95 Tacoma Crank no Start
Discussion in '1st Gen. Tacomas (1995-2004)' started by Royderjd, Apr 11, 2022.
  1. Apr 11, 2022 at 5:37 AM
    Royderjd
    Royderjd [OP] Well-Known Member
    Jonathan
    95 Tacoma 2.7L 4x4
    I have a 95 Tacoma 2.7L its been sitting awhile. I started up it up a couple of weeks ago. Got it going it had a miss in cylinder 3, but I drove it around and let it charge up the battery etc etc. I drove it back home. parked the truck, I changed out the spark plugs on it. after that the truck cranks but will not start. unless it has set for awhile, after it has set for a while like week it would start up and idle for a second or two then die again. so this lead me to believe its a fuel issue. 1. i replace the fuel pump relay under the hood, nothing I didnt hear the fuel pump turn on when the key is turned to the run position. 2. I dropped and replaced the fuel pump, still same results. I'm running out of ideas to look at, so I you have any experience troubleshooting with old trucks it would be greatly appreciated.
  2. Apr 11, 2022 at 12:08 PM
    Ccrowe323
    Ccrowe323 Well-Known Member
    Cory
    Florida
    2001 Tacoma 3.4 DC 5speed TRD OR
    Could possibly be the crankshaft position sensor or camshaft sensor. These could also cause the misfire and a completely dead crankshaft sensor usually results in a no start
  3. Apr 11, 2022 at 12:13 PM
    Royderjd
    Jonathan
    95 Tacoma 2.7L 4x4
    See I ruled that out bc it would fire up and run for a few seconds after it set for while like a week
  4. Apr 11, 2022 at 2:19 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I don’t think the relay will power the fuel pump until it sees a crank signal.
    I’m not saying it’s the cranks signal.
    There’s a lot more parameters that need to be met to keep the engine running.
    ECT Sensor
    Idle Air
    MAF
    Royderjd[OP] likes this.
  5. Apr 16, 2022 at 10:22 AM
    Royderjd
    Jonathan
    95 Tacoma 2.7L 4x4
    I just swapped out the CrankSensor and no luck, Back to Square one. I'm not sure what to look at next. I'm limited on tools for troubleshooting, I still haven't listen to the injectors to see if they are firing. That will have to wait until I order a needle point style stethoscopes to do more on that. Its probably about time to order the actual Toyota Tacoma Manuals and go from there.
  6. Apr 16, 2022 at 10:31 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Have you checked:
    Fuel pressure?
    Power and Ground at the fuel pump when cranking?
    Will it run if you spray carb cleaner in the intake?
  7. Apr 16, 2022 at 10:35 AM
    Royderjd
    Jonathan
    95 Tacoma 2.7L 4x4
    I havent checked powered and ground yet at the Fuel pump, I dont have a voltmeter to check it and no spare hands either. before I changed the fuel pump, if it set for a couple of days it would start and run for a few second before dying again. like one of the injectors was leaking fuel (idk) but after changing the fuel pump no sucks luck, when I turn the key on I don't hear the pump do prime like it normally do. so scratching my head.
  8. Apr 16, 2022 at 10:53 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I don't think 1st gen Tacoma's have a key on prime, I know 2nd gens don't.
    From the FSM:
    FUEL SYSTEM > FUEL PUMP CONTROL CIRCUIT > CIRCUIT OPENING RELAY
    Circuit opening relay controls fuel pump circuit. When EFI main relay is energized, EFI main relay provides battery voltage to circuit opening relay. When engine is cranking, circuit opening relay receives a start signal which energizes circuit opening relay. Circuit opening relay then provides voltage to fuel pump. When start signal is released from circuit opening relay, the circuit opening relay ground circuit is controlled at Engine Control Module (ECM) terminal FC.
    You could do a bypass test on the Circuit Opening (Fuel Pump) Relay and see if the pump runs.
    TnShooter likes this.
  9. Apr 16, 2022 at 11:36 AM
    Royderjd
    Jonathan
    95 Tacoma 2.7L 4x4
    alright give me a crash course on how to do the bypass and ill go give it a shot.
  10. Apr 16, 2022 at 11:41 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Just stick a piece of wire connecting the power wires in the relay socket or just put 12v to the pump with a battery and some leads. You could have seen if the crank sensor was working if the computer was getting crank signal when cranking the engine with a cheap ODB-2 reader hooked up to your phone as I’m assuming you don’t have a tach on your gauge cluster.
  11. Apr 16, 2022 at 11:51 AM
    TnShooter
    Deogee
    STOCK
    You would take a jumper wire and jump pins 1 and 2 of the C/Open Relay.
    Normally they are the 2 BIGGER pins. However, I’d feel more comfortable if someone could provide a Relay pinout. Just to be sure.
  12. Apr 16, 2022 at 12:18 PM
    tcervinsky
    tcervinsky Old man with a gun.
    Tim
    Williamsport, PA
    2002 Tacoma
    So have you tried spraying starter fluid in the intake to see if it tried to start? Have you cracked the fuel line banjo bolt to see if fuel leaks out? These are two very simple things to try to help narrow down the problem. If it tried to start then it is a fuel problem. If it still doesn't then it's an electrical problem. Also, try disconnecting the battery. I'm wondering if this "period" of sitting is just allowing some voltage to drain off enough that the ecm resets. Disconnecting the battery will simulate that.
  13. May 15, 2022 at 6:44 AM
    Royderjd
    Jonathan
    95 Tacoma 2.7L 4x4
    Alright, back to this again. I just jumpered the open circuit relay from white/red wire to the blue wire. And nothing happened it just kept cranking again no start. Didn’t even hear the fuel pump kick on and prime. ‍♂️
  14. May 15, 2022 at 9:09 AM
    TnShooter
    Deogee
    STOCK
    If the pump isn’t running, you either don’t have power AT the pump or your ground for the pump is bad.
    There is a slight chance your injectors aren’t pulsing. But I doubt it. You need to get that pump running.
  15. May 15, 2022 at 9:52 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Do you have power on the White/Red wire at the C/OPN relay with the key on?
  16. May 15, 2022 at 10:12 AM
    gen2tegboi
    gen2tegboi Well-Known Member
    Juan
    Florida
    98 Tacoma Ext Cab SR5 2.4L
    Did you check your coolant temp sensor and fuel temp sensor?
