A.C./Heater fan only blows on high
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jeffbare, Sep 5, 2018.
  1. Sep 5, 2018 at 9:43 PM
    Jeffbare
    Jeffbare [OP] Member
    Driving home today, and noticed the fan only works on high. I’ve only owned it for about a month. Any ideas on a solution?
  2. Sep 5, 2018 at 9:51 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Google the title of this thread with tacomaworld in it. Lots of threads on this already
    BillsSR5 and whatstcp like this.
  3. Sep 5, 2018 at 10:48 PM
    Jeffbare
    Seems there are a lot of resistors on the market, any idea if one is any better than the others?
  4. Sep 6, 2018 at 7:37 AM
    Jeffbare
    Should the blower be replaced at the same time as the resistor?
  5. Sep 6, 2018 at 7:44 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    GOOGLE heater fan blows only on High 2005-2015 Toyota Tacoma Tacomaworld, your welcome
  6. Sep 6, 2018 at 7:49 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Blower motor is fine if it works on high. The resistor is the issue. The resistor controls how much voltage gets to the blower motor. If it's full voltage (resistor NOT in-line) you get the HI setting. All of the lower settings like MED and LO are settings where the resistor is lowering the voltage the motor sees. When the resistor's connection or the resistor itself fails, all of the blower settings where the resistor was doing work will not work. This is why you are left only with the HI setting.
  7. Sep 6, 2018 at 8:49 AM
    Jeffbare
    Thanks all, I’ll just order a resistor.
    HoustonFive likes this.
  8. Sep 6, 2018 at 9:04 AM
    Muddinfun
    Muddinfun Well-Known Member
    Although some people have claimed to have gotten by with just replacing the resistor, the proper way to insure success is to also replace the melted connector at the same time.
  9. Sep 6, 2018 at 9:26 AM
    ItalynStylion
    Steven
    DFW, Tx.
    Yes that's true. If the connector is obviously melted you'll need to replace that too. That's one of those common sense things.
  10. Sep 6, 2018 at 9:38 AM
    Norcal05tacoma
    Norcal05tacoma Active Member
    05tacoma4x4
    can some one link a picture of where to find the resistor in the tacoma to remove/replace it. maybe with some instructions too. I'm just a regular driver not a mechanic . thanks
  11. Sep 6, 2018 at 9:59 AM
    Jeffbare
  12. Sep 6, 2018 at 4:39 PM
    capecodtaco
    capecodtaco Active Member
    Tom
    2014 Spruce Mica SR5
    Stock
    I had the same issue. I bought the resistor and it didn't help. I got it to work by messing with the wires. I haven't had time to swap out the connector. It does occasionally only go to high I can reach under move the wires a bit and it works again.
  13. Sep 7, 2018 at 7:28 PM
    Jeffbare
    Replaced the resistor and connector. Seems to work as it should. Thanks all
    Muddinfun likes this.
