripe look kind of off
