A/C compressor mounting bolt size
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Amo-cat3, Aug 16, 2018.
  1. Aug 16, 2018 at 7:53 PM
    Amo-cat3
    Amo-cat3 [OP] Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    By any chance does anyone know what size the mounting bolts are for the a/c compressor on the 4.0? I'm missing one of the bolts. Do you think I can quickly remove the other mounting bolt to reference the size without the compressor dropping down to much and tweaking the refrigerant lines?
    Thanks for any quick repilies!!
    Rod
  2. Aug 16, 2018 at 10:14 PM
    cfcarpenter
    cfcarpenter Well-Known Member
    Clint
    PNW
    2005 DCLB 4wd MT
    You should be able to pull a bolt to go match it up. I forget what size it is off the top of my head. I’m willing to bet I have one if you can’t find one. Probably wouldn’t take much to ship it
  3. Aug 16, 2018 at 10:16 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Yes you can do this
    However I would order an OEM one for sure.
  4. Aug 16, 2018 at 10:17 PM
    Bishop84
    Bishop84 Well-Known Member
    You can easily remove one and leave the other one holding the compressor, it's not going to go anywhere.
    Take it out and go to a bolt supply shop.
  5. Aug 16, 2018 at 10:17 PM
    anthony250f
    Anthony
    San Diego, CA
    Also you can move the compressor around a lot. I just removed mine and left the lines attached. Was able to move compressor all the way up to the radiator
  6. Aug 17, 2018 at 1:21 AM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    Thanks for all the replies all!!! I was able to figure it out, It's an M8 size bolt, 3" long with a thread pitch of 1.25. i think most of the mounting bolts on the engine and engine area are all 1.25 thread pitch, so for future reference. I just spent the last two days replacing my knock sensors (had to pull the supercharger so did some other maintenance) and also installed the oem engine oil cooler. Hands all busted up. This was the last bolt to install and got her all fired up and so far so good.
    cfcarpenter likes this.
