8" vs. 8.4" diff
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 03f5sp, Apr 19, 2014.
  1. Apr 19, 2014 at 3:36 PM
    03f5sp
    03f5sp [OP] Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    Why do the Off Road models use a smaller rear differential? It seems like you'd want a larger/stronger one for the abuse they see. From what I understand, the Off Road is the only one with the small 8". So what gives?
  2. Apr 19, 2014 at 3:40 PM
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    The 8.4 still has a 8 inch ring gear it just has a stud girdle that increases strength. The 8 inch locking diff is plenty strong for what it is bring used for.
    Wulf likes this.
  3. Apr 19, 2014 at 3:55 PM
    03f5sp
    Bill
    Wisconsin
    What is a stud girdle and why doesn't the OR diff have one?
  4. Apr 19, 2014 at 4:52 PM
    Redneck92
    Concord, NC
    It ties both carrier bearing caps together for less deflection. My guess the reason is because the 8.4 was not out when the elocker was designed, not really sure. The difference in strength is probably marginal.
  5. Apr 19, 2014 at 5:05 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Not sure, but I think 8.4 " is the ring gear diameter where as the 8 " has an 8" ring gear diameter. I also think that All Pro and others have used it as opposed to the 8" for strength in their builds and add lockers like the Detroit Locker fro way more durability. I think, and have read.
  6. Apr 19, 2014 at 5:23 PM
    Redneck92
    Concord, NC
    wi_taco and WRDD Taco like this.
  7. Apr 19, 2014 at 5:35 PM
    Gearheadesw
    Davenport Fl
    I thought wrong.
  8. Apr 19, 2014 at 5:42 PM
    discoy2k
    discoy2k Well-Known Member
    DISCO
    NOLA
    05 TRDSport 3" Iron Man Coil, Stealth
    2005 to 2012 Front End Replace,2010 TRD Interior,6x Escort Shifters, Escort 9500ix, Escort LIVE w/ 4G Data, 100% Stealth on Interstate,De-Badged Completely,5% Tint Blacked out,Iron Man lift,InfraRed military Humvee Spots, Drive in 0lite,Lexus/Fujisu NAV, dual 8in lcd sun visors, 2 10" kicker solobaric dvc 2ohm, phoenix gold 2000 watt, lunar 100watt @ 1/4 ohm,3 farad cap kicker 250watt,2800watt ,TRU-SINE inverter, dual HID bulb+HID fogs w/ mod, Roof rack,Westin Bull Bar, Manik Side Bars, Sirius/XM (HACKED) Undercover Bed Cover, bosch Wipers, Iridium Plugs, Undercover Bed Cover
    How can you tell which one you have? Is it only the OR package trucks that have thr 8"?
  9. Apr 19, 2014 at 5:45 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    The "8" inch comes with the TRD e-locker rear end.
  10. Apr 19, 2014 at 6:00 PM
    discoy2k
    DISCO
    NOLA
    Ok, thanx
  11. Apr 19, 2014 at 7:52 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    every time i hear someone reference whats strong than another. Remember... the stresses typically seen by the open diff (dont kid yourself about the mechanical lsd) on the "8.4" are going to be much less than what is possible on the 8in locking diff when its locked, simply due to the nature of being locked.
    Yes if both tires are on pavement and you gun it in either config they will see the same stress obviously. But where you see failures is on the trail, and the failures you see are typically with the stock elocker (8in) on a truck that is modded with bigger tires in obviously a pretty crazy situation to need a locker. You dont hear of the failures on the 8.4in because they simply arnt put into the situations to do so because with the open diff the truck cant get there!
  12. Apr 19, 2014 at 7:57 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Mostly but not entirely true. What about shock loads on a LSD or open diff. Those loads would potentially be higher than a locked diff not slipping.
  13. Apr 19, 2014 at 7:58 PM
    Supra TT
    Eric
    Indiana
    They're both weak. D70 FTW.
    otis24 and Mully like this.
  14. Apr 19, 2014 at 8:00 PM
    Boone
    Boone, NC
    Airbags deployed
    70 HD.\/ \/
  15. Apr 19, 2014 at 8:30 PM
    Redneck92
    Concord, NC
    Lol Dana 80 ftmfw
    GARSHA91 and Mully like this.
  16. Apr 19, 2014 at 8:34 PM
    nd4spdbh
    SoCal
    This is true i guess. If the person is hopping up and down yeah the loads could be higher. But like stated the stock e lockers that you typically see fail are on rigs with bigger tires in some pretty gnarly situations w/ the locker engaged and a heavy foot. If the 8.4 could have gotten to that same spot it would have broken as well.
    Unless you are doing serious crawling on 35's the stock diff both 8 and 8.4 are pretty darn good.
  17. Apr 19, 2014 at 8:37 PM
    Redneck92
    Concord, NC
    There's guys running elockers on 6k lbs rigs on 42s. The failure point is going to be the shafts first then more than likely the ring and pinion.
  18. Apr 20, 2014 at 2:38 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    There are plenty of photos of failed ring gears on the 8.0.
    The 8.4, even though it is truly the same size gear, has 12 bolts vs the 10 bolts in the 8.0.
    It has been said, but again without some kind of slow motion of the failure, that the girdle will keep the bearings aligned and support the outward stress on the ring and carrier. The 8.0 without the girdle, flexes the internals, then the gear slips and breaks.
    FWIW, my 2010 DCLB TRD Sport has been swapped to remove the open diff and now runs a TrueTrac. If anything, the stupid electronics cause the most grief to sort out how best to over ride them with the button when off road.
    PK
  19. Apr 20, 2014 at 8:01 AM
    Supra TT
    Eric
    Indiana
    Who's running 42s with 6k # rigs? Only rigs I can think of are new 4 runners and tacos that weight that much.
    Well you didn't say elocker Toyota axle... But I'm assuming you are, and talking about the 8" lol
  20. Apr 20, 2014 at 8:23 AM
    Redneck92
    Concord, NC
    Nobody on here have seen a few on pirate. Probably a little high on the weight guess. The way some toy guys are going now are 9.5 hybrid axles.
