A Bigger Ball for My Truck
Discussion in 'Towing' started by Sybaris, Aug 7, 2010.
  1. Aug 7, 2010 at 1:21 PM
    Sybaris
    Sybaris [OP] Member
    04 PreRunner
    My truck came without a tow package but has a 2" ball on the bumper.
    The hitch on my trailer is 2 5/8".
    I have a 2 5/8" ball but the shank won't through the hole in the bumper.
    I bought a 2" hitch to see if I could replace the original hitch on my trailer but that isn't going to work.
    Any suggestions much appreciated.
    thanks
  2. Aug 7, 2010 at 1:27 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    Could you not find a 2 5/8" ball with that sized shank? Also if the trailer is large enough to justify a 2 5/8" ball you may want to invest in a hitch that bolts to the frame. The bumpers aren't the best place to tow from except for occasional light loads.
  3. Aug 7, 2010 at 2:29 PM
    Barnone
    Barnone Guest
    OP stated that his truck came without a tow package.
    No receiver hitch.
    Jason suggested that he find a 2 5/8" ball with a smaller diameter shank or install a receiver hitch.
    Jason also stated that a trailer with a 2 5/8" ball is probably too big a load for the OP's Taco.
  4. Aug 7, 2010 at 2:32 PM
    Jason'sLawnCare
    I think the confusion is the op called the coupler on the trailer tongue a hitch.
  5. Aug 7, 2010 at 2:34 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I agree. Any trailer that requires that big of a ball is probably too much load for your bumper.
  6. Aug 7, 2010 at 5:57 PM
    Sybaris
    Sybaris [OP] Member
    04 PreRunner
    Thanks for the replies
    I'm towing an empty boat trailer to a storage lot so the weight is not a problem.
    Guess I'll look for a 2 5/8" ball with a smaller diameter shank.
  7. Aug 7, 2010 at 6:14 PM
    Jason'sLawnCare
    Oh that explains that. I would suggest tractor supply they seem to have a lot of towing accessories and maybe you could see if they let you test fit it before you purchase. They may even torque it down for you.
  8. Aug 8, 2010 at 5:20 AM
    Barnone
    Barnone Guest
    Or if there is enough metal in the bumper hitch and you can't find a smaller shank, you could drill a larger hole?
  9. Aug 8, 2010 at 6:15 AM
    Jason'sLawnCare
    I'd be concerned about making it too weak but I guess that's an idea.
  10. Aug 8, 2010 at 6:39 AM
    NetMonkey
    NetMonkey Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
  11. Aug 8, 2010 at 6:50 AM
    chugchug
    chugchug Well-Known Member
    Will
    Frederick MD
    2012 Toyota Tundra
    I could be wrong on this but they don't make a 2 5/8 ball but they do make a 2 5/16 ball and you wont find a ball that size to fit your bumper. now they do make a convert ball kit. you buy the kit that will fit the hole in your bumper then buy the 2 5/16 head that will go on top. Google convert a ball
  12. Aug 8, 2010 at 7:55 AM
    Barnone
    Barnone Guest
    You are right about the 2 5/16" size.
    Yea, I forgot about convert-a ball but
    " 1" chromed shank for 1 7/8" 2" and 2 5/16" balls rated 10,000 lbs."
    and he probably has a 3/4" hole in his bumper.
    I would drill out the bumper plate to 1" but that's just me. You are only talking 1/4".
  13. Aug 9, 2010 at 9:23 AM
    Sybaris
    Sybaris [OP] Member
    04 PreRunner
    Right. I meant 2 5/16 and they don't make them with 3/4" shank.
    I looked at the convert-a-ball or drilling out the bumper hole or taking a 2 5/16 to a local machine shop and having it turned down to 3/4" and threaded.
    I've decided to go with a hitch receiver rather than those other options. I wouldn't have a need to tow anything heavy or very frequently so I'm not real adept at doing it. I've seen people pinch their bumper just using a ball on bumper so I want to increase my margin of error.
    As I mentioned, I'm just towing an empty boat trailer and maybe in the future light loads so a class IV would be overkill.
    Any hitch receiver recommendations for an 04 Prerunner much appreciated.
    thanks
    Syb
  14. Aug 9, 2010 at 9:34 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Check autoanything or JCWhitney. You can usually find good deals with free shipping. I have a class III Hidden Hitch on a gen 2. Very easy install, no drilling, cutting or welding.
  15. Aug 9, 2010 at 3:22 PM
    Jason'sLawnCare
    Or maybe check around here for people selling the factory hitch due to purchasing an after market bumper. Or post a WTB(Want to buy) thread.
