85k miles…coolant flush or drain and fill?
Discussion in '4 Cylinder' started by IEsurfer, May 20, 2023.
  1. May 20, 2023 at 2:17 PM
    IEsurfer
    IEsurfer [OP] Well-Known Member
    Socal
    About to hit 85k on my taco, coolant looks new but to my knowledge probably never been touched, do I drain and fill or full flush?
  2. May 20, 2023 at 2:20 PM
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    I’d just take it to one of those BG flush machines and have them change it out.
  3. May 20, 2023 at 2:21 PM
    IEsurfer
    Socal
    I thought of doing that but just like most topics on tacomaworld half the people say do it the others say it will blow the motor
  4. May 20, 2023 at 2:24 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    It shouldn’t hurt anything as long it’s a non pressurised machine. If not just drain and fill with the same color of coolant that’s in there now. Just be sure to drain the block as well. It won’t get absolutely everything out, but at those miles I wouldn’t worry too much about it.
    IEsurfer[QUOTED][OP] likes this.
  5. May 20, 2023 at 2:45 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    Oh yea and make sure to fully bleed the system afterward and keep an eye on temps with an OBD gauge to make sure there aren’t any big fluctuations.
    IEsurfer[OP] likes this.
  6. May 20, 2023 at 2:49 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I don’t mean to correct you but coolant color means nothing. There is no standard in the industry. I’m not sure what the 4cyl uses. My guess is the same as the 6cyl which is OAT, Organic Acid Technology, coolant. Good luck.
  7. May 22, 2023 at 10:52 AM
    MoneyB86
    MoneyB86 Well-Known Member
    Reagan Country, CA
    2019 MGM Tacoma Double Cab
    Get a coolant testing strip. I use the Phoenix Systems strip as its a 2 for 1. Dip it into the radiator to test the coolant and you’ll know the Freeze/Boil point and Acidity level within 30 seconds. Ive noticed that although the Free/Boil level was above 50% life left after 7 years, the acidity level got to 5.5 (replace now) after that same time frame. I’ve changed my coolant using the strips and never had an issue with any radiator corrosion. The color is a poor indicator of life.
    SR-71A and IEsurfer[OP] like this.
  8. May 23, 2023 at 12:00 AM
    69 Jim
    69 Jim 4-word Jimmy
    PNW
    2013 Standard Cab 4x4
    There is quite a bit of difference between Pink and Red OEM coolant.
    airmax233 likes this.
  9. May 23, 2023 at 5:18 AM
    knayrb
    Bryan
    Pure stock
    Yes for the same manufacture. There is no industry standard on the type of coolant corresponding to a particular color.
  10. May 24, 2023 at 6:03 AM
    spicy_fish_taco
    spicy_fish_taco Well-Known Member
    '18 2.7L Taco 4x4 Access Cab
    another one of those subjects where everyone has a wide array of opinions...
  11. May 24, 2023 at 6:13 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Im not sure about 4 cly, but on the V6 you can drop almost 90% of the coolant from the system very easily. Thats more than enough. Would a full flush get that last 10%? Probably. Worth it? Not imo.
    These guys? Looks like a cool product, might have to grab some
    https://www.brakebleeder.com/produc...5-pack-foil-wrapped-double-ended-test-strips/
  12. May 24, 2023 at 6:25 AM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    I've never... ever... drained coolant or flushed a system. And I've never had any kind of engine failure, ever. (knock on wood, right?)
    When I buy a vehicle I have a little tool to check the coolant strength, to make sure it's enough to stay liquid at -25, and I check levels whenever I feel like it. I've also worked in the auto parts industry with certified techs and repair facilities for +thirty years and I intentionally avoided maintenance to see what happened over time... and when I decide to change vehicles they have always been sold running well.
    There's four things that kill vehicles in my experience. Abusive driving, rust, accidents, and too much maintenance.
    YMMV
    arguscanis likes this.
  13. May 24, 2023 at 6:50 PM
    IEsurfer
    Socal
    I appreciate and respect your input so I noticed with our almighty 2.7 the Achilles is the dreaded blown head gasket and based on my research here and tacomaworld is the consensus is usually overheating causes it
    carcarenut says to change it out every 5 years or 50k miles and people on here say the coolant is acidic and can eat away at the gasket hence my reasoning for wanting to change it out
    SR-71A and Travlr[QUOTED] like this.
  14. May 24, 2023 at 7:57 PM
    MoneyB86
    Reagan Country, CA
    Yep thats the one. Case in point, my 2020 Highlander is due for a brake bleed as a result of the test. So the internet saying of replacing brake fluid every 3 years seems to be holding true as well
    SR-71A[QUOTED] likes this.
  15. May 27, 2023 at 9:03 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
  16. Jun 2, 2023 at 9:43 AM
    digcolnagos
    digcolnagos Member
    My 2002 Tacoma has 180k on it, and I just realized I can't recall the last time the coolant was changed. Thought I'd do a flush and fill myself. After checking YouTube and finding all different kinds of ways to do it, some more complicated than others, I called the dealership, which told me they no longer do full-bore flushes on advice from Toyota as the pressure--apparently there is some sort of machinery they once used--can do more harm than good. Because I'm not mechanically inclined, I'm now thinking Jiffy Lube, which will do it for $100.
    For what it's worth.
  17. Jun 2, 2023 at 11:12 AM
    george3
    New Jersey
    You might want to look at my post just above yours.
  18. Jun 2, 2023 at 11:16 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Drain the block and radiator, fill with fresh coolant. Don't go anywhere near jiffy lube
    69 Jim, 10thMTNgrunt and TnShooter like this.
  19. Jun 2, 2023 at 11:42 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I agree. If Toyota doesn’t want to do it. No way JiffyLube should be doing it. You aren’t pressuring anything by draining it. Draining would be your best option.
    SR-71A and 69 Jim like this.
  20. Jun 2, 2023 at 12:21 PM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
