A-pillar RAM mount Write Up for 3rd gens
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nvnv, Aug 18, 2017.
  1. Aug 18, 2017 at 10:52 PM
    nvnv
    nvnv [OP] Stop geotagging
    Connor
    2016 Tacoma TRD OFF ROAD
    I've been looking for a good SOLID spot to mount the faceplate for my ham radio. I got this idea from the 2nd gen guys. It is a very popular mod for them, although it takes a little more work on the 3rd gens since we don't have a driver side grab handle.
    2nd gen thread:
    https://www.tacomaworld.com/threads/mod-a-pillar-ram-mount-gps-phone-holder.372250/
    My parts list:
    -1/4" threaded rivet insert (with the tool to insert it). I got the cheapie kit from Harbor Freight
    -25/64 drill bit (that's the size hole you need for the 1/4" rivnut)
    -3/4" drill bit (this is to drill the hole in the A pillar)
    -RAM motorcycle handlebar mount http://www.rammount.com/part/RAM-B-367U
    -1/4-20 x 2" socket head cap screw
    -3/4" groove diameter rubber grommet
    -1/4" nut to use as a spacer to bring the RAM mount out from the A pillar a bit
    -Two 1/4" lock washers
    Time from start to finish was about 20 minutes.
    First pop off the cap that hides a bolt towards the top of the A pillar (it's the piece that says SRS airbag on it). Remove the A pillar trim piece carefully. Be careful, the side curtain air bag is behind the trim piece along with a wiring harness. In the picture below you can see the two mounting points circled. The bottom one is what we'll be using. In stock form there is a clip that goes into it to help secure the trim. We'll use the clip as a guide to drill the hole.
    You have to drill out the hole of the bottom mount to 25/64" to fit the nutsert. Then using your nutsert tool set the threaded rivet.
    Now comes the fun part. You need to drill a 3/4" hole in the trim piece. If you screw up it only costs about $50-60 to replace, not a huge deal. Remove the white clip from the trim, we use the clip holder as a guide to drill the hole since it lines up perfectly with the mount on the A pillar. First using the clip holder as a guide, drill a pilot hole using a smaller drill bit from the back of the trim piece.
    Now from the front use a 3/4" bit to drill out the rest. Make sure not to drill too far through because you want to keep the clip holder on the back intact. I used a paddle bit do this and it was a bit messy. Would suggest a normal bit for a cleaner hole, but it gets covered up with the grommet anyway. You can clean up the hole with a razor blade too.
    Now insert the rubber grommet around the hole to make it look pretty.
    Now it's time to put the trim piece back in. Again, be careful as you don't want to damage the airbag or the wiring harness. Once the trim piece is back in you can screw in the RAM mount. I used one 1/4" nut as a spacer to have the mount stick out a bit more from the A pillar.
    The order I used was: Socket head screw- lock washer- RAM ball- lock washer - nut
    Now you can screw it in and you're done. Also make sure to but the factory trim bolt back in and snap the cap back on.
    I have a 3" dual socket arm and a X grip coming, but for some reason those got delayed by Amazon. Here's the final product. This mount is extremely sturdy and it mounts your phone/gps/whatever off to the side, out of your view. It also doesn't block any vents, radio controls, switches, etc.
  2. Aug 18, 2017 at 11:05 PM
    RCRcer
    RCRcer Well-Known Member
    2015 OR DC
    Nicely done!
    t0nyvalenzuela likes this.
  3. Aug 18, 2017 at 11:39 PM
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
    Very nice!
    Appreciate the write-up with instructions, tools, and pictures.
  4. Aug 18, 2017 at 11:42 PM
    System_Erorr
    System_Erorr Member
    Kevin
    2017 White Tacoma TRD 4x4 Sport
    None yet!
    Nice man, that looks great! Did you learn how to use a ham radio online? I've been shuffling around the idea of getting certified.
  5. Aug 18, 2017 at 11:49 PM
    nvnv
    Connor
    I've been licensed for almost 10 years now. I bought a book and also did the online practice tests until I was scoring over 90%. I've been wanting to get into APRS so I got a Kenwood TM-D710g to replace my Yaesu FT-7800. There's a ton of cool stuff you can do now with APRS, a lot of it very useful when off roading without cell service.
    System_Erorr[QUOTED] likes this.
  6. Aug 19, 2017 at 5:54 PM
    DarkestCon
    DarkestCon Well-Known Member
    DC
    SF Bay Area
    2017 White Tacoma TRD Off Road
    Bone Stock
    Nicely done sir!
  7. Aug 20, 2017 at 4:54 PM
    eurowner
    eurowner Duke Sky
    Scoty
  8. Aug 20, 2017 at 4:56 PM
    steele-taco
    steele-taco Well-Known Member
    james
    Jersey shore
    17 TRD OR DCSB white
    5rolledtacos
    10% discount code for hondo garage
    Fyi
  9. Aug 20, 2017 at 5:02 PM
    foy1der
    foy1der Well-Known Member
    W1FOY
    2017 OR DCLB
    It's probably worth mentioning that when somebody t bones you, your cell phone is going to end up inserted in your forehead.
    paradox4286 likes this.
  10. Aug 20, 2017 at 5:32 PM
    nvnv
    Connor
    Why do you think that? How's this any different than any other cell phone mount? If anything it's one of the safer spots for a mount.
