A/C blowing out of defrost vents - Condensation/fogging
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 18' TACO TRD, Aug 4, 2018.
  1. Aug 4, 2018 at 9:52 AM
    18' TACO TRD
    18' TACO TRD [OP] Well-Known Member
    Florida
    2018 TRD Cement
    I live in Florida. Everytime I turn on the A/C front vents only. The windshield will condense and fog up on the outside of the glass, center lower portion. I noticed that the cold A/C blows out of the defrost vents against the windshield even when the defroster is set to off.
    Is this normal or anyone have a solution?
    Thanks
    Gator352 likes this.
  2. Aug 4, 2018 at 10:19 AM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    Is the Recirculation button turned on?
  3. Aug 4, 2018 at 10:20 AM
    18' TACO TRD
    Florida
    2018 TRD Cement
    Yes it is
  4. Aug 4, 2018 at 1:17 PM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    Nature of the beast; cold air on one side, hot air on the other. The only thing you can do, if you must have it on the defrost setting, is to turn up the temp. until it doesn't cause condensation.
    2016Tacoman likes this.
  5. Aug 6, 2018 at 5:36 PM
    18' TACO TRD
    Florida
    2018 TRD Cement
    So there's no way to have ac on with defrost vents off? I don't understand why there would be cold ac blowing on my windshield when select front vents only.
  6. Aug 6, 2018 at 5:37 PM
    fzj40
    fzj40 Well-Known Member
    R
    2017 TRD OR MGM 6MT
    normal
  7. Aug 6, 2018 at 5:44 PM
    18' TACO TRD
    Florida
    2018 TRD Cement
    But why? Doesn't make sense.
  8. Aug 6, 2018 at 5:46 PM
    gunn_runner
    gunn_runner www.gunnphotoservices.com
    Rocky River, OH
    2013 DCLB TRD
    OME 886 & Dakars. 35" Mickey Thompson Baja Boss
    It's not a solid seal when the motor actuated door blocks the defrost vent. Cold air still flows by a little. My 2nd gen started doing it after about 60k on the odometer.
    CanisLupus likes this.
  9. Aug 6, 2018 at 5:51 PM
    shamuspi
    shamuspi Well-Known Member
    Richard
    2017 Tacoma SR
    None
    Some years ago, many/all manufacturers started running the ac with the defroster to reduce the amount of moisture in the defroster's blown air. Sadly, the even colder (but drier) incoming air is fighting with the heater. On some/most vehicles it works. On others (i.e.: Jeeps) not so well.
  10. Aug 6, 2018 at 6:16 PM
    18' TACO TRD
    Florida
    2018 TRD Cement
    Its weird bc my other cars I never had this problem. So the cold air coming out defrost vents is normal. Seems like it should just be sealed off unless you actually use the defroster.
  11. Aug 6, 2018 at 6:34 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Put a cold coke can outside. What happens ?
    Outside moisture condenses on cold can. Dew point.
    Anytime you lower the outside temperature on the glass lower than the dew point it will condense.
    You are in the cold can (truck), moisture is on your windshield (outside of can).
    Only thing that would eliminate this is having the air blow out in a more diffused pattern as not to concentrate on one section of the windshield aggressively and become colder than rest of area.
  12. Aug 6, 2018 at 7:15 PM
    18' TACO TRD
    Florida
    2018 TRD Cement
    I understand the coke bottle. I just don't understand why the cold air would be blowing at the windshield. I wish there was option to turn it off or better sealed.
    2016Tacoman[QUOTED] likes this.
  13. Aug 6, 2018 at 9:08 PM
    VegasTool
    VegasTool Well-Known Member
    Las Vegas
    2017 TRD OR
    Always an option, fix the problem yourself or have someone else do it. Had a Jetta that did that, ripped the dash apart. Actuator wasn't pushing it all the way in, wore out from age I guess. Cut the link, enlisted a coat hanger to add extra length and got it to work. Always options. Since yours is a 2018 i'd option it back to the place you got it and have them fix it
  14. Aug 7, 2018 at 2:03 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Really depends how much air is blowing out your defrost vents. Very well could be a faulty actuator or blend door. Your under warranty so have the dealer check it out
  15. Aug 7, 2018 at 4:24 AM
    Spillproof
    Spillproof Well-Known Member
    Ken
    Nova Scotia
    2018 Inferno AC OR
    I run AC a lot in very humid conditions, and I have never noticed this on my 18. Yes condensation is normal, but blowing cold air through the defrost vents is not in my experience. Might be worth a discussion with your dealer.
  16. Aug 7, 2018 at 4:51 AM
    JaTe
    JaTe Well-Known Member
    Maryland
    2017 Tacoma TRD OR DCSB
    It's an option the dealer can change if you have auto a/c. See attached.
  17. Aug 7, 2018 at 5:01 AM
    18TRDOR
    18TRDOR Well-Known Member
    Kyle
    New Philadelphia, OH
    2018 TRD OR DCSB 6MT
    I noticed the same thing in my 18 the day after I bought it. I've never owned a vehicle that fogged windows so easily so it caught me off guard. Now i just adjust the temp a little bit to get rid of the condensation on the outside and ride with it. I may bring it up to my dealer at the first service or I may find a way to fix it myself. Either way I'll have to agree that its slightly annoying. I wonder if its just an actuator not fully closing the defrost vent or the foam seal on the defrost door isn't that great. I wonder if an HVAC recalibration would fix it? I have noticed that if I put the mode selector in anything other than "up high" the fogging is worse, or if you have it in between settings its even worse than that.
  18. Aug 7, 2018 at 5:35 AM
    18' TACO TRD
    Florida
    2018 TRD Cement
    I have auto a/c. Which one would help with the defroster? I have it set to the front vents only.
  19. Aug 7, 2018 at 5:44 AM
    18' TACO TRD
    Florida
    2018 TRD Cement
    I uploaded couple pics. This is what I'm experiencing especially in the morning with front vents selected only and temp anywhere from LO to 75 degrees that tested so far.
  20. Aug 7, 2018 at 5:44 AM
    JaTe
    Maryland
    Third option - foot/defroster auto mode. Standard is on. You would want that off so it doesn't blow to the windshield automatically when auto ac is on.
    Tacoma2020 likes this.
