97 2.4 camshaft sensor location?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Westdale, Sep 15, 2022.
  1. Sep 15, 2022 at 11:33 AM
    Westdale
    Westdale [OP] Member
    97 Tacoma Yard Ornament
    Anyone have a diagram or picture of the location for a 97 base model 2.4 camshaft position sensor?
    2RZ-FE RZN
  2. Sep 15, 2022 at 12:28 PM
    San Lorenzo
    San Lorenzo Well-Known Member
    Juan Ramon
    2003 Tacoma
  3. Sep 15, 2022 at 12:29 PM
    San Lorenzo
    Juan Ramon
    2003 Tacoma
  4. Sep 15, 2022 at 7:38 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Cam sensor is only for those with no distributor......
    98 and up........everybody knows that....gessh....
  5. Sep 16, 2022 at 5:41 AM
    Westdale
    Well. No I didn't know. This was a yard find that has been sitting up for 3 years. I am not a mechanic but I knew enough to drain the gas etc. It started and ran fine, but would lose about 20% power, and a/c would quit. I used a cheap code reader and it gave the code, I think. The problem is when it runs and the check engine light is off, no code shows.
    Usually when it comes on I don't have the reader or I can't pull over to do it. I will try to capture the code and see.
    I did clean the throttle body, it was horribly dirty. I don't have the tools to test vacuum and sensors. I just wanted enough info to talk to a mechanic about it.
  6. Sep 16, 2022 at 6:04 PM
    O'Silver_Taco
    MD
    Well you've bought a ship with some holes in it....
    .....you'll just have to address each mess one by one....
    If you want a turn key vehicle that runs and runs and never needs work...
    you've made a terrible mistake....maybe a corolla or camry?..
    The people here sure can help u out.......
    ......bunch of them specifically know specific engines...
    but its gonna take some effort....or make payments for jeep/fiat or something...
    When u buy a house and nobodies done anything to it for decades....
    .......wow makings for a good moive.....wonder what shelly long is doing.....
    Good news ....is these trucks are easy to work on.....and there's multilple vids out there to tackle pretty much any job you think of....
    If not .....someone here has already done it......learn from their mistakes.......