  11. Aug 20, 2017 at 7:11 PM
    paradox4286
    paradox4286 Well-Known Member
    San Antonio, TX
    17 TRDOR DCSB P/T JBL
    Isn't that defeating the point of it being clipped in vs screwed in.... So when the airbag goes off, it will be less effective due to having to bend the A pillar piece vs simply popping off? Am I missing something
    I can appreciate the work that went into it and certainly understand why you'd want it but I just hope it doesn't comprise your safety and the functionality of the curtain airbag.
  12. Aug 20, 2017 at 7:31 PM
    nvnv
    Connor
    The passenger side is held in by two bolts due to the handle being there instead of one bolt and a clip. The driver's side is no different than that. Watch this video, the trim piece doesn't even come unclipped or break.
    https://youtu.be/VfRxxjtFRsU?t=38s
    shakerhood likes this.
  13. Aug 20, 2017 at 7:36 PM
    paradox4286
    San Antonio, TX
    Well very cool mod then!
  14. Apr 17, 2018 at 9:31 PM
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    think it doesn't need to move ?
  15. Nov 24, 2018 at 9:56 AM
    tenebs
    tenebs Well-Known Member
    The section that this is installed on doesn't move in the video (see side view and picture below). The airbag pops out of the aft seam and only the very upper part of the inside cover of the a pillar moves. The clip locations are the same threads as those used on the passenger side to bolt on the passenger grab handle. The passenger side has the same side curtain airbag. There just isn't a grab handle on the drivers side because people use the steering wheel instead.
  16. Nov 24, 2018 at 10:02 AM
    Boricua
    Boricua Well-Known Member
    Jack
    2018 TRD Sport
    I really hate using the steering wheel to get in/out of my truck. I’m pretty sure sooner or latter someone is going to be creative enough to make a functional grab handle for the driver side!
    :fingerscrossed:
    58electricman likes this.
  17. Nov 24, 2018 at 10:16 AM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Actually, people use the steering wheel because there isn’t a driver’s side grab handle. :D
    <end of Saturday am rant>
  18. Oct 15, 2020 at 4:54 PM
    58electricman
    58electricman Well-Known Member
    San Diego,Calif.
    18' TRD Sport Black DCLB, & 05' Sport Pre-Runner Black DCSB
    Icon Coilovers & UCA's, Maxtrac 4" lift Spindles, Falken MT 285/70/17 Tires, Mickey Thompson Classic III Wheels 17X9 -12mm 4.53in Backspace, Bilstein 5160 Rear Shocks, TRD Cold Air Intake, Aries Action Trac Side Steps, Rough Country Speedometer Calibrator, Shift Sense Pro, Pedal Commander, Bakflip MX4 Bed Cover, Mountain Hatch Tailgate Insert, TRD Pro Grill, Start-X Remote Start, Pop n" Lock Tailgate, OEM Bed Mat, OEM Cargo Divider, OEM Bed Step, MORIMOTO 5500 35W HID's, ORACLE H11 - VSeries LED Highbeams, MESO Stealth Pro Shift Knob, MESO Puddle Pods, MESO Ultimate Turn Signals, MESO Total Tail Stage 1, MESO TRD Blk Start Button &Trim Ring &Coin Tray & Gasshole, Hondo Phone Mount, Clazzio Leather Seats, Vantrue Dash Cam, Off Grid/Blue Sea Fuse Block & Tray Mount, Beat-Sonic CS6EP W/ Natika Front Camera, Kicker Speakers/Subaru Tweeters & 300W Amp & 8"Hideaway Subwoofer, CADDY Train Horns, Redline Hood Struts, Automatic ECT PWR Power Mode Default Always ON, RAV4 Blind Spot Mirrors, Matt Gecko LED hood light engine kit, SEVENS Tailgate Letter Inserts, Smittybilt 2781 5.65CFM Air Compressor, AVS Window Visors, All Window Tint, RHINO USA Recovery Accessories, KTJO4X4 DRIVER'S SIDE GRAB HANDLE (Installed), DARTH VADER, & a STORM TROOPER, etc...
    AND.....IT'S HERE!...:spending::broccoli::woot::101010::oldglory: JUST PRE-ORDERED MINE!
    https://www.ktjo4x4.com/tacoma-oem-grab-handles-2016
    3RD GEN TACOMA (2016+)
    OEM DRIVER'S SIDE GRAB HANDLES W/ A PILLARS
  19. Apr 10, 2021 at 1:36 PM
    HCfromEP
    HCfromEP New Member
    Harley
    2021 Tacoma Limited Wind Chill Pearl Hickory Interior
    Nice job @nvnv. I had the a-pillar mount in my 2nd gen and could not live without it. It was hooked to an Apple CarPlay head unit and I ran an iPhone cable for charging and CarPlay features. I just bought a new 2021 Taco and was so happy you posted this, I had no idea the handle bracket was under there. I'll highlight the features that are different.
    Ram Mount Magnetic Holder: https://www.rammount.com/part/RAP-339U
    3M cable (6' will be too short): https://www.amazon.com/gp/product/B086H39P8S/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8
    iPhone cable tucked behind Ram Mount. I also used a 3/4" spacer to get the ball of the Ram Mount away from the A-pillar far enough to fit the charger cable thru the hole (hole is 1").
    iPhone cable thru hole, you cannot see this if you drill on the underside. After pulling the dash apart I was hopeful the USB port could be plugged directly into the head unit or into the port behind the dash. No dice. I guess I could have taken the USB port out of the switch panel but decided this would allow me to easily connect other phones if needed.
    I_Am_kasc0 and nvnv[OP] like this.
