97 Tacoma headlights
Discussion in '1st Gen. Tacomas (1995-2004)' started by 97redtaco, Oct 18, 2016.
  1. Oct 18, 2016 at 11:45 PM
    97redtaco
    97redtaco [OP] Active Member
    Trey
    Red 97 Tacoma 4x4 xtra cab sr5 v6
    Lift,wheels and tires and custom bumpers
    Does anybody know any good lights to replace the sealed glass unit ones? They're on my 97 4x4 tacoma.
    robssol likes this.
  2. Oct 19, 2016 at 12:24 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Sorry, no
    Welcome to TW!:hattip:
    Let me give you your first "like"
  3. Oct 19, 2016 at 12:33 AM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    I have the Vision X sealed beam replacements and their pretty dang good for the price.
  4. Oct 19, 2016 at 6:10 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Hella Vision Plus H4 and upgrade the wire harness while you're at it.
    burntkat likes this.
  5. Oct 19, 2016 at 6:20 AM
    Clearwater Bill
    Billy
    Largo Florida
    Lets see if @crashnburn80 can chime in. Maybe his ultimate headlight upgrade is applicable here.
    crashnburn80 likes this.
  6. Oct 19, 2016 at 6:51 AM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '09 R1, '03 cbr954rr, '03 rc51
  7. Oct 19, 2016 at 7:02 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    The hella and vision x options are good. Retrofits are the best.
  8. Oct 19, 2016 at 8:56 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Yes. The Hella 200mm E-code H4s are an outstanding improvement over stock and the best drop in replacement reflector IMO.
    E-code lights have a superior beam pattern with sharper cut-offs to DOT lights and put significantly more light on the road. I've done this on my 89 and 94 pickup that ran sealed beams. The Hellas are a little more expensive but had perfect fit and finish. I've tried lesser brands first and they were loose in the headlight bucket and required shimming. Then I got a rock through the lens and saw how thin the glass was. Went with Hella afterward and was way better quality.
    Here is a link for the Hellas, which are a complete plug and play replacement.
    Hella 200mm E-code H4 conversion:
    http://www.rallylights.com/h6054-hella-200mm-rectangular-e-code-hi-lo-conversion-headlamp-kit.html
    Optionally you can add the 85/80w Osram bulbs used in the ultimate headlight upgrade to the purchase. Running the 85w/80 bulbs will vastly improve output even over the E-codes, but do require the the standalone harness from the linked headlight upgrade. The difference will be literally night and day, more-so with the E-codes than the pictures with DOTs in the thread.
    Running just the Hella E-code H4 conversion with standard wattage bulbs will still see a significant improvement over stock.
    zenn1102 likes this.
  9. Oct 19, 2016 at 9:15 AM
    97redtaco
    Trey
    Thanks for all the help guys. I'm also looking for more idea to do on my truck. What have you guys done
  10. Oct 21, 2016 at 4:26 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
  11. Oct 21, 2016 at 4:44 PM
    devinzz1
    devin
    2023 aclb trd or mt
    Hids+halogen housings are a no no
    burntkat, crashnburn80 and Sicyota04 like this.
  12. Oct 21, 2016 at 4:47 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Wow, look at how much brighter. :crazy:
  13. Oct 21, 2016 at 4:59 PM
    devinzz1
    devin
    2023 aclb trd or mt
  14. Oct 21, 2016 at 8:06 PM
    djtacoma
    djtacoma Active Member
    2014 Tacoma TRD Off Road DCSB
    Magnuson Supercharger, Cam gears, King 2.5 Coilovers and shocks, SPC UCAs, Icon progressive add-a-leaf, Wheelers u-bolt flip with Superbumps, Tom Woods one-piece driveshaft, TRD Pro wheels, 265/70/17 KO2s, air freshener
    Is that the low beam?
  15. Oct 21, 2016 at 8:30 PM
    devinzz1
    devin
    2023 aclb trd or mt
    I would hope not.
  16. Oct 22, 2016 at 5:28 AM
    1997tacomav6
    Denver
    That was in a under ground parking lot not totally level, 3 car lengths back on high beam. You can see the car to the left, the light pattern would cover the car. Not the sky above the car.
    The Hella H4 beam is very direct with specific light cut offs,
    If you want an excellent performance package this is the way to go hands down.
    If your looking for a retro look or a different look there are other choices but not
    in performance for a factory lens setup, the LED are great but from reviews are not
    as good as the HID but are close.
  17. Oct 22, 2016 at 10:23 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    :bananadead:
    While E-codes do have better cut offs than DOT, this was specifically writen for LEDs, and it is even far worse for HIDs.
    Read this to understand why you cannot just swap the light source in a halogen reflector.
    https://www.tacomaworld.com/threads/why-leds-should-not-be-run-in-halogen-reflectors.454371/
    Halogen bulbs in a halogen reflector will deliver superior results unless you are going full projector retrofit for your HIDs.
  18. Oct 22, 2016 at 10:54 AM
    1997tacomav6
    Denver
    Interesting but nevertheless the HID that I put in the replace the halogen 65 watt bulbs are twice as powerful and work much better on my truck. That's first-hand experience after replacing the 65 watt halogen with the 55 watt HID bulbs.
  19. Oct 22, 2016 at 11:19 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Of course they are brighter. Not just for you but for everyone else around your truck. Your the type of guy we all complain about on forums cause we are blinded on the road by glaring headlights "upgraded" with HIDs/LED's in halogen housings.
  20. Oct 22, 2016 at 11:23 AM
    1997tacomav6
    Denver
    Nope, the Hella H4 LAMPS do the opposite of that they lay down a controlled light spread with cut offs that dont go into the oncoming driver's eyes
